151-00503
151-00503
    HELLERMAN(海尔曼太通)
    HELLERMANNTYTON - 151-00503 - Fastener, Flat Design, Adhesive Backed Cable Clamp, Nylon (Polyamide),...
151-00503 数据手册
Cable Ties and Fixings 1.8 Clips, Clamps and Plugs Snapper Hose Clips for Tubes and Harnesses • SNP-Series TYPE Bundle Ø min. Bundle Ø max. Width (W) min. Width (W) max. Width (W2) Wall (WT) Material Colour Article-No. SNP19 22.3 25.3 22.3 36.09 5.9 1.80 PA66GF13 Black (BK) 190-00090 SNP20(E) 22.7 24.7 20.0 26.0 6.0 1.80 POM Natural (NA) 191-10209 SNP22 23.7 27.4 23.9 37.69 6.0 1.80 PA66GF13 Black (BK) 192-10220 SNP22(E) 25.3 27.3 20.0 26.0 6.0 1.60 POM Natural (NA) 191-10229 SNP24 25.8 29.2 26.49 39.4 7.4 1.70 PA66GF13 Black (BK) 192-10240 SNP24(E) 26.5 28.6 26.5 39.4 7.4 2.50 POM Natural (NA) 191-10249 SNP28 29.1 33.6 25.91 41.81 7.3 1.70 PA66GF13 Black (BK) 190-00127 SNP32(E) 30.3 33.1 27.0 34.0 7.5 2.00 POM Natural (NA) 191-10329 SNP32 31.2 35.8 27.33 44.4 7.3 1.80 PA66GF13 Black (BK) 192-10320 SNP34(E) 32.5 35.1 27.0 34.0 7.5 2.00 POM Natural (NA) 191-10349 SNP36(E) 34.8 37.1 27.0 34.0 7.5 2.00 POM Natural (NA) 191-10369 SNP38(E) 36.7 38.9 27.0 34.0 7.5 2.00 POM Natural (NA) 191-10389 SNP36 37.8 44.0 32.41 43.99 7.3 1.70 PA66GF13 Black (BK) 192-10360 SNP42(E) 41.0 44.2 32.0 45.0 7.5 2.00 POM Natural (NA) 191-10429 SNP38 41.0 48.1 35.61 57.51 7.3 1.80 PA66GF13 Black (BK) 192-10380 SNP42N 44.5 52.2 35.1 58.93 7.3 1.70 PA66GF13 Black (BK) 191-00005 SNP50(E) 48.8 52.0 32.0 45.0 7.5 2.00 POM Natural (NA) 191-10509 SNP50 52.2 58.6 36.5 60.4 7.5 1.70 PA66GF13 Black (BK) 192-10500 SNP58(E) 56.7 59.2 31.0 39.0 7.5 2.00 POM Natural (NA) 191-10589 All dimensions in mm. Subject to technical changes. Self Adhesive Clips • RB-Series with flat design Features and Benefits • One-piece self-adhesive fixing clips for quick and easy installation • Designed to hold wires, cables or hoses without a cable tie • Flat design for use in applications with limited space • Different sizes for various bundle diameters • Cost effective with easy application on smooth, clean surfaces For more information on the types of adhesive please see page 118. TYPE Width (W) Width (W2) Length (L) Height (H) Bundle Ø max. Material Colour Adhesive Article-No. RB20 27.0 18.0 33.0 25.0 20.0 PA66HIRHS Black (BK) Synthetic rubber 151-00831 27.4 23.0 33.2 16.0 14.0 PA66 Black (BK) Synthetic rubber 151-00502 27.4 23.0 33.2 16.0 14.0 PA66 Natural (NA) Synthetic rubber 151-00505 RB14 All dimensions in mm. Subject to technical changes. 154 Further information and products at www.HellermannTyton.co.uk/b154 Date of issue: January 2014 RB20 RB5-14 Self Adhesive Clip Cable Ties and Fixings 1.1 Material Information Materi a Propert l ies* ability Flamm Aluminium-alloy AL -40 °C to +180 °C Natural (NA) • Corrosion resistant • Antimagnetic Chloroprene CR -20 °C to +80 °C Black (BK) • Weather-resistant • High yield strength Ethylenterafluorineethylen E/TFE -80 °C to +170 °C Blue (BU) UL94 V0 • Resistance to radioactivity • UV- resistant, not moisture sentitive • Good chemical resistance to: • acids, bases, oxidizing agents Polyacetal POM -40 °C to +90 °C, (+110 °C, 500 h) Natural (NA) UL94 HB • Limited brittleness sensitivity • Flexible at low temperature • Not moisture sensitive • Robust on impacts Polyamide 11 PA11 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Bio-plastic, derived from vegetable oil • Strong impact resistance at low temperature • Very low moisture absorption • Weather-resistant • Good chemical resistance Polyamide 12 PA12 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Good chemical resistance to: • acids, bases, oxidizing agents • UV- resistant Polyamide 4.6 PA46 -40 °C to +150 °C (5000 h), +195 °C (500 h) Natural (NA), Grey (GY) UL94 V2 • Resistance to high temperatures • Very moisture sensitive • Low smoke sensitive Polyamide 6 PA6 -40 °C to +80 °C Black (BK) UL94 V2 • High yield strength Polyamide 6.6 PA66 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK), Natural (NA) UL94 V2 • High yield strength Polyamide 6.6, Glassfibre reinforced PA66GF13, PA66GF15 -40 °C to +105 °C Black (BK) UL94 HB • Good resistance to: lubricants, vehicle fuel, salt water and many solvents Polyamide 6.6 heat and UV stabilised PA66HSW -40 °C to +105 °C Black (BK) UL94 V2 • High yield strength • Modified elevated max. temperature • UV-resistant Polyamide 6.6 Heat Stabilised PA66HS -40 °C to +105 °C Black (BK), Natural (NA) UL94 V2 • High yield strength • Modified elevated max. temperature Polyamide 6.6 High Imp. Mod., Heat Stab. PA66HIRHS -40 °C to +105 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature Polyamide 6.6 High Imp. Mod. scan black PA66HIR(S) -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature Polyamide 6.6 High Impact Modified PA66HIR -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature Polyamide 6.6 high impact modified, heat and UV stabilised PA66HIRHSW -40 °C to +110 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature • High yield strength, UV-resistant Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®-Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers. *These details are only rough guide values. They should be regarded as a material specification and are no substitute for a suitability test. Please see our datasheets for further details. 30 **More colours on request. = Minimum Tensile Strength Further information and products at www.HellermannTyton.co.uk/b30 Date of issue: January 2014 Colour* * Opera tin Tempe g rature ut Shortc Materi al Material Specification Overview Cable Ties and Fixings 1.1 Material Information Materi a Propert l ies* ability Flamm Colour* * Opera tin Tempe g rature ut Shortc Materi al Material Specification Overview Polyamide 6.6 UV Resistant PA66W -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 V2 • High yield strength • UV-resistant Polyamide 6.6 V0 PA66V0 -40 °C to +85 °C White (WH) UL94 V0 • High yield strength • Low smoke emission Polyamide 6.6 V0 High Oxygen Index PA66V0-HOI -40 °C to +85 °C, (+105 °C, 500 h) White (WH) UL94 V0 • High yield strength • Low smoke emissions Polyamide 6.6 with metal particles PA66MP -40 °C to +85 °C, (+105 °C, 500 h) Blue (BU) UL94 HB • High yield strength Polyamide 6 high impact modified PA6HIR -40 °C to +80 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature SP -50 °C to +150 °C Black (BK) PEEK -55 °C to +240 °C Beige (BGE) UL94 V0 • Resistance to radioactivity • Not moisture sensitive • Good chemical resistance to: acids, bases, oxidizing agents Polyethylene PE -40 °C to +50 °C Black (BK), Grey (GY) UL94 HB • Low moisture absorption • Good chemical resistance to: most acids, alcohol and oils Polyolefin PO -40 °C to +90 °C Black (BK) UL94 V0 • Low smoke emissions Polypropylene PP -40 °C to +115 °C Black (BK), Natural (NA) UL94 HB • Floats in water • Moderate yield strength • Good chemical resistance to: organic acids Polypropylene, Ethylene-Propylene-Dien-Terpolymere-rubber free of Nitrosamine PP, EPDM -20 °C to +95 °C Black (BK) UL94 HB • Good resistance to high temperatures • Good chemical and abrasion resistance Polyvinylchloride PVC -10 °C to +70 °C Black (BK), Natural (NA) UL94 V0 • Low moisture absorption • Good chemical resistance to: acids, ethanol, oil Stainless Steel SS304, SS316 -80 °C to +538 °C Natural (NA) Thermoplastic Polyurethane TPU -40 °C to +85 °C Black (BK) Polyester Polyetheretherketone • UV-resistant • Good chemical resistance to: most acids, alkalis and oils • Corrosion resistant • Antimagnetic UL94 HB Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®-Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers. • High elastic • Good chemical resistance to: • acids, bases, oxidizing agents **More colours on request. Date of issue: January 2014 *These details are only rough guide values. They should be regarded as a material specification and are no substitute for a suitability test. Please see our datasheets for further details. Further information and products at www.HellermannTyton.co.uk/b31 = Minimum Tensile Strength 31
151-00503 价格&库存
很抱歉,暂时无法提供与“151-00503”相匹配的价格&库存,您可以联系我们找货
