151-28529
    HELLERMAN(海尔曼太通)
151-28529 数据手册
Cable Ties and Fixings 1.7 Cable Tie Mounts Self Adhesive, Screw Fixing Cable Tie Mounts Where speed, simplicity and a firm fixing base are required these self adhesive clips are ideal. Particularly suitable for use in control cabinets, telecoms equipment or domestic appliances where the use of holes, screws or nuts and bolts are impractical or undesirable. Features and Benefits • Screw or self-adhesive versions • Simple to install with a screw or bolt • Excellent security, particularly in areas of high vibration • Maximum adhesive surface area to achieve high pull-off force • 4-way entry for cable tie for quicker and more flexible installation MB-Series Square-Cut, self adhesive, screwable G G H H L Cable Tie Mount MB2A (side and plan view) MB2A MB3A MB4A3 MB4A MB4CA* MB4CAS MB5A MB5A3 W FH W TYPE MB-Series Mounts with square design / screwable, self adhesive. L Cable Tie Mount MB4CA (side and plan view) Width (W) 13.0 Length (L) 13.0 Height (H) 4.1 Hole Ø (FH) - Strap Width max. (G) 2.7 Material PA66 19.0 19.0 3.8 3.1 4.1 19.0 28.0 19.0 28.0 3.8 4.7 3.1 4.0 4.1 5.4 28.0 28.0 4.7 4.0 5.4 28.0 29.0 29.0 37.7 38.0 28.0 29.0 29.0 37.7 38.0 4.7 5.7 5.7 7.1 6.4 4.0 4.2 4.2 4.8 4.7 5.4 5.4 5.4 8.9 10.0 Cable Tie Mount MB3A in application Colour Natural (NA) Adhesive Synthetic rubber T60 Pack Cont. 100 pcs. Article-No. 151-01802 PA66 Black (BK) Synthetic rubber T60 100 pcs. 151-28320 PA66 PA66 Natural (NA) Black (BK) Synthetic rubber T60 Acrylate 100 pcs. 100 pcs. 151-28349 151-28430 PA66 Black (BK) Synthetic rubber T60 100 pcs. 151-28412 PA66 PA66 PA66 PA66 PA66 Natural (NA) Natural (NA) Natural (NA) White (WH) Black (BK) Synthetic rubber T60 Synthetic rubber T60 Synthetic rubber T60 Synthetic rubber T50 Acrylate 100 pcs. 100 pcs. 100 pcs. 100 pcs. 100 pcs. 151-28469 151-28459 151-28449 151-28529 151-28530 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. * Plastic box MB-Series Square-Cut, screwable G F L Material specification please see page 24. FH W For more information on the types of adhesive please see page 129. Date of issue: October 2015 MB3-MB5 (side view) TYPE MB3 MB4 MB5 MB3-MB5 (plan view) Width (W) 19.0 28.0 37.7 Length (L) 19.0 28.0 37.7 Height (H) 3.8 4.7 6.2 Fixing Hole Centres (F) 13.2 20.0 25.3 Hole Ø (FH) 3.1 4.0 4.8 Strap Width max. (G) 4.1 5.4 8.9 Material PA66 PA66 PA66 Colour Natural (NA) Natural (NA) White (WH) Pack Cont. 100 pcs. 100 pcs. 100 pcs. Article-No. 151-28359 151-28479 151-00324 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.com/fixings 131 Cable Ties and Fixings 1.0 Material Information Material Specification Overview Material Shortcut Operating Temperature Aluminium-alloy AL -40 °C to +180 °C Natural (NA) • Corrosion resistant • Antimagnetic Chloroprene CR -20 °C to +80 °C Black (BK) • Weather-resistant • High yield strength Ethylene Tetrafluoroethylene E/TFE -80 °C to +170 °C Blue (BU) UL94 V0 Polyacetal POM -40 °C to +90 °C, (+110 °C, 500 h) Natural (NA) UL94 HB Polyamide 11 PA11 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 HB Polyamide 12 PA12 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Good chemical resistance to: acids, bases, oxidizing agents • UV-resistant Polyamide 4.6 PA46 -40 °C to +150 °C (5000 h), +195 °C (500 h) Natural (NA), Grey (GY) UL94 V2 • Resistance to high temperatures • Very moisture sensitive • Low smoke sensitive Polyamide 6 PA6 -40 °C to +80 °C Black (BK) UL94 V2 • High yield strength PA6HIR -40 °C to +80 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature Polyamide 6.6 PA66 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK), Natural (NA) UL94 V2 • High yield strength Polyamide 6.6, PA66GF13, PA66GF15 -40 °C to +105 °C Black (BK) UL94 HB • Good resistance to: lubricants, vehicle fuel, salt water and many solvents PA66HSW -40 °C to +105 °C Black (BK) UL94 V2 • High yield strength • Modified elevated max. temperature • UV-resistant Polyamide 6.6, heat stabilised PA66HS -40 °C to +105 °C Black (BK), Natural (NA) UL94 V2 • High yield strength • Modified elevated max. temperature Polyamide 6.6, high impact modified PA66HIR -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL94 HB Polyamide 6.6, high impact modified, heat and UV stabilised PA66HIRHSW -40 °C to +110 °C Black (BK) UL94 HB Polyamide 6.6, high impact modified, heat stabilised PA66HIRHS -40 °C to +105 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature Polyamide 6.6, high impact modified, scan black PA66HIR(S) -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature PA66W -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 V2 • High yield strength • UV-resistant Polyamide 6, high impact modified glass-fibre reinforced Polyamide 6.6, heat and UV stabilised Polyamide 6.6, UV-resistant Colour** Material Properties* Flammability Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers. • Resistance to radioactivity • UV-resistant, not moisture sensitive • Good chemical resistance to: acids, bases, oxidizing agents • Limited brittleness sensitivity • Flexible at low temperature • Not moisture sensitive • Robust on impacts • Bio-plastic, derived from vegetable oil • Strong impact resistance at low temperature • Very low moisture absorption • Weather-resistant • Good chemical resistance • Limited brittleness sensitivity • Higher flexibility at low temperature • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature • High yield strength, UV-resistant **More colours on request. *These details are only rough guide values. They should be regarded as a material specification and are no substitute for a suitability test. Please see our datasheets for further details. HF = Halogenfree LFH = Limited Fire Hazard RoHS = Restriction of Hazardous Substances 24 Material Specifications Further information at www.HellermannTyton.com/fixings Date of issue: October 2015 MATERIAL Cable Ties and Fixings Material Information Material Shortcut Operating Temperature Polyamide 6.6, with metal particles PA66MP Polyamide 6.6 V0 MATERIAL Material Properties* Colour** Flammability -40 °C to +85 °C, (+105 °C, 500 h) Blue (BU) UL94 HB • High yield strength • Metal and X-Ray detectable PA66V0 -40 °C to +85 °C White (WH) UL94 V0 • High yield strength • Low smoke emission PA66V0-HOI -40 °C to +85 °C, (+105 °C, 500 h) White (WH) UL94 V0 • High yield strength • Low smoke emissions SP -50 °C to +150 °C Black (BK) Halogen free • UV-resistant • Good chemical resistance to: most acids, alkalis and oils PEEK -55 °C to +240 °C Beige (BGE) UL94 V0 • Resistance to radioactivity • Not moisture sensitive • Good chemical resistance to: acids, bases, oxidizing agents Polyethylene PE -40 °C to +50 °C Black (BK), Grey (GY) UL94 HB • Low moisture absorption • Good chemical resistance to: most acids, alcohol and oils Polyolefin PO -40 °C to +90 °C Black (BK) UL94 V0 • Low smoke emissions Polypropylene PP -40 °C to +115 °C Black (BK), Natural (NA) UL94 HB • Floats in water • Moderate yield strength • Good chemical resistance to: organic acids PP, EPDM -20 °C to +95 °C Black (BK) UL94 HB • Good resistance to high temperatures • Good chemical and abrasion resistance Polyamide 6.6 V0, High Oxygen Index Polyester Polyetheretherketone Polypropylene, EthylenePropylene-DienTerpolymere-rubber free of Nitrosamine Polypropylene with metal particles PPMP -40 °C to +115 °C Blue (BU) UL94 HB • Floats in certain liquids • Metal and X-Ray detectable • Heat resistant • Moderate yield strength • Good chemical resistance Polyvinylchloride PVC -10 °C to +70 °C Black (BK), Natural (NA) UL94 V0 • Low moisture absorption • Good chemical resistance to: acids, ethanol and oil Stainless Steel, Stainless Steel SS304, SS316 -80 °C to +538 °C Natural (NA) Non burning • Corrosion resistant • Antimagnetic • Weather resistant • Outstanding chemical resistance Thermoplastic Polyurethane TPU -40 °C to +85 °C Black (BK) UL94 HB • High elasticity • Good chemical resistance to: acids, bases and oxidizing agents Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers. 1.0 Material Specifications **More colours on request. Date of issue: October 2015 *These details are only rough guide values. They should be regarded as a material specification and are no substitute for a suitability test. Please see our datasheets for further details. HF = Halogenfree LFH = Limited Fire Hazard RoHS = Restriction of Hazardous Substances Further information at www.HellermannTyton.com/fixings 25 Cable Ties and Fixings Technical Information Information and installation instructions for self-adhesive mounting bases HellermannTyton uses different types of adhesives for self-adhesive bases: acrylate and synthetic rubber. These differ in the operating temperature range and the 'pull off' force of the adhesive. Synthetic rubber has an excellent initial grip, allowing for almost immediate use. Acrylate adhesive has less initial grip, so there is a need to wait for a few hours before use, but has a higher 'pull off' force than synthetic rubber. This enables a permanent fixing lasting months or even years. To use these adhesives the surface must be dry, and free of dust, oil, oxides, parting agents and other impurities. For this the use of isopropane / water (50/50) is recommended. After cleaning allow the surface to dry completely. Peel off the protective backing on the self-adhesive base, ensuring the adhesive is not touched. Apply the part to the surface and press down firmly for several seconds. Instructions for use 1. The surface must be dry, free from dust, oil, oxides, parting agents and other impurities. The surface to be glued should be cleaned using a clean cloth and isopropanol / water (50/50). When using other appropriate cleaning agents, ensure that they do not attack the surface nor leave any residues. 2. After cleaning allow the surface to air-dry completely. Adhesive Operating Temperature ADHESIVE Synthetic rubber with base of polyethylene foam 1.7 Synthetic rubber T50 -20 °C to +50 °C Synthetic rubber T60 -40 °C to +60 °C Acrylate with base of polyurethane foam Acrylate to +105 °C Acrylate with base of acrylic foam mod. Acrylate -40 °C to +90 °C 3. Peel off protective backing and ensure the adhesive area is not touched. 4. Press down firmly on the base with the thumbs for several seconds. We will be happy to send you on request an up-todate technical datasheet for whichever adhesive you are using. Date of issue: October 2015 5. Depending on the type of adhesive, wait for several minutes (synthetic rubber) or hours (acrylate) so that the adhesive can bond completely with the surface. Further information at www.HellermannTyton.com/fixings 129
151-28529 价格&库存
很抱歉,暂时无法提供与“151-28529”相匹配的价格&库存,您可以联系我们找货
  • 10+9.0783110+1.08480
  • 50+8.3217850+0.99440
  • 100+7.37613100+0.88140
库存:25
