156-01807
    HELLERMAN(海尔曼太通)
    T50SOSBHMB 6MM BLIND HOLE MNT
156-01807 数据手册
156-01807 Article Number: 156-01807 Description: Blind Hole Mount Outside Serrated Tie 1/4" Thread/NonThread Hole, 6", 50lb, PA66HS, Black, 500/bag Base Data Local Order Number 156-01807 Type T50SOSBHMB Color Black (BK) Features and benefits ‡Delivers high extraction force for reliable performance, yet it¶s easy to install. ‡Reusable fastener can be removed from threaded or nonthreaded holes using a 5/16" hex driver. ‡Heat stabilized material provides excellent resistance to high temperatures. Quantity Per bag Product Description HellermannTyton Blind Hole Mount Cable Ties for threaded and nonthreaded holes offer an easy-to-use method for bundling and affixing cables. The two-piece design includes a heat stabilized cable tie and formula-matched, 1/4" mount that features a low insertion force and aggressively resists pull off. Performs equally well in threaded or nonthreaded blind holes. Mount can slide along cable tie to adjust orientation if needed. Fastener can be removed from hole using a hex driver. This ensures fastener can be reused. GLOBAL PART NAME (auto set) T50SOSBHMB-PA66HS-BK Short Description Blind Hole Mount Outside Serrated Tie 1/4" Thread/Non-Thread Hole, 6", 50lb, PA66HS, Black, 500/bag Minimum Tensile Strength (Imperial) 50.0lbs Minimum Tensile Strength (Metric) 225.0N Length L (Imperial) 6.0" Length L (Metric) 150.0mm Fixing Hole Depth Min. (Imperial) 0.5" Fixing Hole Depth Min. (Metric) 12.7mm Identification Plate Position none Width W (Imperial) 0.31" Width W (Metric) 7.8mm Height H (Imperial) 0.736" Height H (Metric) 18.7mm Product Dimensions generated on: 12/13/2017 156-01807 Product Dimensions Height H2 (Imperial) 0.488" Height H2 (Metric) 12.4mm Bundle Diameter Min. (Imperial) 0.10" Bundle Diameter Min. (Metric) 2.5mm Bundle Diameter Max. (Imperial) 1.40" Bundle Diameter Max. (Metric) 35.0mm Diameter D (imperial) 0.25" Diameter D (metric) 6.0mm Material Polyamide 6.6 heat stabilized (PA66HS) Material Shortcut PA66HS Flammability UL 94 V2 Operating Temperature -40°F to +257°F (-40°C to +125°C) ROHS Compliant Yes Package Quantity (Imperial) 500 Package Quantity (Metric) 500 Material and Specifications Logistic and Packaging generated on: 12/13/2017
156-01807 价格&库存
很抱歉,暂时无法提供与“156-01807”相匹配的价格&库存,您可以联系我们找货
