164-41008
    HELLERMAN(海尔曼太通)
164-41008 数据手册
Cable Protection Systems 3.5 Protective Tubing and Spiral Binding Flexible Cable Support Heladuct Flex Heladuct flexible cable supports are commonly used in switching cabinets. They are also used in the furniture industry, where cables need to be routed rapidly and attractively. Features and Benefits • Space-saving wiring system • Highly flexible, can be installed at angles of 90° and higher • Cable clearly open to view • Rapid mounting with screws or adhesive strip with high-quality foam bonding layer Heladuct Flex- clearly and space-saving arrangement of wiring, even at angles above 90°. TYPE Nominal Ø MATERIAL Polypropylene (PP) Operating Temperature -20 °C to +70 °C Adhesive Synthetic rubber with base of polyethylene foam Flammability UL94 V0 (excluding adhesive) Max. load on a length of 500 mm at 70 °C (g) No. of Wires Colour Length (L) Article-No. Heladuct Flex10 10 9 x 0.75 mm² 6 x 1.50 mm² 4 x 2.50 mm² 100 White (WH) 500.0 164-11008 Heladuct Flex20 20 32 x 0.75 mm² 22 x 1.50 mm² 14 x 2.50 mm² 300 White (WH) 500.0 164-21008 Heladuct Flex30 30 67 x 0.75 mm² 50 x 1.50 mm² 34 x 2.50 mm² 650 White (WH) 500.0 164-31008 Heladuct Flex40 40 - 81 x 1.50 mm² 60 x 2.50 mm² 1,100 White (WH) 500.0 164-41008 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. TYPE Nominal Ø No. of Wires Max. load on a length of 500 mm at 70 °C (g) Colour Length (L) Article-No. Heladuct Flex10SK 10 9 x 0.75 mm² 6 x 1.50 mm² 4 x 2.50 mm² 100 White (WH) 500.0 164-11108 Heladuct Flex20SK 20 32 x 0.75 mm² 22 x 1.50 mm² 14 x 2.50 mm² 300 White (WH) 500.0 164-21108 Heladuct Flex30SK 30 67 x 0.75 mm² 50 x 1.50 mm² 34 x 2.50 mm² 500 White (WH) 500.0 164-31108 Heladuct Flex40SK 40 - 81 x 1.50 mm² 60 x 2.50 mm² 400 White (WH) 500.0 164-41108 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. 320 Further information at www.HellermannTyton.com/protection Date of issue: October 2015 Heladuct Flex with Adhesive
164-41008 价格&库存
很抱歉,暂时无法提供与“164-41008”相匹配的价格&库存,您可以联系我们找货
