333-41509
Article Number: 333-41509
Heat Shrink Tubing, 4FT-Stick, 3:1, 3/16", 4.8/1.5 dia., Polyolefin, Black, 20/pkg
Download spec sheet
Base Data
Local Order Number 333-41509
Type TFN31-ST-4.5/1.5 BK
Color Black (BK)
Features and Benefits • Thin wall, flexible 3 to 1 shrink ratio material accommodates a wide range of component shapes and diameters.
• Meets UL224 VW-1 specifications, making it ideal for high heat applications (excludes clear tubing).
• Polyolefin material provides excellent insulation and mechanical strength with good resistance to solvents, oils and
fuels.
• Available in bulk reels, sticks and convenience bags (HIS-3 bags), for small to large volume applications.
Product Description TFN31 series heat shrink tubing features a flexible, thin wall and highly flame retardant polyolefin material with a
higher operating temperature range than general-use heat shrink tubing. and offers good resistance to solvents, oils
and fuels. The 3 to 1 shrink ratio accommodates a variety of component shapes and sizes. TFN31 tubing is available
in bulk reels, sticks and convenience bags (HIS-3 bags), for projects of all sizes.
Short Description Heat Shrink Tubing, 4FT-Stick, 3:1, 3/16", 4.8/1.5 dia., Polyolefin, Black, 20/pkg
Product Dimensions
Length L (Metric) 1.22 m
Printable (Yes/No) No
Shrink Ratio 3:1
Tensile Strength (MPa) 14 MPa
Trade Size 3/16 "
Variant Thin-Wall
Volume Resistance (Ohm cm) 10¹ Ω cm
Nominal Diameter (Imperial) 3/16 "
Nominal Diameter (Metric) 4.5 mm
Wall Thickness WT (Imperial) 0.024 "
Wall Thickness WT (Metric) .60 mm
Recovered Diameter d (metric) 1.5 mm
Recovered Diameter d (imperial) 0.094 "
Supplied Diameter D (imperial) 0.188 "
Supplied Diameter D (metric) 4.8 mm
Logistics and Packaging
Quantity Per lengths
Package Quantity 20
Material and Specifications
Material Polyolefin, cross-linked (PO-X)
Material Shortcut PO-X
Dielectric Strength (Metric) 20 kV/mm
Elongation at break 600%
Flammability UL224 VW-1
Halogenfree No
Shrink Temperature +212 °F (+100 °C)
Operating Temperature -67°F to +275°F (-55°C to +135°C)
ROHS Compliant Yes
Certification/Specification UL224 125 °C 600V VW-1
CSA
UL Recognized (US) Yes
© HellermannTyton 2015
很抱歉,暂时无法提供与“333-41509”相匹配的价格&库存,您可以联系我们找货
