Bundling and Securing
C a b l e Ti e M o u n t s
Cable Tie Mounts
HellermannTyton offers a wide variety of mounting bases suited for
many applications. Mounting bases are used in conjunction with cable
ties to stabilize and secure wiring bundles, both indoors and outdoors.
These mounting bases can be secured to a surface using rubber based
adhesive, acrylic adhesive, or also can be screw mounted.
Cable Tie Mounting Bases
HellermannTyton’s 4-way mounting bases are available in four sizes
to accommodate T18 through T150 series cable ties. Insertion of
ties can be made from all four sides. Each mount may be secured
with two screws (four screws for the MB2.5 mount), with adhesive
backing, or both, for ease of application and stability.
Adhesive mounts are supplied in pairs connected
together on an adhesive liner.
Material Data
Material
For applications where higher temperatures, certain chemicals, or
UV radiation are a concern and an adhesive is the preferred
method for securing, the acrylic adhesive 4-way mounting bases
are recommended. The 2-way mounting bases may be secured
with one screw, with adhesive backing, or both, and allow ties to
be inserted from two sides.
Polyamide 6.6 (PA66)
Operating
Temperature
-40 °F to +185 °F
(-40 °C to +85 °C) continuous
Flammability
UL94 V2 (excluding adhesive)
2-way mount
4-way, MB2.5 mount
4-way, MB3, MB4 and MB5 mounts
Cable Tie Mounting Bases - Screw Mount
File# E64139
Product Selection
Article No.
Part No.
2- Way Screw Mount
Type
Cable Tie Series Mounting
Length (L)
Width (W)
Height (H)
in.
in.
in.
(mm)
(mm)
(mm)
Color
Pkg. Qty.
100
151-29104 MB4SH10C2 MB4SH
1.115″ (28.32)
1.115″ (28.32)
.202″ (5.13)
White
151-00323 MB4SH10H4 MB4SH
1.115″ (28.32)
.202″ (5.13)
White
500
1.115″ (28.32)
.202″ (5.13)
Black
100
1.115″ (28.32)
.202″ (5.13)
Black
500
151-29100 MB4SH0C2
MB4SH
# 6 Screw 1.115″ (28.32)
1.115″ (28.32)
151-29101 MB4SH0H4
MB4SH
1.115″ (28.32)
T18 - T50
4- Way Screw Mount
151-28901 MB2.510C2
MB2.5
.625″ (15.88)
.625″ (15.88)
.130″
(3.3)
White
100
151-28902 MB2.510M4
MB2.5
.625″ (15.88)
.625″ (15.88)
.130″
(3.3)
White
1000
151-00285 MB2.50C2
MB2.5
.625″ (15.88)
.625″ (15.88)
.130″
(3.3)
Black
100
151-00286 MB2.50M4
MB2.5
.625″ (15.88)
.625″ (15.88)
.130″
(3.3)
Black
1000
T18
# 3 Screw
151-28302 MB310C2
MB3
.75″
(19.0)
.75″
(19.0)
.15″
(3.8)
White
100
151-28305 MB310M4
MB3
.75″
(19.0)
.75″
(19.0)
.15″
(3.8)
White
1000
151-00136 MB30C2
MB3
.75″
(19.0)
.75″
(19.0)
.15″
(3.8)
Black
100
151-28301 MB30M4
MB3
.75″
(19.0)
.75″
(19.0)
.15″
(3.8)
Black
1000
151-28802 MB410C2
MB4
1.12″
(28.5)
1.12″
(28.5)
.19″
(4.8)
White
100
151-00319 MB410H4
MB4
1.12″
(28.5)
1.12″
(28.5)
.19″
(4.8)
White
500
151-00320 MB40C2
MB4
1.12″
(28.5)
1.12″
(28.5)
.19″
(4.8)
Black
100
(28.5)
1.12″
T18, T30
T18 - T50
#4 Screw
#8 Screw
151-28801 MB40H4
MB4
1.12″
(28.5)
.19″
(4.8)
Black
500
151-00324 MB510C2
MB5
1.485″ (37.7)
1.485″ (37.7)
.245″
(6.2)
White
100
151-28504 MB510F4
MB5
1.485″ (37.7)
1.485″ (37.7)
.245″
(6.2)
White
250
151-28500 MB50C2
MB5
1.485″ (37.7)
1.485″ (37.7)
.245″
(6.2)
Black
100
151-28501 MB50F4
MB5
1.485″ (37.7)
1.485″ (37.7)
.245″
(6.2)
Black
250
T18 - T150
#8 Screw
Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes.
58
w w w . h e l l e r m a n n . t y t o n . c o m
1 - 8 0 0 - 5 3 7 - 1 5 1 2
Cable Tie Mounting Bases continued
2-way mount
4-way, MB2.5 mount
Cable Tie Mounting Bases - Rubber-Based Adhesive
File# E64139
Product Selection
Cable Tie
Article No.
Part No.
Type
Series
2- Way Mount with Rubber - Based Adhesive
Mounting
Length (L)
Width (W)
Height (H)
in.
in. (mm)
in.
(mm)
(mm)
Color
Pkg. Qty.
100
1.115″ (28.32)
1.115″ (28.32)
.232″ (5.89)
White
Adhesive 1.115″ (28.32)
1.115″ (28.32)
.232″ (5.89)
White
500
1.115″ (28.32)
1.115″ (28.32)
.232″ (5.89)
Black
100
MB2.5A
.625″ (15.88)
.625″ (15.88)
.160″
(4.1)
White
100
151-00298 MB2.5A10M4 MB2.5A
.625″ (15.88)
.625″ (15.88)
.160″
(4.1)
White
1000
.625″ (15.88)
.625″ (15.88)
.160″
(4.1)
Black
100
.625″ (15.88)
.625″ (15.88)
.160″
(4.1)
Black
1000
151-29203 MB4SHA10C2 MB4SHA
151-29206 MB4SHA10H4 MB4SHA
151-29200 MB4SHA0C2
T18 - T50
MB4SHA
4- Way Mount with Rubber - Based Adhesive
151-29002 MB2.5A10C2
151-29000 MB2.5A0C2
MB2.5A
151-29001 MB2.5A0M4
MB2.5A
T18
Adhesive
151-28718 MB3A10C2
MB3A
.75″
(19.0)
.75″
(19.0)
.18″
(4.6)
White
100
151-28721 MB3A10M4
MB3A
.75″
(19.0)
.75″
(19.0)
.18″
(4.6)
White
1000
151-28710 MB3A0C2
MB3A
.75″
(19.0)
.75″
(19.0)
.18″
(4.6)
Black
100
151-28713 MB3A0M4
MB3A
.75″
(19.0)
.75″
(19.0)
.18″
(4.6)
Black
1000
151-28421 MB4A10C2
MB4A
1.12″
(28.0)
1.12″
(28.0)
.22″
(5.6)
White
100
151-00321 MB4A10H4
MB4A
1.12″
(28.0)
1.12″
(28.0)
.22″
(5.6)
White
500
151-28403 MB4A0C2
MB4A
1.12″
(28.0)
1.12″
(28.0)
.22″
(5.6)
Black
100
(28.0)
1.12″
T18, T30
T18 - T50
Adhesive
Adhesive
151-28406 MB4A0H4
MB4A
1.12″
(28.0)
.22″
(5.6)
Black
500
151-28529 MB5A10C2
MB5A
1.485″ (37.7)
1.485″ (37.7)
.275″
(6.9)
White
100
151-00427 MB5A10F4
MB5A
1.485″ (37.7)
1.485″ (37.7)
.275″
(6.9)
White
250
151-28602 MB5A0C2
MB5A
1.485″ (37.7)
1.485″ (37.7)
.275″
(6.9)
Black
100
151-28605 MB5A0F4
MB5A
1.485″ (37.7)
1.485″ (37.7)
.275″
(6.9)
Black
250
Color
Pkg. Qty.
100
T18 - T150
Adhesive
Cable Tie Mounting Bases - Acrylic Adhesive
Product Selection
Article No.
Part No.
Type Cable Tie Series Mounting
4 - Way Screw Mount Acrylic Adhesive
Length (L)
Width (W)
Height (H)
in. (mm)
in. (mm)
in. (mm)
151-00331 MB3A10A2C2 MB3A
.75″
(19.0)
.75″
(19.0)
.18″
(4.6)
White
151-28717 MB3A10A2H4 MB3A
.75″
(19.0)
.75″
(19.0)
.18″
(4.6)
White
500
.75″
(19.0)
.75″
(19.0)
.18″
(4.6)
Black
100
151-28711 MB3A0A2C2
MB3A
151-28709 MB3A0A2H4
T18, T30
Adhesive
MB3A
.75″
(19.0)
.75″
(19.0)
.18″
(4.6)
Black
500
151-28420 MB4A10A2C2 MB4A
1.12″
(28.5)
1.12″
(28.5)
.23″
(5.9)
White
100
151-00322 MB4A10A2H4 MB4A
1.12″
(28.5)
1.12″
(28.5)
.23″
(5.9)
White
500
1.12″
(28.5)
1.12″
(28.5)
.23″
(5.9)
Black
100
1.12″
(28.5)
1.12″
151-28402 MB4A0A2C2
MB4A
151-28405 MB4A0A2H4
MB4A
T18 - T50
Adhesive
151-28607 MB5A10A2C2 MB5A
151-28610 MB5A10A2F4 MB5A
151-28600 MB5A0A2C2
MB5A
151-28604 MB5A10A2F4 MB5A
T18 - T150
Adhesive
(28.5)
.23″
(5.9)
Black
500
1.485″ (37.7)
1.485″ (37.7)
.275″
(6.9)
White
100
1.485″ (37.7)
1.485″ (37.7)
.275″
(6.9)
White
250
1.485″ (37.7)
1.485″ (37.7)
.275″
(6.9)
Black
100
1.485″ (37.7)
1.485″ (37.7)
.275″
(6.9)
Black
250
59
Cable Tie Mounts
The CTM series is designed to provide stability to wire bundles. These mounts can accommodate miniature, intermediate, or
standard cross-section cable ties. Each mount is secured with a single screw.
Material Data
Material
Operating
Temperature
-40 °F to +185 °F (-40 °C to +85 °C) continuous
Flammability
UL94 V2
File# E64139
Product Selection
Length (L)
Article No.
Part No.
in. (mm)
in. (mm)
Color
.578″ (14.68)
.375″ (9.52)
.266″ (6.76)
White
100
151-30305 CTM010M4
.578″ (14.68)
.375″ (9.52)
.266″ (6.76)
White
1000
.578″ (14.68)
.375″ (9.52)
.266″ (6.76)
Black
100
.578″ (14.68)
.375″ (9.52)
.266″ (6.76)
Black
1000
.579″ (14.71)
.370″ (9.40)
.266″ (6.76)
White
100
.579″ (14.71)
.370″ (9.40)
.266″ (6.76)
White
1000
.579″ (14.71)
.370″ (9.40)
.266″ (6.76)
Black
100
.579″ (14.71)
.370″ (9.40)
.266″ (6.76)
Black
1000
.857″ (21.77)
.605″ (15.37)
.372″ (9.45)
White
100
.857″ (21.77)
.605″ (15.37)
.372″ (9.45)
White
1000
CTM0
151-30301 CTM00M4
151-30400 CTM10C2
# 6 Screw
CTM1
151-30402 CTM10M4
# 8 Screw
151-30504 CTM210C2
151-30506 CTM210M4
Mounting
T18 - T50
151-30404 CTM110C2
151-30406 CTM110M4
Cable Tie Series
CTM2
in. (mm)
Height (H)
151-30303 CTM010C2
151-30300 CTM00C2
Type
Width (W)
.857″ (21.77)
.605″ (15.37)
.372″ (9.45)
Black
100
151-30501 CTM20M4
.857″ (21.77)
.605″ (15.37)
.372″ (9.45)
Black
1000
151-30605 CTM310C2
.858″ (21.79)
.609″ (15.47)
.374″ (9.50)
White
100
151-30607 CTM310M4
.858″ (21.79)
.609″ (15.47)
.374″ (9.50)
White
1000
151-30500 CTM20C2
CTM3
T18 -T120
#10 Screw
.858″ (21.79)
.609″ (15.47)
.374″ (9.50)
Black
100
151-30603 CTM30M4
.858″ (21.79)
.609″ (15.47)
.374″ (9.50)
Black
1000
151-30703 CTM410C2
.864″ (21.95)
.616″ (15.65)
.372″ (9.45)
White
100
151-30705 CTM410M4
.864″ (21.95)
.616″ (15.65)
.372″ (9.45)
White
1000
.864″ (21.95)
.616″ (15.65)
.372″ (9.45)
Black
100
.864″ (21.95)
.616″ (15.65)
.372″ (9.45)
Black
1000
151-30600 CTM30C2
151-30700 CTM40C2
151-30702 CTM40M4
CTM4
.25″ Screw
60
Pkg. Qty.
Low Profile Cable Tie Mounts
Material Data
Low profile mounts are intended for use in
securing bundles where space is limited. Each
mount is fastened with a single screw.
Material
Operating
Temperature
Flammability
UL94 V2
File# E64139
Product Selection
Length (L)
Article No.
Part No.
Type
Cable Tie Series
Mounting
Width (W)
in. (mm)
Height (H)
in. (mm)
in. (mm)
Color
Pkg. Qty.
.500″ (12.70)
.312″
(7.92)
.130″
(3.30)
Natural
100
.500″ (12.70)
.312″
(7.92)
.130″
(3.30)
Natural
1000
.500″ (12.70)
.312″
(7.92)
.130″
(3.30)
Black
100
.500″ (12.70)
.312″
(7.92)
.130″
(3.30)
Black
1000
151-00227 MB29C2
.807″ (20.50)
.490″ (12.45)
.130″
(3.30)
Natural
100
151-00297 MB29M4
.807″ (20.50)
.490″ (12.45)
.130″
(3.30)
Natural
1000
.807″ (20.50)
.490″ (12.45)
.130″
(3.30)
Black
100
.807″ (20.50)
.490″ (12.45)
.130″
(3.30)
Black
1000
151-00226 MB19C2
151-00294 MB19M4
151-00295 MB10C2
MB1
#2 Screw
T18
151-00296 MB10M4
151-28210 MB20C2
MB2
T18 - T50
# 8 Screw
151-28202 MB20M4
Low Profile Rivet Mounts
Material Data
Material
The low profile rivet mount is designed to
secure wiring bundles and fastens with the
drive rivet through a predrilled hole. This
mount is ideal for use in applications where
space is limited.
Operating
Temperature
Flammability
UL94 V2
Product Selection
Article No.
Part No.
Type
151-27000 LKCRF19C2
LKCRF1
151-27009 LKCRF19H4
LKCRF1
Cable
Tie
Series
T18 T50
Mounting
Hole Ø
Max. Panel
Thickness
Length (L)
Width (W)
Height (H)
in. (mm)
in. (mm)
in. (mm)
in. (mm)
in. (mm)
Color
Pkg.
Qty.
.250″ (6.35)
.134″
(3.4)
.938″ (23.82) .470″ (11.94)
.157″ (3.99)
Natural
100
.250″ (6.35)
.134″
(3.4)
.938″ (23.82) .470″ (11.91)
.157″ (3.99)
Natural
500
61
Push Mounts
Material Data
Intended for use in a predrilled hole, this push mount accepts
T18 through T50 series cable ties. Once inserted through the
hole, the mount locks into place.
Material
Operating
Temperature
+85 °C) continuous
Flammability
UL94 V2
File# E64139
Product Selection
Article No.
Part No.
Type
151-40106 TM1SF10C2
TM1SF
151-00328 TM1SF10M4
TM1SF
151-40100 TM1SF0C2
TM1SF
151-40101 TM1SF0M4
TM1SF
Cable
Tie
Series
T18 T50
Mounting
Hole Ø
Max. Panel
Thickness
Length
(L)
Width
(W)
Height
(H)
in. (mm)
in. (mm)
in. (mm)
in. (mm)
in. (mm)
Color
Pkg.
Qty.
.25″
(6.3)
.134″
(3.4)
.616″ (15.65)
.401″ (10.19)
.181″ (4.60)
White
100
.25″
(6.3)
.134″
(3.4)
.616″ (15.65)
.401″ (10.19)
.181″ (4.60)
White
1000
.25″
(6.3)
.134″
(3.4)
.616″ (15.65)
.401″ (10.19)
.181″ (4.60)
Black
100
.25″
(6.3)
.134″
(3.4)
.616″ (15.65)
.401″ (10.19)
.181″ (4.60)
Black
1000
Push Button Mounts
Material Data
Material
The push button mounts are used where the back of the panel
is accessible.
Operating
Temperature
+85 °C) continuous
Flammability
UL94 V2
File# E64139
Product Selection
Article No.
Part No.
151-00230 PBM10C2
Cable
Tie
Type Series
PBM
151-00231 PBM10M4 PBM
151-00228 PBM0C2
PBM
151-00229 PBM0M4
PBM
T18 T50
Mounting
Hole Ø
in. (mm)
Max. Panel
Thickness
in. (mm)
Width
(W)
in. (mm)
Height
(H)
in. (mm)
Height
(H2)
in. (mm)
Color
.25″
(6.4)
.122″
(3.1)
.26″ (6.60)
.40″ (10.16)
.08″ (2.03)
White
100
.25″
(6.4)
.122″
(3.1)
.26″ (6.60)
.40″ (10.16)
.08″ (2.03)
White
1000
.25″
(6.4)
.122″
(3.1)
.26″ (6.60)
.40″ (10.16)
.08″ (2.03)
Black
100
.25″
(6.4)
.122″
(3.1)
.26″ (6.60)
.40″ (10.16)
.08″ (2.03)
Black
1000
62
Pkg. Qty.
Cable Tie Anchor Mounts
Cable ties may be inserted from any of the four sides of the CTAM. This feature allows the mount to be placed either
parallel or perpendicular to the wires.
Material Data
Material
Operating
Temperature
-40 °F to +185 °F
Flammability
UL94 V2
File# E64139
Product Selection
Width (W)
Article No.
Part No.
Type
Length (L)
in. (mm)
Height (H)
in. (mm)
in. (mm)
Color
Pkg. Qty.
CTAM1
.400″ (10.16)
.800″ (20.32)
.200″ (5.08)
White
100
151-31106 CTAM110M4 CTAM1
.400″ (10.16)
.800″ (20.32)
.200″ (5.08)
White
1000
.400″ (10.16)
.800″ (20.32)
.200″ (5.08)
Black
100
.400″ (10.16)
.800″ (20.32)
.200″ (5.08)
Black
1000
.400″ (10.16)
.800″ (20.32)
.200″ (5.08)
White
100
.400″ (10.16)
.800″ (20.32)
.200″ (5.08)
White
1000
.400″ (10.16)
.800″ (20.32)
.200″ (5.08)
Black
100
.400″ (10.16)
.800″ (20.32)
.200″ (5.08)
Black
1000
151-31103 CTAM110C2
151-31101 CTAM10C2
CTAM1
151-00287 CTAM10M4
CTAM1
151-31203 CTAM210C2
CTAM2
#8 screw
T18 - T50
151-31205 CTAM210M4 CTAM2
151-31201 CTAM20C2
CTAM2
151-31202 CTAM20M4
CTAM2
#10 screw
Cable Tie Anchor Plates
These plates have slotted mounting holes to provide for easier alignment of mount and bundles. Once aligned, they are
fastened securely by tightening the applied screw. The CTAP2 allows an additional screw for maximum stability. Both plates
are used perpendicularly to the wire bundle.
Material Data
Material
Operating
Temperature
-40 °F to +185 °F
Flammability
UL94 V2
File# E64139
Product Selection
Width (W)
Article No.
Part No.
Type
Cable Tie Series
in. (mm)
Color
CTAP1
.50″ (12.7)
1.34″ (34.04)
.15″ (3.81)
White
100
151-00288 CTAP110M4
CTAP1
.50″ (12.7)
1.34″ (34.04)
.15″ (3.81)
White
1000
151-00289 CTAP10C2
CTAP1
.50″ (12.7)
1.34″ (34.04)
.15″ (3.81)
Black
100
151-00290 CTAP10M4
CTAP1
.50″ (12.7)
1.34″ (34.04)
.15″ (3.81)
Black
1000
151-30200 CTAP210C2
CTAP2
.50″ (12.7)
2.13″
(54.1)
.14″
(3.5)
White
100
151-00308 CTAP210H4
CTAP2
.50″ (12.7)
2.13″
(54.1)
.14″
(3.5)
White
500
151-00291 CTAP20C2
CTAP2
.50″ (12.7)
2.13″
(54.1)
.14″
(3.5)
Black
100
151-00292 CTAP20M4
CTAP2
.50″ (12.7)
2.13″
(54.1)
.14″
(3.5)
Black
500
#10 screw
in. (mm)
in. (mm)
Height (H)
151-30100 CTAP110C2
T18 - T50
Mounting
Length (L)
Pkg. Qty.
63
Lashing Tie Mounts
The lashing tie mount is designed to snap into the T250 lashing tie. The tie
head is assembled perpendicular to the mount. The strap is parallel to the
mount when inserted into the head. The lashing tie mount is recommended
for indoor or outdoor wall mount cable applications.
Material Data
Material
Polyamide 6.6 UV-resistant (PA66UV)
Operating
Temperature
continuous
Flammability
UL94 V2
Product Selection
Width (W)
Article No.
Part No.
Type
151-00358 LTM2500C2
LTM250
151-00293 LTM2500H4
LTM250
T250
.25″ screw
in.
Length (L)
(mm)
in.
Height (H)
(mm)
Color
Pkg. Qty.
.733″ (18.62)
1.46″ (37.08)
(mm)
.378″ (9.60)
in.
Black
100
.733″ (18.62)
1.46″ (37.08)
.378″ (9.60)
Black
500
Masonry Mounts
Masonry mounts provide a permanent method of attaching wire and cable
to masonry surfaces. HellermannTyton’s masonry mounts simply tap into
predrilled holes and can be used for indoor and outdoor applications.
Material Data
Material
Operating
Temperature
continuous
Flammability
UL94 V2
Product Selection
Article No.
Part No.
Type
Cable
Tie
Series
Mounting
Hole Ø
in. (mm)
Min.
Depth
in.
(mm)
Length
(L)
in.
Width
(W)
(mm)
in. (mm)
Width
(W2)
in.
(mm)
Width
(W3)
in. (mm)
Pkg.
Qty.
151-29800 MMB00C2
MMB0
.188″ (4.7)
1.185″ (30.1)
.355″ (9.02) .218″ (5.54) .236″ (5.99)
Black
100
151-00325 MMB00M4
MMB0
.188″ (4.7)
1.185″ (30.1)
Black
1000
151-00116 MMB.50C2
MMB.5
1.244″ (31.60) .375″ (9.53) .220″ (5.59) .308″ (7.82)
Black
100
Black
1000
151-30001 MMB.50M4 MMB.5
T18 T50
.25″ (6.25)
1.0 ″ (25.4)
.25″ (6.25)
151-00326 MMB10C2
MMB1
.312″ (8.0)
151-00327 MMB10H4
MMB1
.312″ (8.0)
1.5″ (38.10)
1.71″ (43.49) .508″ (12.9) .374″ (9.50) .362″ (9.19)
Black
100
Black
500
64
Color
Cable Tie Mounting Plates
Allowing multiple cables to be run in parallel, these mounting
plates are secured with two screws. The cables are attached to
the mounting plate by using a cable tie through any combination
of the available slots.
Material Data
Material
Operating
Temperature
Color
Flammability
continuous
Natural
UL94 V2
Product Selection
Width (W)
Article No.
Part No.
Type
Cable Tie Series
Mounting
Length (L)
Height (H)
in.
(mm)
154-00000 MP1M3.NN3P
MP1M3
# 6 (M3) screw
.50″
(12.7)
1.75″
in. (mm)
(44.4)
.125″
in. (mm)
(3.2)
Pkg. Qty.
154-00100 MP1M5.NN3P
MP1M5
#10 (M5) screw
.50″
(12.7)
1.75″
(44.4)
.125″
(3.2)
100
151-24219 MP2M3.NN3P
MP2M3
# 6 (M3) screw
.50″
(12.7)
3.00″
(76.2)
.125″
(3.2)
100
100
154-00300 MP2M5.NN3P
MP2M5
#10 (M5) screw
.50″
(12.7)
3.00″
(76.2)
.125″
(3.2)
100
151-24319 MP3M3.NN3P
MP3M3
# 6 (M3) screw
.50″
(12.7)
4.25″ (108.0)
.125″
(3.2)
100
154-00500 MP3M5.NN3P
MP3M5
#10 (M5) screw
.50″
(12.7)
4.25″ (108.0)
.125″
(3.2)
100
151-24419 MP4M3.NN3P
MP4M3
# 6 (M3) screw
.50″
(12.7)
5.50″ (139.8)
.125″
(3.2)
100
154-00700 MP4M5.NN3P
MP4M5
#10 (M5) screw
.50″
(12.7)
5.50″ (139.8)
.125″
(3.2)
100
151-24519 MP5M3.NN3P
MP5M3
# 6 (M3) screw
.50″
(12.7)
6.75″ (171.6)
.125″
(3.2)
100
154-00900 MP5M5.NN3P
MP5M5
#10 (M5) screw
.50″
(12.7)
6.75″ (171.6)
.125″
(3.2)
100
T18 - T50
154-00018 MSMP5/69C2
MSMP5/6
# 6 (M3) screw
.618″
(15.7)
8.08″ (205.3)
.21″
(5.33)
100
154-01200 MSMP5/109C2
MSMP5/10
#10 (M5) screw .618″
(15.7)
8.08″ (205.3)
.21″
(5.33)
100
154-01302 MSMP6/69C2
MSMP6/7
# 6 (M3) screw
.618″
(15.7)
9.58″ (243.3)
.21″
(5.33)
100
154-01300 MSMP6/109C2
MSMP6/10
(15.7)
9.58″ (243.3)
.21″
(5.33)
100
65
很抱歉,暂时无法提供与“CTAM110C2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+3.60725100+0.46285
- 200+3.43427200+0.44066
- 300+3.33743300+0.42823
- 500+3.21891500+0.41303
- 700+3.14335700+0.40333
- 1000+3.065221000+0.39331
