CTAM20C2
Article Number: 151-31201
Cable Tie Anchor Mount, 0.2" Hole Dia., 0.2" Max Tie Width, PA66, Black, 100/pkg
Download spec sheet
Base Data
Local Order Number CTAM20C2
Type CTAM2
Color Black (BK)
Features and Benefits • 4-way entry allowing the cable tie to secure bundles running parallel or perpendicular.
• Secures with a single screw providing quick installation.
Product Description HellermannTyton cable tie anchor mounts are designed with a 4-way entry allowing the cable tie to secure bundles
running parallel or perpendicular. The mounts are installed quick and easy by securing a single screw.
Short Description Cable Tie Anchor Mount, 0.2" Hole Dia., 0.2" Max Tie Width, PA66, Black, 100/pkg
Product Dimensions
Length L (Imperial) 0.8 "
Length L (Metric) 20.4 mm
Fixation Method Screw Mounting and Rivet
Width W (Imperial) 0.4 "
Width W (Metric) 10.2 mm
Cable Tie Width Max. (Imperial) 0.2 "
Cable Tie Width Max. (Metric) 5.0 mm
Height H (Imperial) 0.2 "
Height H (Metric) 5.1 mm
Height H2 (Imperial) 0.05 "
Height H2 (Metric) 1.78 mm
Mounting Hole Diameter D (Imperial) 0.2 "
Mounting Hole Diameter D (Metric) 5.2 mm
Mounting Hole Diameter D Max. 5.2 mm
(Metric)
Mounting Hole Diameter D Min. (Metric)5.2 mm
Logistics and Packaging
Quantity Per bag
Package Quantity (Metric) 100
Carton Quantity 15000
Material and Specifications
Material Polyamide 6.6 (PA66)
Material Shortcut PA66
Flammability UL94 V2
Operating Temperature -40°F to +185°F (-40°C to +85°C)
ROHS Compliant Yes
Certification/Specification UL
UL Listed (US and Canada) No
UL Recognized (US and Canada) Yes
© HellermannTyton 2015
很抱歉,暂时无法提供与“CTAM20C2”相匹配的价格&库存,您可以联系我们找货
