H12P-N66-NA-M1
H12P-N66-NA-M1
    HELLERMAN(海尔曼太通)
H12P-N66-NA-M1 数据手册
Cable Ties and Fixings 1.9 Clips, Clamps and Plugs Plastic P-Clips HP-Series For permanent or semi-permanent cable fixings, this range of P-Clips can be used in a variety of industries. Their light weight form makes them particularly suitable for use in the aerospace industry where minimising weight, but retaining a strong fixing, is vitally important. Features and Benefits • Manufactured from Polyamide • Good temperature resistance and high strength • Wide range of sizes for every application P-Clips H1P - H18P in different dimensions. R WT F TYPE H1P H2P H3P H4P H5P H6P H7P H8P H9P H10P P-Clip H1P - H18P (plan view) Width (W) Wall (WT) Hole Ø (FH) Bundle Ø max. Fixing Hole Centres (F) Radius (R) Material Colour Article-No. 10.0 0.80 4.2 3.2 8.5 0.5 PA66 Natural (NA) 211-60019 10.0 0.80 4.2 3.2 8.5 0.5 PA66HS Black (BK) 211-60000 10.0 1.00 4.2 5.0 9.5 1.0 PA66 Natural (NA) 211-60029 211-60001 10.0 1.00 4.2 5.0 9.5 1.0 PA66HS Black (BK) 10.0 1.00 4.2 6.5 10.0 1.0 PA66 Natural (NA) 211-60039 10.0 1.00 4.2 6.5 10.0 1.0 PA66HS Black (BK) 211-60002 10.0 1.20 4.2 8.0 10.0 1.0 PA66 Natural (NA) 211-60049 10.0 1.20 4.2 8.0 10.0 1.0 PA66HS Black (BK) 211-60003 10.0 1.20 4.2 9.5 11.0 1.0 PA66 Natural (NA) 211-60059 10.0 1.20 4.2 9.5 11.0 1.0 PA66HS Black (BK) 211-60004 10.0 1.20 4.2 11.0 13.0 1.0 PA66 Natural (NA) 211-60069 10.0 1.20 4.2 11.0 13.0 1.0 PA66HS Black (BK) 211-60005 10.0 1.20 4.2 12.5 14.0 1.5 PA66 Natural (NA) 211-60079 10.0 1.20 4.2 12.5 14.0 1.5 PA66HS Black (BK) 211-60006 10.0 1.50 4.2 14.0 15.0 1.5 PA66 Natural (NA) 211-60089 10.0 1.50 4.2 14.0 15.0 1.5 PA66HS Black (BK) 211-60007 10.0 1.50 4.2 16.0 16.0 1.5 PA66 Natural (NA) 211-60099 10.0 1.50 4.2 16.0 16.0 1.5 PA66HS Black (BK) 211-60008 10.0 1.50 4.2 17.5 17.0 1.5 PA66 Natural (NA) 211-60109 10.0 1.50 4.2 17.5 17.0 1.5 PA66HS Black (BK) 211-60009 H11P 10.0 1.50 4.2 19.0 18.0 2.0 PA66 Natural (NA) 211-60119 H12P 10.0 1.50 4.2 20.5 19.0 2.0 PA66 Natural (NA) 211-60129 H13P 12.0 1.50 5.2 22.0 20.5 2.0 PA66 Natural (NA) 211-60139 H14P 12.0 1.50 5.2 24.0 21.5 2.0 PA66 Natural (NA) 211-60149 H15P 12.0 1.50 5.2 25.5 23.0 2.5 PA66 Natural (NA) 211-60159 H16P 12.0 1.50 5.2 28.5 24.0 2.5 PA66 Natural (NA) 211-60169 H17P 12.0 1.50 5.2 31.5 26.0 2.5 PA66 Natural (NA) 211-60179 H18P 12.0 1.50 5.2 35.0 27.5 2.5 PA66 Natural (NA) 211-60189 All dimensions in mm. Subject to technical changes. 178 Further information at www.HellermannTyton.com/fixings Date of issue: October 2015 P-Clip H1P - H18P (side view) Cable Ties and Fixings 1.0 Material Information Material Specification Overview Material Shortcut Operating Temperature Aluminium-alloy AL -40 °C to +180 °C Natural (NA) • Corrosion resistant • Antimagnetic Chloroprene CR -20 °C to +80 °C Black (BK) • Weather-resistant • High yield strength Ethylene Tetrafluoroethylene E/TFE -80 °C to +170 °C Blue (BU) UL94 V0 Polyacetal POM -40 °C to +90 °C, (+110 °C, 500 h) Natural (NA) UL94 HB Polyamide 11 PA11 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 HB Polyamide 12 PA12 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Good chemical resistance to: acids, bases, oxidizing agents • UV-resistant Polyamide 4.6 PA46 -40 °C to +150 °C (5000 h), +195 °C (500 h) Natural (NA), Grey (GY) UL94 V2 • Resistance to high temperatures • Very moisture sensitive • Low smoke sensitive Polyamide 6 PA6 -40 °C to +80 °C Black (BK) UL94 V2 • High yield strength PA6HIR -40 °C to +80 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature Polyamide 6.6 PA66 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK), Natural (NA) UL94 V2 • High yield strength Polyamide 6.6, PA66GF13, PA66GF15 -40 °C to +105 °C Black (BK) UL94 HB • Good resistance to: lubricants, vehicle fuel, salt water and many solvents PA66HSW -40 °C to +105 °C Black (BK) UL94 V2 • High yield strength • Modified elevated max. temperature • UV-resistant Polyamide 6.6, heat stabilised PA66HS -40 °C to +105 °C Black (BK), Natural (NA) UL94 V2 • High yield strength • Modified elevated max. temperature Polyamide 6.6, high impact modified PA66HIR -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL94 HB Polyamide 6.6, high impact modified, heat and UV stabilised PA66HIRHSW -40 °C to +110 °C Black (BK) UL94 HB Polyamide 6.6, high impact modified, heat stabilised PA66HIRHS -40 °C to +105 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature Polyamide 6.6, high impact modified, scan black PA66HIR(S) -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature PA66W -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 V2 • High yield strength • UV-resistant Polyamide 6, high impact modified glass-fibre reinforced Polyamide 6.6, heat and UV stabilised Polyamide 6.6, UV-resistant Colour** Material Properties* Flammability Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers. • Resistance to radioactivity • UV-resistant, not moisture sensitive • Good chemical resistance to: acids, bases, oxidizing agents • Limited brittleness sensitivity • Flexible at low temperature • Not moisture sensitive • Robust on impacts • Bio-plastic, derived from vegetable oil • Strong impact resistance at low temperature • Very low moisture absorption • Weather-resistant • Good chemical resistance • Limited brittleness sensitivity • Higher flexibility at low temperature • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature • High yield strength, UV-resistant **More colours on request. *These details are only rough guide values. They should be regarded as a material specification and are no substitute for a suitability test. Please see our datasheets for further details. HF = Halogenfree LFH = Limited Fire Hazard RoHS = Restriction of Hazardous Substances 24 Material Specifications Further information at www.HellermannTyton.com/fixings Date of issue: October 2015 MATERIAL Cable Ties and Fixings Material Information Material Shortcut Operating Temperature Polyamide 6.6, with metal particles PA66MP Polyamide 6.6 V0 MATERIAL Material Properties* Colour** Flammability -40 °C to +85 °C, (+105 °C, 500 h) Blue (BU) UL94 HB • High yield strength • Metal and X-Ray detectable PA66V0 -40 °C to +85 °C White (WH) UL94 V0 • High yield strength • Low smoke emission PA66V0-HOI -40 °C to +85 °C, (+105 °C, 500 h) White (WH) UL94 V0 • High yield strength • Low smoke emissions SP -50 °C to +150 °C Black (BK) Halogen free • UV-resistant • Good chemical resistance to: most acids, alkalis and oils PEEK -55 °C to +240 °C Beige (BGE) UL94 V0 • Resistance to radioactivity • Not moisture sensitive • Good chemical resistance to: acids, bases, oxidizing agents Polyethylene PE -40 °C to +50 °C Black (BK), Grey (GY) UL94 HB • Low moisture absorption • Good chemical resistance to: most acids, alcohol and oils Polyolefin PO -40 °C to +90 °C Black (BK) UL94 V0 • Low smoke emissions Polypropylene PP -40 °C to +115 °C Black (BK), Natural (NA) UL94 HB • Floats in water • Moderate yield strength • Good chemical resistance to: organic acids PP, EPDM -20 °C to +95 °C Black (BK) UL94 HB • Good resistance to high temperatures • Good chemical and abrasion resistance Polyamide 6.6 V0, High Oxygen Index Polyester Polyetheretherketone Polypropylene, EthylenePropylene-DienTerpolymere-rubber free of Nitrosamine Polypropylene with metal particles PPMP -40 °C to +115 °C Blue (BU) UL94 HB • Floats in certain liquids • Metal and X-Ray detectable • Heat resistant • Moderate yield strength • Good chemical resistance Polyvinylchloride PVC -10 °C to +70 °C Black (BK), Natural (NA) UL94 V0 • Low moisture absorption • Good chemical resistance to: acids, ethanol and oil Stainless Steel, Stainless Steel SS304, SS316 -80 °C to +538 °C Natural (NA) Non burning • Corrosion resistant • Antimagnetic • Weather resistant • Outstanding chemical resistance Thermoplastic Polyurethane TPU -40 °C to +85 °C Black (BK) UL94 HB • High elasticity • Good chemical resistance to: acids, bases and oxidizing agents Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers. 1.0 Material Specifications **More colours on request. Date of issue: October 2015 *These details are only rough guide values. They should be regarded as a material specification and are no substitute for a suitability test. Please see our datasheets for further details. HF = Halogenfree LFH = Limited Fire Hazard RoHS = Restriction of Hazardous Substances Further information at www.HellermannTyton.com/fixings 25
H12P-N66-NA-M1 价格&库存
很抱歉,暂时无法提供与“H12P-N66-NA-M1”相匹配的价格&库存,您可以联系我们找货
