Electrical Installation
4.1
Wire Connectors
Connectors
HelaCon Easy
The HelaCon Easy connectors are used for fast, easy and reliable
connection, distribution of cable and conductors in the field of electrical
installations within junction boxes and control panels.
Features and Benefits
• Fast, easy, reliable push-in wire connectors
• For connection and distribution of conductors in electrical housing
• Use typical range of voltages up to 450 volts
• Variety of input poles for flexible application
• Conductor sizes of: 0.5 up to 1.5 mm² and 1.0 up to 2.5 mm²
The compact design of HelaCon Easy fits perfectly in tight spaces.
One Step to the Web!
Polyamide (PA)
0.5 - 1.5 mm² solid
1.0 - 2.5 mm² solid
Max Current
17.5 A
24 A
Max Voltage
450 V
Stripping Length
11 mm
Flammability
UL94 V2
Operating
Temperature
-30 °C to +110 °C (VDE),
-30 °C to +105 °C (cULus)
Specifications
ENEC, FIMKO, VDE
CEBEC, cULus, ENEC,
FIMKO, KEMA-KEUR,
VDE
HelaCon Easy wire connector
front view
Wire Range
(VDE) in mm²
Number of
Conductors
Colour
Width
(W)
Height
(H)
Depth
(D)
Pack
Cont.
Article-No.
HECE-2
1.0 - 2.5 solid
2
Grey (GY)
10.5
9.5
19.5
100 pcs.
148-90006
HECE-3
1.0 - 2.5 solid
3
Grey (GY)
13.5
9.5
19.7
100 pcs.
148-90035
HECE-4
1.0 - 2.5 solid
4
Grey (GY)
17.2
9.5
19.7
100 pcs.
148-90008
TYPE
Drawing
All dimensions in mm. Subject to technical changes.
Minimum Order Quantity (MOQ) may differ from package content.
For product specific approvals and specifications please refer to the Appendix.
358
Further information at www.HellermannTyton.com/installation
Date of issue: October 2015
side view
MATERIAL
Wire Range (VDE)
4.1
Wire Connectors
Connectors
HelaCon Easy
Wire Range
(VDE) in mm²
Number of
Conductors
Colour
Width
(W)
Height
(H)
Depth
(D)
Pack
Cont.
Article-No.
HECE-5
1.0 - 2.5 solid
5
Grey (GY)
21.1
9.5
19.7
100 pcs.
148-90009
HECE-8
1.0 - 2.5 solid
8
Grey (GY)
17.8
14.5
17.8
50 pcs.
148-90010
HECE-3x1.5
0.5 - 1.5 solid
3
Grey (GY)
11.4
8.8
18.5
100 pcs.
148-90013
HECE-5x1.5
0.5 - 1.5 solid
5
Grey (GY)
17.2
8.8
18.5
100 pcs.
148-90015
HECE-8x1.5
0.5 - 1.5 solid
8
Grey (GY)
26.0
8.8
18.5
75 pcs.
148-90018
TYPE
Drawing
359
很抱歉,暂时无法提供与“148-90006”相匹配的价格&库存,您可以联系我们找货
