151-28359
    HELLERMAN(海尔曼太通)
151-28359 数据手册
Cable Ties and Fixings 1.7 Cable Tie Mounts Self Adhesive, Screw Fixing Cable Tie Mounts Where speed, simplicity and a firm fixing base are required these self adhesive clips are ideal. Particularly suitable for use in control cabinets, telecoms equipment or domestic appliances where the use of holes, screws, or nuts and bolts is impractical or undesirable. Features and benefits • Screwable or self-adhesive versions • Simple to install with a screw or bolt • Excellent security, particularly in areas of high vibration • Maximum surface area with adhesive to achieve high pull-off force • 4-way entry for cable tie for quicker and more flexible installation MB-Series square design, screwable MB-Series Mounts with square design / screwable, self adhesive. G F L H FH MB3-MB5 (side view) TYPE MB3 MB4 MB5 For more information on the types of adhesive please see page 130. W MB3-MB5 (plan view) Width (W) 19.0 28.0 37.7 Length (L) 19.0 28.0 37.7 Height (H) 3.8 4.7 6.2 Fixing Hole Centres (F) 13.2 20.0 25.3 Hole Ø (FH) 3.1 4.0 4.8 Strap Width max. (G) 4.1 5.4 8.9 Material PA66 PA66 PA66 Colour White (WH) White (WH) White (WH) Pack Cont. 100 pcs. 100 pcs. 100 pcs. Article-No. 151-28359 151-28479 151-00324 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. MB-Series square design, self adhesive, screwable G G H H L W Cable Tie Mount MB2A (side and plan view) TYPE MB2A MB3A MB4A3 Date of issue: January 2019 MB4A MB4CA* MB4CAS MB5A MB5A3 Width (W) 13.0 13.0 19.0 19.0 28.0 28.0 28.0 29.0 29.0 37.7 37.7 38.0 L W FH Cable Tie Mount MB4CA (side and plan view) Length (L) 13.0 13.0 19.0 19.0 28.0 28.0 28.0 29.0 29.0 37.7 37.7 38.0 Height (H) 4.1 4.1 3.8 3.8 4.7 4.7 4.7 5.7 5.7 7.1 7.1 6.4 Hole Ø (FH) 3.1 3.1 4.0 4.0 4.0 4.2 4.2 4.8 4.8 4.7 Cable Tie Mount MB3A in application Strap Width max. (G) 2.7 2.7 4.1 4.1 5.4 5.4 5.4 5.4 5.4 8.9 8.9 10.0 Material PA66 PA66 PA66 PA66 PA66 PA66 PA66 PA66 PA66 PA66 PA66 PA66 Colour Black (BK) White (WH) Black (BK) White (WH) Black (BK) Black (BK) White (WH) Natural (NA) Natural (NA) Black (BK) White (WH) Black (BK) Adhesive Synthetic rubber T60 Synthetic rubber T60 Synthetic rubber T60 Synthetic rubber T60 Acrylate Synthetic rubber T60 Synthetic rubber T60 Synthetic rubber T60 Synthetic rubber T60 Synthetic rubber T50 Synthetic rubber T50 Acrylate Pack Cont. 50 pcs. 100 pcs. 100 pcs. 100 pcs. 100 pcs. 100 pcs. 100 pcs. 100 pcs. 100 pcs. 100 pcs. 100 pcs. 100 pcs. Article-No. 151-01800 151-01802 151-28320 151-28349 151-28430 151-28412 151-28469 151-28459 151-28449 151-28602 151-28529 151-28530 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. * Plastic box For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.co.uk/fixings 135 Cable Ties and Fixings 1.0 Material Information Material Specification Overview Material Shortcut Operating Temperature Colour** Aluminium alloy AL -40 °C to +180 °C Natural (NA) • Corrosion resistant • Antimagnetic Chloroprene rubber CR -20 °C to +80 °C Black (BK) • Weather resistant • High yield strength Ethylene Tetrafluoroethylene (Tefzel®) E/TFE -80 °C to +170 °C Blue (BU) UL 94 V0 Polyacetal POM -40 °C to +90 °C, (+110 °C, 500 h) Natural (NA) UL 94 HB Polyamide 11 PA11 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL 94 HB Polyamide 12 PA12 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL 94 HB • Good chemical resistance to acids, bases, oxidizing agents • UV resistant Polyamide 4.6 PA46 -40 °C to +130 °C, Natural (NA), (+150 °C, 5000 h; Grey (GY) +195 °C, 500 h) UL 94 V2 • Resistance to high temperatures • Very moisture sensitive • Low smoke sensitivity Polyamide 6 PA6 -40 °C to +80 °C Black (BK) UL 94 V2 • High yield strength PA6HIR -40 °C to +80 °C Black (BK) UL 94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature PA66 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK), Natural (NA) UL 94 V2 • High yield strength Polyamide 6.6 glass-fibre reinforced PA66GF13, PA66GF15 -40 °C to +105 °C Black (BK) UL 94 HB • Good resistance to lubricants, fuels, salt water and solvents Polyamide 6.6 heat and UV stabilised PA66HSW -40 °C to +105 °C Black (BK) UL 94 V2 • High yield strength • Modified elevated maximum temperature • UV resistant Polyamide 6.6 heat stabilised PA66HS -40 °C to +105 °C Black (BK), Natural (NA) UL 94 V2 • High yield strength • Modified elevated maximum temperature Polyamide 6.6 high impact modified PA66HIR -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL 94 HB PA66HIRHSW -40 °C to +110 °C Black (BK) UL 94 HB Polyamide 6 high impact modified Polyamide 6.6 Polyamide 6.6 high impact modified, heat and UV stabilised Material Properties* Material Specifications • Resistance to radioactivity • UV resistant, not moisture sensitive • Good chemical resistance to acids, bases, oxidizing agents • Limited brittleness sensitivity • Flexible at low temperature • Not moisture sensitive • Robust on impact • Bio-plastic, derived from vegetable oil • Strong impact resistance at low temperature • Very low moisture absorption • Weather resistant • Good chemical resistance • Limited brittleness sensitivity • Higher flexibility at low temperature • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated maximum temperature • High yield strength, UV resistant • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated maximum temperature Polyamide 6.6 high impact modified, heat stabilised PA66HIRHS -40 °C to +105 °C Black (BK) UL 94 HB Polyamide 6.6 high impact modified, scan black PA66HIR(S) -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL 94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature PA66W -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL 94 V2 • High yield strength • UV resistant Polyamide 6.6 UV resistant 26 Flammability Further information at www.HellermannTyton.co.uk/fixings Date of issue: January 2019 MATERIAL Cable Ties and Fixings Material Information Material Shortcut Operating Temperature Polyamide 6.6 with metal particles PA66MP Polyamide 6.6 with metal particles Polyamide 6.6 V0 MATERIAL Colour** Flammability -40 °C to +85 °C, (+105 °C, 500 h) Blue (BU) UL 94 HB • High yield strength • Metal and X-Ray detectable PA66MP+ -40 °C to +85 °C Blue (BU) not flame retardant • High yield strength • Metal and X-Ray detectable PA66V0 -40 °C to +85 °C White (WH) UL 94 V0 • High yield strength • Low smoke emission SP -50 °C to +150 °C Black (BK) PEEK -55 °C to +240 °C Beige (BGE) UL 94 V0 • Resistance to radioactivity • Not moisture sensitive • Good chemical resistance to acids, bases, oxidising agents Polyethylene PE -40 °C to +50 °C Black (BK), Grey (GY) UL 94 HB • Low moisture absorption • Good chemical resistance to most acids, bases, alcohol, oils Polyolefin PO -40 °C to +90 °C Black (BK) UL 94 V0 • Low smoke emissions Polypropylene PP -40 °C to +115 °C Black (BK), Natural (NA) UL 94 HB • Floats in water • Moderate yield strength • Good chemical resistance to acids, bases and solvents PP, EPDM -20 °C to +95 °C Black (BK) UL 94 HB • Good resistance to high temperature • Good chemical and abrasion resistance Polypropylene with metal particles PPMP -40 °C to +115 °C Blue (BU) UL 94 HB • Metal and X-Ray detectable • Heat resistant • Moderate yield strength • Good chemical resistance Polypropylene with metal particles PPMP+ -40 °C to +85 °C Blue (BU) not flame retardant • High yield strength • Metal and X-Ray detectable Polyvinylchloride PVC -10 °C to +70 °C Black (BK), Natural (NA) Stainless Steel, Stainless Steel SS304, SS316 -80 °C to +538 °C Natural (NA) Thermoplastic Polyurethane TPU -40 °C to +85 °C Black (BK) Polyester Polyetheretherketone Polypropylene, Ethylene Propylene Diene Terpolymer rubber free of Nitrosamine Material Properties* 1.0 Material Specifications • UV resistant • Good chemical resistance to most acids, bases and oils • Low moisture absorption • Good chemical resistance to acids, bases, salts, alcohol, oils • Corrosion resistant • Antimagnetic • Weather resistant Non burning • Chemical resistance • SS316 also resistant against seawater, salt spray and anorganic acids UL 94 V0 UL 94 HB Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton also uses equivalent E/TFE raw material from other suppliers. • High elasticity • Good chemical resistance to acids, bases and oxidising agents **Further colours available on request. Date of issue: January 2019 *These details are only guide values. They should not be regarded as a exhaustive material specification and are no substitute for suitability tests. Please see our datasheets for further details. HF = Halogenfree LFH = Limited Fire Hazard RoHS = Restriction of Hazardous Substances Further information at www.HellermannTyton.co.uk/fixings 27
151-28359 价格&库存
很抱歉,暂时无法提供与“151-28359”相匹配的价格&库存,您可以联系我们找货
  • 10+3.69162
  • 40+2.98612
  • 100+2.97414
  • 110+2.82321
库存:280
151-28359
  • 10+3.6218710+0.43279
  • 50+3.2152450+0.38420
  • 100+2.91263100+0.34804
库存:280
