Specification Sheet
Part Number: 156-00862
Outside Serrated Cable Tie & Edge Clip, 8.0" Long, EC5B, 1–3 mm Panel, 50lb, PA66HS, Black, 500/pkg
Article Number
156-00862
Type
T50ROSEC5B
Color
Black (BK)
Features & Benefits
•Edge Clip applies easily to plastic and metal sheets without the need for a
mounting hole. •Edge Clip provides low insertion force and high extraction
force ideal for assembly environments. •Two piece assembly allows the mount
to slide along the strap ensuring proper orientation. •Cable tie is outside
serrated to reduce bundle chafing.
Quantity Per
bag
Product Description
HellermannTyton's Two Piece Edge Clip with Cable Tie Assemblies are
designed specifically to route bundles by securing them to the edge of a plastic
or metal sheet without the need for a mountinig hole. The clip is easy to
secure and the extraction force is high due to the integrated metal clamp that
holds the edge clip in place.
Short Description
Global Part Name
T50ROSEC5B-PA66HS/PA66HIRHS-BK
Minimum Tensile Strength (Imperial)
50.0
Minimum Tensile Strength (Metric)
225
Length L (Imperial)
8.0
Length L (Metric)
202.0
Fixation Method
EdgeClip, sideway, assembled, 2 piece
Identification Plate Position
none
Releasable Closure
No
Variant
Outside Serrated
Width W (Imperial)
0.18
Width W (Metric)
4.6
Bundle Diameter Min (Imperial)
0.20
Bundle Diameter Min (Metric)
5.0
Bundle Diameter Max (Imperial)
2.0
Bundle Diameter Max (Metric)
50.0
Thickness T (Imperial)
0.05
Thickness T (Metric)
1.2
Height H (Imperial)
.05
Height H (Metric)
1.30
Panel Thickness Min(Imperial)
0.04
Panel Thickness Max(Imperial)
0.12
Panel Thickness Min (Metric)
1.0
Panel Thickness Max (Metric)
3.0
Material
Polyamide 6.6, high impact modified, heat stabilized (PA66HIRHS) Polyamide
6.6 heat stabilized (PA66HS)
Material Shortcut
PA66HS PA66HIRHS
Material Cable Tie
Polyamide 6.6 heat stabilized (PA66HS)
Flammability
UL 94 HB
Operating Temperature (Metric)
-40°F to +221°F (-40°C to +105°C) -40°F to +230°F (-40°C to +110°C)
ROHS Complaint
Yes
Package Quantity(Imperial)
500
Package Quantity (Metric)
500
Customs Number
3926909987
Weight (Metric)
4.5
© 2018 HellermannTyton. All rights reserved.
Contact Us RoHS/WEEE Compliance Disclaimer Terms and Conditions
很抱歉,暂时无法提供与“156-00862”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+9.51397500+1.22913
