Insulation
2.1
Heat Shrinkable Tubing
Heat Shrinkable Tubing 2:1 - PVDF
TK20
Typical applications of this translucent tubing are where hightemperature performance is required. Also very suitable for applications
that ask for visual inspection of covered components, or if a low friction
surface is needed. TK20 is also used as oil stop for energy cables.
This thin walled, translucent heat shrink tubing is often used for
chemical applications.
Features and Benefits
• Semi-rigid heat shrinkable tubing made of PVDF
• Thin walled and tough
• For higher temperature applications
• Very good mechanical strength, abrasion resistance and
chemical resistance
• Meets various industrial standards
• Self extinguishing, UL 224 VW1 listed
This thin walled, translucent heat shrink tubing is often used for chemical
applications.
Detailed Information about
Heatguns please refer to page 529.
MATERIAL
Polyvinylidene Fluoride (PVDF)
Shrink Ratio
2:1
Operating Temperature
-55 °C to +175 °C
Minimum Shrink
Temperature
+175 °C
Longitudinal change
after shrinkage
+/-10 % max
Dielectric Strength
≥ 30 kV/mm min. according to ASTM
D2171
Flammability
UL224 VW-1
Specifications
ASN-E0718, NSA937494, PAN6491,
SAE - AMS - DTL-23053 / 8,
UL224 150 °C 600V VW-1, VG 95343
L
Supplied
Ø D min.
Size
(imperial)
Recov.
Ø d max.
Wall
(WT)
Length
(L)
Colour
Designation as per
VG-Norm
Article-No.
TK20-1.2/0.6
1.2
3/64 "
0.6
0.25
1.2 m
Transparent (CL)
VG95343T05F001M
331-00129
TK20-1.6/0.8
1.6
1/16 "
0.8
0.25
1.2 m
Transparent (CL)
VG95343T05F002M
311-00169
TK20-2.4/1.2
2.4
3/32 "
1.2
0.25
1.2 m
Transparent (CL)
VG95343T05F003M
311-00249
TK20-3.2/1.6
3.2
1/8 "
1.6
0.25
1.2 m
Transparent (CL)
VG95343T05F004M
311-00329
TK20-4.8/2.4
4.8
3/16 "
2.4
0.25
1.2 m
Transparent (CL)
VG95343T05F005M
311-00489
TK20-6.4/3.2
6.4
1/4 "
3.2
0.30
1.2 m
Transparent (CL)
VG95343T05F006M
311-00649
TK20-9.5/4.8
9.5
3/8 "
4.8
0.30
1.2 m
Transparent (CL)
VG95343T05F007M
311-00959
TK20-12.7/6.4
12.7
1/2 "
6.4
0.30
1.2 m
Transparent (CL)
VG95343T05F008M
311-01279
TK20-19.1/9.5
19.1
3/4 "
9.5
0.43
1.2 m
Transparent (CL)
VG95343T05F009M
311-01909
TK20-25.4/12.7
25.4
1"
12.7
0.48
1.2 m
Transparent (CL)
VG95343T05F010M
311-02549
TK20-38.1/19.1
38.1
1-1/2 "
19.1
0.51
1.2 m
Transparent (CL)
311-03819
TK20-50.8/25.4
50.8
2"
25.4
0.51
1.2 m
Transparent (CL)
311-05089
TYPE
All dimensions in mm. Subject to technical changes.
Minimum Order Quantity (MOQ) may differ from package content.
ASN
240
For product specific approvals and specifications please refer to
the Appendix.
Further information at www.HellermannTyton.com/insulation
Date of issue: October 2015
很抱歉,暂时无法提供与“311-00959”相匹配的价格&库存,您可以联系我们找货
