Insulation
Heat Shrinkable Tubing
2.1
Heat Shrinkable Tubing 6:1, adhesive lined
in 1 m cuts
HA67
Insulates, seals and protects large size differences between connectors
and cables.
Features and Benefits
• High shrink ratio, heavy-duty heat shrinkable tubing
• Thermoplastic adhesive-lined tubing
• Conforms well to highly variable substrate dimensions
• Simplifies cable repair
• Passes over large connectors and shrinks onto much smaller
cable jackets
• Environmental sealing and excellent insulation
• Resistant to impact and abrasion
One Step to the Web!
Due to the high shrink ratio HA67 is suitable for complex shapes and dimensions.
MATERIAL
Polyolefin, cross-linked (PO-X)
Shrink Ratio
6:1
Operating Temperature
-55 °C to +110 °C
Minimum Shrink
Temperature
+120 °C
Softening Point Adhesive
+85 °C
Longitudinal change
after shrinkage
-10 % max.
Dielectric Strength
20kV/mm according to ASTM D2671
Flammability
not flame retarded
L
Heat Shrinkable Tubing 6:1 with adhesive
Supplied
Ø D min.
Recov.
Ø d max.
Wall
(WT)
Length
(L)
Colour
Article-No.
19.0
3.2
3.20
1,220.0
Black (BK)
321-30000
HA67-33.0/5.5
33.0
5.5
3.40
1,220.0
Black (BK)
321-30100
HA67-44.4/7.4
44.4
7.4
3.60
1,220.0
Black (BK)
321-30200
TYPE
HA67-19.0/3.2
HA67-50.8/8.3
50.8
8.3
4.80
1,220.0
Black (BK)
321-30300
HA67-69.8/11.7
69.8
11.7
4.80
1,220.0
Black (BK)
321-30400
HA67-88.9/17.1
88.9
17.1
4.80
1,220.0
Black (BK)
321-30500
HA67-119.4/22.9
119.4
22.9
4.80
1,220.0
Black (BK)
321-30600
HA67-235.0/40.0
235.0
40.0
4.80
1,220.0
Black (BK)
321-30700
Date of issue: October 2015
All dimensions in mm. Subject to technical changes.
Minimum Order Quantity (MOQ) may differ from package content.
Further information at www.HellermannTyton.com/insulation
233
很抱歉,暂时无法提供与“321-30400”相匹配的价格&库存,您可以联系我们找货
