318-60150
318-60150
    HELLERMAN(海尔曼太通)
318-60150 数据手册
318-60150 Article Number: 318-60150 Heat Shrink Tubing, 4FT-Stick, Adhesive Lined, 3:1, 1/8", 3.0/1.0 dia., Polyolefin, Black, 20/pkg Download spec sheet Base Data Local Order Number 318-60150 Type TAN33-ST-3/1 BK Color Black (BK) Features and Benefits • Adhesive lining provides an excellent seal against moisture and humidity. • 3 to 1 shrink ratio accommodates a wide range of component shapes and diameters, while thin exterior wall is very flexible and provides superior insulation. • Meets UL224 VW-1 specifications making it ideal high heat applications (excludes clear tubing). • Polyolefin material provides mechanical strength with good resistance to solvents, oils and fuels. Product Description TAN33 is a flexible, thin wall adhesive lined heat shrink tubing with highly flame retardant properties. The 3 to 1 shrink ratio accommodates a wide range of component shapes and diameters. The adhesive lining begins to activate as the temperature reaches 176° F (80° C), to create a strong seal against moisture and humidity. 4-foot sticks are individually labeled for retail. Short Description Heat Shrink Tubing, 4FT-Stick, Adhesive Lined, 3:1, 1/8", 3.0/1.0 dia., Polyolefin, Black, 20/pkg Product Dimensions Length L (Imperial) 4.0 ft Length L (Metric) 1.22 m Printable (Yes/No) No Shrink Ratio 3:1 Tensile Strength (MPa) 10 MPa Trade Size 1/8 " Variant Thin-Wall Volume Resistance (Ohm cm) 10¹ Ω cm Nominal Diameter (Imperial) 1/8 " Nominal Diameter (Metric) 3 mm Wall Thickness WT (Imperial) 0.039 " Wall Thickness WT (Metric) 1.00 mm Recovered Diameter d (metric) 1.0 mm Recovered Diameter d (imperial) 0.039 " Supplied Diameter D (imperial) 0.112 " Supplied Diameter D (metric) 3 mm Logistics and Packaging Quantity Per pack Package Quantity 20 Package Quantity (Metric) 20 Material and Specifications Material Polyolefin, cross-linked (PO-X) Material Shortcut PO-X Elongation at break 400% Halogenfree No Shrink Temperature +212 °F (+100 °C) Operating Temperature -67°F to +257°F (-55°C to +125°C) ROHS Compliant Yes UL Recognized (US) Yes © HellermannTyton 2015
318-60150 价格&库存
很抱歉,暂时无法提供与“318-60150”相匹配的价格&库存,您可以联系我们找货
  • 1600+19.940811600+2.58304
