321-50014
Article Number: 321-50014
Heat Shrink Tubing, 4FT Stick, Thick Wall Adhesive Lined, Up to 3.5:1, 2", 51/16 dia, Polyolefin, Black, 2/pkg
Download spec sheet
Base Data
Local Order Number 321-50014
Type TREDUX HA47-48ST-51/16
Color Black (BK)
Features and Benefits • Tubing is 3.5:1, thick wall adhesive lined.
• Toughness and weatherability is ideal for low and medium voltage power applications.
• Available in 3.28' (1.0 m) lengths, multiple diameters and 1 color (black).
• Conveniently packed in a display carton.
Product Description TREDUX HA47 thick wall heat shrink tubing has a adhesive liner that provides good moisture sealing and weather
protection suitable for insulation and protection of low and medium voltage power applications. HA47 is tough and the
weatherability makes it suitable for exposed applications and underground cable joints. Polyolefin material is pre-cut
into 3.28' (1.0m) sticks and stored in a convenient display box. RoHS approved and Halogen free.
Short Description Heat Shrink Tubing, 4FT Stick, Thick Wall Adhesive Lined, Up to 3.5:1, 2", 51/16 dia, Polyolefin, Black, 2/pkg
Product Dimensions
Length L (Imperial) 4.0 ft
Length L (Metric) 1.0 m
Printable (Yes/No) No
Shrink Ratio up to 3.5:1
Tensile Strength (MPa) 14 MPa
Trade Size 2 "
Variant Thick-Wall
Voltage Range Low and Medium Voltage
Volume Resistance (Ohm cm) 10¹ Ω cm
Nominal Diameter (Imperial) 2 "
Nominal Diameter (Metric) 51 mm
Wall Thickness WT (Imperial) 0.161 "
Wall Thickness WT (Metric) 4.1 mm
Recovered Diameter d (metric) 16.0 mm
Recovered Diameter d (imperial) 0.63 "
Supplied Diameter D (imperial) 2.008 "
Supplied Diameter D (metric) 51.0 mm
Logistics and Packaging
Quantity Per pieces
Package Quantity (Metric) 2 Pieces
Weight (imperial) 3.29
Weight (Metric) 1.49 kg
Material and Specifications
Material Polyolefin, cross-linked (PO-X)
Material Shortcut PO-X
Adhesive Hot melt adhesive
Dielectric Strength (Metric) 20 kV/mm
Elongation at break 400%
Flammability not flame retardant
Halogenfree Yes
Shrink Temperature +248 °F (+120 °C)
Operating Temperature -67°F to +230°F (-55°C to +110°C)
ROHS Compliant Yes
UL Listed (US) No
UL Recognized (US) No
© HellermannTyton 2015
很抱歉,暂时无法提供与“321-50014”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2+303.216202+39.30260
