323-50016
323-50016
    HELLERMAN(海尔曼太通)
    HEATSHRINK4:175MMX1M
323-50016 数据手册
323-50016 Article Number: 323-50016 Heat Shrink Tubing, 4FT Stick, Medium Wall Adhesive Lined, Up to 4:1, 3", 75/22 dia, Polyolefin, Black, 2/pkg Download spec sheet Base Data Local Order Number 323-50016 Type TREDUX MA47-48ST-75/22 Color Black (BK) Features and Benefits • Medium wall tubing resists solvents, acids and alkaline solutions while providing good mechanical strength. • Features robust insulation characteristics designed for low voltage power applications. • Adhesive lining provides excellent insulation against moisture and humidity. • RoHS compliant and Halogen-free. Product Description MA47 is a medium wall heat shrink tubing with an adhesive lining for use in low voltage applications. The thermoplastic adhesive liner provides excellent moisture sealing and insulation protection of cable joints and terminations. Made of a polyolefin outer material, this tubing has a shrink ratio up to 4 to 1. The adhesive lining begins to activate as the temperature approaches 185° F (85° C). Individually labeled 4-foot sticks come packaged in a retail display box. Short Description Heat Shrink Tubing, 4FT Stick, Medium Wall Adhesive Lined, Up to 4:1, 3", 75/22 dia, Polyolefin, Black, 2/pkg Product Dimensions Length L (Imperial) 4.0 ft Length L (Metric) 1.0 m Printable (Yes/No) No Shrink Ratio up to 4:1 Tensile Strength (MPa) 14 MPa Trade Size 3 " Variant Medium-Wall Voltage Range Low and medium voltage Volume Resistance (Ohm cm) 10¹ Ω cm Nominal Diameter (Imperial) 3 " Nominal Diameter (Metric) 75 mm Wall Thickness WT (Imperial) 0.12 " Wall Thickness WT (Metric) 3.0 mm Recovered Diameter d (metric) 22.0 mm Recovered Diameter d (imperial) 0.86 " Supplied Diameter D (imperial) 2.95 " Supplied Diameter D (metric) 75.0 mm Logistics and Packaging Quantity Per pieces Package Quantity 2 Package Quantity (Metric) 2 Pieces Weight (imperial) 2.54 Weight (Metric) 1.15 kg Material and Specifications Material Polyolefin, cross-linked (PO-X) Material Shortcut PO-X Adhesive Hot melt adhesive Dielectric Strength (Metric) 20 kV/mm Elongation at break 400% Flammability not flame retardant Halogenfree Yes Shrink Temperature +248 °F (+120 °C) Operating Temperature -67°F to +230°F (-55°C to +110°C) ROHS Compliant Yes © HellermannTyton 2015
323-50016 价格&库存
很抱歉,暂时无法提供与“323-50016”相匹配的价格&库存,您可以联系我们找货
