Application Tooling
Application Tooling for Cable Ties
6.2
Manual Tensioning Tool for Cable ties with
low profile head
MK10-SB up to 9.5 mm strap width
Features and Benefits
• Ideal for easy handling of entire HellermannTyton RPE and
PE-Series cable ties
• Tensions and cuts off pre-looped cable ties flush at the head
MK10-SB.
TYPE
Strap Width
max. (G)
Strap Thickness
max.
Weight
Article-No.
9.5
2.5
0.33 kg
110-10001
MK10-SB
All dimensions in mm. Subject to technical changes.
For product specific approvals and specifications please refer to the Appendix.
Manual Tensioning Tool for Cable Ties,
simple version
MK20 up to 4.8 mm strap width
MK21 up to 7.6 mm strap width
• Lightweight, ergonomic tools
• For tensioning and cutting HellermannTyton standard cable ties
4.8 - 7.6 mm wide
• MK20 and MK21 ideal for on-site assembly
• Mounted and pre-tensioned ties are cut off by twisting the tool
Date of issue: October 2015
MK20, MK21.
Apply.
Tension.
Twist to cut.
TYPE
Strap Width
max. (G)
Strap Thickness
max.
Weight
Article-No.
MK20
4.8
1.5
0.05 kg
110-20006
MK21
7.6
2.5
0.05 kg
110-21016
Further information at www.HellermannTyton.com/tools
513
很抱歉,暂时无法提供与“110-20016”相匹配的价格&库存,您可以联系我们找货
