166-90332
166-90332
    HELLERMAN(海尔曼太通)
    HELAGUARD-NON-METALLICIP66FI
166-90332 数据手册
166-90332 Article Number: 166-90332 Description: HelaGuard Non-Metallic IP66 Fitting, 90-Elbow, 1/2" NPT Thread, 0.38" Dia, PA66, Black, 10/pkg Base Data Local Order Number 166-90332 Type HG038-90-0500 Color Black (BK) Features and benefits ‡External NPT thread provides a secure connection. ‡Snap-on construction reduces installation time and costs by eliminating the need to thread fittings onto conduits. ‡Elbow features a smooth, swept bore to ease cable installation. ‡All-around "teeth" attach firmly to conduit and deliver a high extraction force. ‡Durable nylon material has high resistance to salts, oils, weak acids and solvents. ‡IP66 fitting has one-piece construction. ‡IP68 fitting has additional conduit seal for increased protection against wind, dirt and water. Quantity Per bag Product Description Elbow fitting features a snap-on design that provides a quick, secure connection. Constructed of a very durable nylon material with a high resistance to salts, oils, weak acids and solvents. Designed for easy removal with a small screwdriver. Choose from IP66 or IP68 ingress protection rated fittings. Short Description HelaGuard Non-Metallic IP66 Fitting, 90-Elbow, 1/2" NPT Thread, 0.38" Dia, PA66, Black, 10/pkg Length L (Imperial) 2.01" Length L (Metric) 51mm Outside Diameter D (imperial) 1.14" Outside Diameter D (metric) 29mm Nominal Diameter (Imperial) 3/8" Nominal Diameter (Metric) 16mm Material Polyamide 6.6 (PA66) Material Shortcut PA66 Flammability UL 94 V2 Product Dimensions Material and Specifications generated on: 5/10/2017 166-90332 Material and Specifications Operating Temperature -58°F to +275°F (-50°C to +135°C) Package Quantity (Imperial) 10 Package Quantity (Metric) 10Pieces Customs Number(Schedule B) 3926909987 Logistic and Packaging generated on: 5/10/2017
166-90332 价格&库存
很抱歉,暂时无法提供与“166-90332”相匹配的价格&库存,您可以联系我们找货
