308-11803
308-11803
    HELLERMAN(海尔曼太通)
    HELLERMANNTYTON - 308-11803 - Adhesive Lined Heat Shrink Tubing, Dual Wall, PO-X, 3:1, 0.709 ", 18 m...
308-11803 数据手册
Insulation 2.1 Heat Shrinkable Tubing Heat Shrinkable Tubing 3:1 on a Reel HIS-A - with adhesive liner HIS-A forms a seal against moisture and protect against corrosion and mechanical abrasion. Features and Benefits • Adhesive lined heat shrink tubing • Inner wall melts when heated and is forced into gaps • Adhesive forms seal against moisture as tubing cools • Protects components • Available in black and transparent • 6 sizes for wide range of applications HIS-A - with adhesive liner Detailed Information about Heatguns please refer to page 529. MATERIAL Polyolefin, cross-linked (PO-X) Shrink Ratio 3:1 Operating Temperature -55 °C to +125 °C Minimum Shrink Temperature +100 °C Longitudinal change after shrinkage -10 % max. Softening Point Adhesive +85 °C Dielectric Strength 15 kV/mm according to IEC 60684 P2 Flammability UL224 VW-1 (except clear) Insulation Class A (VDE 0530) Specifications CSA, SAE - AMS - DTL-23053 / 4 , UL224 125 °C 600V VW-1 TYPE HIS-A-3/1 HIS-A-6/2 HIS-A-9/3 HIS-A-12/4 HIS-A-18/6 HIS-A-24/8 Supplied Ø D min. Recov. Ø d max. Wall (WT) Reel Length 3.0 1.0 1.00 3.0 1.0 1.00 6.0 2.0 1.00 6.0 2.0 1.00 9.0 3.0 1.40 9.0 3.0 1.40 12.0 4.0 1.80 Colour Article-No. 10 m Black (BK) 308-10300 10 m Transparent (CL) 308-10303 5m Black (BK) 308-10600 5m Transparent (CL) 308-10603 5m Black (BK) 308-10900 5m Transparent (CL) 308-10903 5m Black (BK) 308-11200 12.0 4.0 1.80 5m Transparent (CL) 308-11203 18.0 6.0 2.25 4m Black (BK) 308-11800 18.0 6.0 2.25 4m Transparent (CL) 308-11803 24.0 8.0 2.50 3m Black (BK) 308-12400 24.0 8.0 2.50 3m Transparent (CL) 308-12403 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. For product specific approvals and specifications please refer to the Appendix. 198 Further information at www.HellermannTyton.com/insulation Date of issue: October 2015 Heat Shrinkable Tubing 3:1 with adhesive
308-11803 价格&库存
很抱歉,暂时无法提供与“308-11803”相匹配的价格&库存,您可以联系我们找货
