Insulation
2.1
Heat Shrinkable Tubing
Heat Shrinkable Tubing 3:1 on a Reel
HIS-A - with adhesive liner
HIS-A forms a seal against moisture and protect against corrosion and
mechanical abrasion.
Features and Benefits
• Adhesive lined heat shrink tubing
• Inner wall melts when heated and is forced into gaps
• Adhesive forms seal against moisture as tubing cools
• Protects components
• Available in black and transparent
• 6 sizes for wide range of applications
Detailed Information about
Heatguns please refer to page 529.
MATERIAL
Polyolefin, cross-linked (PO-X)
Shrink Ratio
3:1
Operating Temperature
-55 °C to +125 °C
Minimum Shrink
Temperature
+100 °C
Longitudinal change
after shrinkage
-10 % max.
Softening Point
Adhesive
+85 °C
Dielectric Strength
15 kV/mm according to IEC 60684 P2
Flammability
UL224 VW-1 (except clear)
Insulation Class
A (VDE 0530)
Specifications
CSA, SAE - AMS - DTL-23053 / 4 , UL224
125 °C 600V VW-1
TYPE
HIS-A-3/1
HIS-A-6/2
HIS-A-9/3
HIS-A-12/4
HIS-A-18/6
HIS-A-24/8
Supplied
Ø D min.
Recov.
Ø d max.
Wall
(WT)
Reel
Length
3.0
1.0
1.00
3.0
1.0
1.00
6.0
2.0
1.00
6.0
2.0
1.00
9.0
3.0
1.40
9.0
3.0
1.40
12.0
4.0
1.80
Colour
Article-No.
10 m
Black (BK)
308-10300
10 m
Transparent (CL)
308-10303
5m
Black (BK)
308-10600
5m
Transparent (CL)
308-10603
5m
Black (BK)
308-10900
5m
Transparent (CL)
308-10903
5m
Black (BK)
308-11200
12.0
4.0
1.80
5m
Transparent (CL)
308-11203
18.0
6.0
2.25
4m
Black (BK)
308-11800
18.0
6.0
2.25
4m
Transparent (CL)
308-11803
24.0
8.0
2.50
3m
Black (BK)
308-12400
24.0
8.0
2.50
3m
Transparent (CL)
308-12403
All dimensions in mm. Subject to technical changes.
Minimum Order Quantity (MOQ) may differ from package content.
For product specific approvals and specifications please refer to the Appendix.
198
Further information at www.HellermannTyton.com/insulation
Date of issue: October 2015
Heat Shrinkable Tubing 3:1 with adhesive
很抱歉,暂时无法提供与“308-12400”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+252.53217
- 2+238.75747
