Insulation
Heat Shrinkable Tubing
2.1
Heat Shrinkable Tubing 3:1 on a Reel
HIS-3
HIS-3 is used in general purpose of electrical insulation with a high level
of protection against corrosion and mechanical abrasion.
Features and Benefits
• Unlined tubing in handly dispenser packs
• High shrink ratio (3:1) tubing
• Fits highly variable substrate dimensions
• Only 6 sizes for application diameter range of 1 mm up to 20 mm,
reduce inventory by half
HIS-3 can fit highly variable substrate dimensions.
Detailed Information about
Heatguns please refer to page 529.
One Step to the Web!
MATERIAL
Polyolefin, cross-linked (PO-X)
Shrink Ratio
3:1
Operating Temperature
-55 °C to +135 °C
Minimum Shrink
Temperature
+100 °C
Longitudinal change
after shrinkage
-5 % max.
Dielectric Strength
20 kV/mm according to ASTM D 150
Flammability
UL224 VW-1 (except clear)
Insulation Class
B (VDE 0530)
Specifications
CSA, SAE - AMS - DTL-23053/5 Class 1
and 3, SAE - AMS - DTL-23053/5 Class 2
(clear), UL224 125 °C 600V VW-1
TYPE
HIS-3-1.5/0.5
Date of issue: October 2015
HIS-3-3/1
HIS-3-6/2
Supplied
Ø D min.
Recov.
Ø d max.
Wall
(WT)
Reel
Length
Colour
Article-No.
1.5
0.5
0.45
10 m
Black (BK)
308-30150
1.5
0.5
0.45
10 m
Blue (BU)
308-30156
1.5
0.5
0.45
10 m
Red (RD)
308-30152
1.5
0.5
0.45
10 m
Transparent (CL)
308-30153
3.0
1.0
0.55
10 m
Black (BK)
308-30300
3.0
1.0
0.55
10 m
Blue (BU)
308-30306
3.0
1.0
0.55
10 m
Green-Yellow (GNYE)
308-30307
3.0
1.0
0.55
10 m
Red (RD)
308-30302
3.0
1.0
0.55
10 m
Transparent (CL)
308-30303
6.0
2.0
0.65
5m
Black (BK)
308-30600
6.0
2.0
0.65
5m
Blue (BU)
308-30606
6.0
2.0
0.65
5m
Green-Yellow (GNYE)
308-30607
6.0
2.0
0.65
5m
Red (RD)
308-30602
6.0
2.0
0.65
5m
Transparent (CL)
308-30603
All dimensions in mm. Subject to technical changes.
Minimum Order Quantity (MOQ) may differ from package content.
For product specific approvals and specifications please refer to the Appendix.
Further information at www.HellermannTyton.com/insulation
203
Insulation
2.1
HIS-3
TYPE
HIS-3-9/3
HIS-3-12/4
HIS-3-18/6
HIS-3-24/8
Supplied
Ø D min.
Recov.
Ø d max.
Wall
(WT)
Reel
Length
Colour
Article-No.
9.0
3.0
0.75
5m
Black (BK)
308-30900
9.0
3.0
0.75
5m
Blue (BU)
308-30906
9.0
3.0
0.75
5m
Green-Yellow (GNYE)
308-30907
9.0
3.0
0.75
5m
Red (RD)
308-30902
9.0
3.0
0.75
5m
Transparent (CL)
308-30903
12.0
4.0
0.80
5m
Black (BK)
308-31200
12.0
4.0
0.80
5m
Blue (BU)
308-31206
12.0
4.0
0.80
5m
Green-Yellow (GNYE)
308-31207
12.0
4.0
0.80
5m
Red (RD)
308-31202
12.0
4.0
0.80
5m
Transparent (CL)
308-31203
18.0
6.0
0.90
4m
Black (BK)
308-31800
18.0
6.0
0.90
4m
Blue (BU)
308-31806
18.0
6.0
0.90
4m
Green-Yellow (GNYE)
308-31807
18.0
6.0
0.90
4m
Red (RD)
308-31802
18.0
6.0
0.90
4m
Transparent (CL)
308-31803
24.0
8.0
1.20
3m
Black (BK)
308-32400
24.0
8.0
1.20
3m
Blue (BU)
308-32406
24.0
8.0
1.20
3m
Green-Yellow (GNYE)
308-32407
24.0
8.0
1.20
3m
Red (RD)
308-32402
24.0
8.0
1.20
3m
Transparent (CL)
308-32403
204
很抱歉,暂时无法提供与“308-30602”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+396.832601+51.40370
- 3+357.053383+46.25090
- 5+297.646265+38.55560
