309-32543
309-32543
    HELLERMAN(海尔曼太通)
    Heat Shrink Tubing, Flexible, 2:1, 1 ", 25.4 mm, Transparent, 164 ft, 50 m
309-32543 数据手册
Insulation 2.1 Heat Shrinkable Tubing Heat Shrinkable Tubing 2:1 flexible and transparent TF24 Protects wire and cable markers subject to abuse, while permitting inspectability of each item covered. Protects electronic components while permitting their identification and inspection. Features and Benefits • Transparent, flexible polyolefin tubing • Protects identification marking perfect • Halogen free • Good mechanical and chemical resistance • VG-approval and additional industrial approvals TF24 transparent tubing with 2:1 shrink ratio. Cut lengths available on request. Please contact us! One Step to the Web! MATERIAL Polyolefin, cross-linked (PO-X) Shrink Ratio 2:1 Operating Temperature -55 °C to +135 °C Minimum Shrink Temperature +110 °C Longitudinal change after shrinkage +/-5 % max. Dielectric Strength ≥ 30 kV/mm min. according to ASTM D2171 Flammability not flame retarded Specifications DEF STAN 59-97 Type 2B, SAE - AMS DTL-23053/5 Class 2, VG 95343 Heat Shrinkable Tubing 2:1 Supplied Ø D min. Size (imperial) Recov. Ø d max. Wall (WT) Reel Length Colour Designation as per VG-Norm TF24-1.2/0.6 1.2 3/64 " 0.6 0.41 100 m Transparent (CL) VG95343T05B001M 309-40123 TF24-1.6/0.8 1.6 1/16 " 0.8 0.43 100 m Transparent (CL) VG95343T05B002M 309-40163 TF24-2.4/1.2 2.4 3/32 " 1.2 0.51 100 m Transparent (CL) VG95343T05B003M 309-40243 TF24-3.2/1.6 3.2 1/8 " 1.6 0.51 100 m Transparent (CL) VG95343T05B004M 309-40323 TF24-4.8/2.4 4.8 3/16 " 2.4 0.51 60 m Transparent (CL) VG95343T05B005M 309-50483 TF24-6.4/3.2 6.4 1/4 " 3.2 0.64 60 m Transparent (CL) VG95343T05B006M 309-50643 Date of issue: October 2015 TYPE Article-No. TF24-9.5/4.8 9.5 3/8 " 4.8 0.64 50 m Transparent (CL) VG95343T05B007M 309-40953 TF24-12.7/6.4 12.7 1/2 " 6.4 0.64 50 m Transparent (CL) VG95343T05B008M 309-41273 TF24-19.1/9.5 19.1 3/4 " 9.5 0.76 50 m Transparent (CL) VG95343T05B009M 309-31903 TF24-25.4/12.7 25.4 1" 12.7 0.89 50 m Transparent (CL) VG95343T05B010M 309-32543 TF24-38.1/19.1 38.1 1-1/2 " 19.1 1.02 60 m Transparent (CL) VG95343T05B011M 309-33813 TF24-50.8/25.4 50.8 2" 25.4 1.14 60 m Transparent (CL) VG95343T05B012M 309-35083 TF24-76.2/38.1 76.2 3" 38.1 1.27 30 m Transparent (CL) VG95343T05B013M 309-37603 TF24-101.6/50.8 101.6 4" 50.8 1.40 15 m Transparent (CL) VG95343T05B014M 309-31023 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.com/insulation 217
309-32543 价格&库存
很抱歉,暂时无法提供与“309-32543”相匹配的价格&库存,您可以联系我们找货
  • 50+71.2618350+9.26600
  • 150+65.00470150+8.45240
  • 250+60.74637250+7.89870
库存:50
