311-00169
311-00169
    HELLERMAN(海尔曼太通)
    HELLERMANNTYTON - 311-00169 - Heat Shrink Tubing, TK20 Semi Rigid, 2:1, 0.062 ", 1.6 mm, Transparent...
311-00169 数据手册
Insulation 2.1 Heat Shrinkable Tubing Heat Shrinkable Tubing 2:1 - PVDF TK20 Typical applications of this translucent tubing are where hightemperature performance is required. Also very suitable for applications that ask for visual inspection of covered components, or if a low friction surface is needed. TK20 is also used as oil stop for energy cables. This thin walled, translucent heat shrink tubing is often used for chemical applications. Features and Benefits • Semi-rigid heat shrinkable tubing made of PVDF • Thin walled and tough • For higher temperature applications • Very good mechanical strength, abrasion resistance and chemical resistance • Meets various industrial standards • Self extinguishing, UL 224 VW1 listed This thin walled, translucent heat shrink tubing is often used for chemical applications. Detailed Information about Heatguns please refer to page 529. MATERIAL Polyvinylidene Fluoride (PVDF) Shrink Ratio 2:1 Operating Temperature -55 °C to +175 °C Minimum Shrink Temperature +175 °C Longitudinal change after shrinkage +/-10 % max Dielectric Strength ≥ 30 kV/mm min. according to ASTM D2171 Flammability UL224 VW-1 Specifications ASN-E0718, NSA937494, PAN6491, SAE - AMS - DTL-23053 / 8, UL224 150 °C 600V VW-1, VG 95343 L Supplied Ø D min. Size (imperial) Recov. Ø d max. Wall (WT) Length (L) Colour Designation as per VG-Norm Article-No. TK20-1.2/0.6 1.2 3/64 " 0.6 0.25 1.2 m Transparent (CL) VG95343T05F001M 331-00129 TK20-1.6/0.8 1.6 1/16 " 0.8 0.25 1.2 m Transparent (CL) VG95343T05F002M 311-00169 TK20-2.4/1.2 2.4 3/32 " 1.2 0.25 1.2 m Transparent (CL) VG95343T05F003M 311-00249 TK20-3.2/1.6 3.2 1/8 " 1.6 0.25 1.2 m Transparent (CL) VG95343T05F004M 311-00329 TK20-4.8/2.4 4.8 3/16 " 2.4 0.25 1.2 m Transparent (CL) VG95343T05F005M 311-00489 TK20-6.4/3.2 6.4 1/4 " 3.2 0.30 1.2 m Transparent (CL) VG95343T05F006M 311-00649 TK20-9.5/4.8 9.5 3/8 " 4.8 0.30 1.2 m Transparent (CL) VG95343T05F007M 311-00959 TK20-12.7/6.4 12.7 1/2 " 6.4 0.30 1.2 m Transparent (CL) VG95343T05F008M 311-01279 TK20-19.1/9.5 19.1 3/4 " 9.5 0.43 1.2 m Transparent (CL) VG95343T05F009M 311-01909 TK20-25.4/12.7 25.4 1" 12.7 0.48 1.2 m Transparent (CL) VG95343T05F010M 311-02549 TK20-38.1/19.1 38.1 1-1/2 " 19.1 0.51 1.2 m Transparent (CL) - 311-03819 TK20-50.8/25.4 50.8 2" 25.4 0.51 1.2 m Transparent (CL) - 311-05089 TYPE All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. ASN 240 For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.com/insulation Date of issue: October 2015 Heat Shrinkable Tubing 2:1
311-00169 价格&库存
很抱歉,暂时无法提供与“311-00169”相匹配的价格&库存,您可以联系我们找货
  • 1+20.256151+2.62160
  • 10+18.5972510+2.40690
  • 125+16.41447125+2.12440
库存:260
311-00169
    库存:71
