550-11401
550-11401
    HELLERMAN(海尔曼太通)
550-11401 数据手册
Identification Systems 5.1 Wire and Cable Markers Self-laminating labels, manual marking RiteOn, Starter Pack, Material 1401 dispenser A specially developed material for use in labels required to wrap around cables and wires. The conformable structure of the label ensures that once the label is applied to the wire it remains in place without lifting. The SPRO200-1401-WH Starter Pack contains all you need to start work identifying your wires, • 1 x RiteOn dispenser •1  x R202 reel of 150 self-laminating labels for cable diameters ranging from 6mm to 12mm • 1 x T82S-BK black indelible ink marker pen Features and Benefits • Palm sized hand held self-laminating label dispenser • Easy to write on and dispense labels • Wide range of wire diameters covered as standard • Ideal for low volume maintenance and repair work • Write text with specially formulated fast-drying ink T82 pens The RiteOn starter pack gets you started right away. Application video: RiteOn TYPE RO201-1401-WH RO202-1401-WH RO203-1401-WH Description Filled dispenser RO201REF-1401-WH RO202REF-1401-WH Refill packs RO203REF-1401-WH SPRO200-1401-WH Starter pack Bundle Ø min. MATERIAL Type 1401, Vinyl (PVC) Operating Temperature -40 °C to +80 °C Curing Temperature from +10 °C Adhesive Acrylic Thickness of Foil (µm) 80 µm Chem. Material Properties Resistant to water, alcohol, most oils, greases, fuel, aliphatic solvents, weak acids, salts and alkalis. Bundle Width Height Height Ø max. (W) (H) (H2) Pack Cont. ArticleNo. Colour 4.0 8.1 12.7 12.7 38.1 200 pcs. White (WH), Transparent (CL) 550-14011 6.1 12.1 19.1 12.7 50.8 150 pcs. White (WH), Transparent (CL) 550-14012 9.1 18.2 19.1 25.4 76.2 100 pcs. White (WH), Transparent (CL) 550-14013 4.0 8.1 12.7 12.7 38.1 200 pcs. White (WH), Transparent (CL) 550-14014 6.1 12.1 19.1 12.7 50.8 150 pcs. White (WH), Transparent (CL) 550-11401 9.1 18.2 19.1 25.4 76.2 100 pcs. White (WH), Transparent (CL) 550-71401 6.1 12.1 19.1 12.7 50.8 150 pcs. White (WH), Transparent (CL) 550-14010 Description Colour Pack Cont. Article-No. T82S-BK Indelible Marker Pen Black (BK) 2 pcs. 500-50820 T82R-RD Indelible Marker Pen Red (RD) 2 pcs. 500-50822 TYPE Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. 442 Further information at www.HellermannTyton.com/identification Date of issue: October 2015 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available.
550-11401 价格&库存
很抱歉,暂时无法提供与“550-11401”相匹配的价格&库存,您可以联系我们找货
