621-10103
    HELLERMAN(海尔曼太通)
    HELLERMANNTYTON - 621-10103 - Cable Management Tool, 3-Pronged, Cable Tie Tool
621-10103 数据手册
Application Tooling Application Tooling for Non Shrinkable Tubing 6.3 Three-Pronged Pliers for Sleeves and Grommets NA Three-pronged expansion tools are used to ensure speedy and precise application of expandable markers and sleeves. Features and Benefits • To easy affix expandable sleeves of every type onto cables/connectors • Sleeve simply slide onto the prongs • Push pliers and pull over cable • Close pliers, sleeve is placed easily • Hellerine lubricant recommended for easy operation Fast, secure application with the NA three-pronged pliers. Replacement prong NA1K/3 Replacement prong NA0/1 Three-prong pliers max. application diameter Replacement prong NA8/10 Replacement prong NA4/5 TYPE Bundle Ø min. Bundle Ø max. ØD max. Max. length of marker Article-No. NA/01 1.3 1.8 10.5 28 621-10001 NA1K/3 2.5 5.0 11.0 28 621-10103 NA4/5 7.5 10.0 15.5 50 621-10405 NA8/10 12.0 17.0 25.5 60 621-10810 NA/01 PRONG 1.3 1.8 - 28 621-60001 NA1K/3 PRONG 2.5 5.0 - 28 621-60103 NA4/5 PRONG 7.5 10.0 - 50 621-60405 NA8/10 PRONG 12.0 17.0 - 60 621-60810 Date of issue: October 2015 All dimensions in mm. Subject to technical changes. Further information at www.HellermannTyton.com/tools 531
621-10103
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外发射二极管。
2. 器件简介:EL817是一种红外发射二极管,用于红外线发射,常用于遥控器等设备。
3. 引脚分配:EL817有两个引脚,分别为阳极和阴极。
4. 参数特性:工作电压范围为1.4V至1.8V,工作电流为50mA,发射波长为940nm。
5. 功能详解:EL817在通电后发射红外光,用于无线信号传输。
6. 应用信息:主要用于红外线遥控器、红外线通信设备等。
7. 封装信息:EL817采用黑色环氧树脂封装,尺寸为3.8mm x 1.7mm。
621-10103 价格&库存
很抱歉,暂时无法提供与“621-10103”相匹配的价格&库存,您可以联系我们找货
