990-804
    HELLERMAN(海尔曼太通)
990-804 数据手册
Weldy Hot Air Tool The Weldy Pro and Plus are compact, lightweight heat guns. They are designed for use with all types of heatshrinkable tubing and shapes. The Weldy Pro has an adjustable temperature range from 100°C to 550°C, whilst the Weldy Plus gives a maximum 650°C. For ease-of-use the Plus also includes a handy LCD display to show air temperature and application. The Triac-S is specifically designed for long running bench work. It features a high temperature element protected by thermal cutoff and a stay cool nozzle. The temperature range is from ambient to 600°C. Nozzle accessories are avaliable upon request. Weldy Pro. Weldy Plus. Triac S Hot Air Tool. Technical Table Article-No. Type 391-00407 Triac-S Air Flow l/min Temp. °C Wattage Operational Voltage Weight (Kg) 230 max. 20-700 1600 W 230-240 V 391-00409 Sieve reflector 50mm – – – – – 391-00410 Sieve reflector 35mm – – – – – 391-00411 Solder sleeve reflector 1.3 – – – – – 391-00501 Weldy Plus 200-550 80-650 2000 W 230-240 V 0.62 391-00502 Weldy Pro 0.57 250-500 100-550 1800 W 230-240 V 391-00503 Overlap welding nozzle – – – – – 391-00504 Reduction nozzle – – – – – 391-00505 Reflector nozzle – – – – – 391-00506 Wide slot nozzle – – – – – 391-00507 Solder sleeve reflector – – – – – 391-00508 Welding nozzle – – – – – 1
990-804 价格&库存
很抱歉,暂时无法提供与“990-804”相匹配的价格&库存,您可以联系我们找货
