The Best Choice for Professional,
Industrial labelling!
The RhinoPRO 5000 is an easy to use, affordable, rugged industrial label printer that
uses durable labels that stick and stay stuck. It’s specifically designed to quickly and easily
label cables, patch panels, racks, infrastructure equipment, fuse boxes or anything else that
needs labelling around your job site or facility.
Features and Benefits:
Simple one-touch “Hot Keys” for popular formats
and functions:
• WRAP: simply enter the diameter of your cable to
create wraps
• PPANEL: creates perfect patch panel labels
for one port, forty eight ports or a whole rack
• MODULE: creates one label that fits exactly
with the total number of modular components
on a DIN rail
• FIXED: creates fixed length labels for face
plates, ...
Extra large backlit display for use in low
light conditions.
Easy to see, bright colour ensures it won’t get
lost.
Durable rubber bumper provides extra
protection.
Includes commonly used
datacom and electrical symbols:
ohm, ground, phone, data, fax, and
also prints barcodes 39 and 128.
Built-in battery life indicator and
auto-shut off so you don’t run out
of power on the job.
Separate Save and Recall keys for
quick access to label memory.
Multiple line printing and serialisation.
Fits easily in the palm of your hand
for labelling on the job.
Easy to load “all-in-one” RhinoPRO cartridges.
Prints on 6mm, 9mm, 12mm, 19mm RhinoPRO tapes
Applications all around your job site...
Labelling with “Hot Keys”:
Cable/Wire Wrapping
Patch Panels
Fixed Length labels
Vertical labels
Modules
And lots more …
Fixed Length Labels
Vertical Labels
Patch Panels
RhinoPRO Labels:
Cable/Wire Wrapping
Thermal transfer print technology is durable, smearproof
and resists chemicals, solvents, grease, heat, moisture and
other harsh elements.
Permanent adhesive results in labels that stick and last in
harsh industrial environments.
Easy-to-peel labels, available in split-back and dry-edge
varieties.
Modules
Easy-peel split-back label
- LABEL SELECTION CHART Surface applications
Material
6 mm
9 mm
12 mm
19 mm
Lenght
Wire/Cable/Curved/Smooth/Flat/Textured/Highly Textured
Indoor Surfaces
White Flexible Nylon
n/a
n/a
18758
18759
3,5 m
Indoor Surfaces
Yellow Flexible Nylon
n/a
n/a
18756
18757
3,5 m
Wire/Cable/Curved/Smooth/Flat/Textured/Highly Textured Surfaces
Yellow Vinyl
n/a
18431
18432
18433
5,5 m
Outdoor Surfaces
Orange Vinyl
n/a
18434
18435
18436
5,5 m
Outdoor Surfaces
Red Vinyl
n/a
18437
18438
18439
5,5 m
Green Vinyl
n/a
18440
18441
18442
5,5 m
White Vinyl
n/a
18443
18444
18445
5,5 m
Smooth/Flat/Textured Surfaces
White Permanent Polyester
n/a
18766
18764
18765
5,5 m
Metallized Permanent Polyester
n/a
18760
18761
18762
5,5 m
Clear Permanent Polyester
n/a
18508
n/a
n/a
7m
Wire and Cable
White Heat Shrink Tube
18051
18053
18055
18057
1,5 m
Wire and Cable
Yellow Heat Shrink Tube
18052
18054
18056
18058
1,5 m
Insert
White Non-Adhesive Tag
18111
18112
18113
18114
5,5 m
Insert
Yellow Non-Adhesive Tag
18115
18116
18117
18118
5,5 m
Product Specifications:
• Codenumber: 16903
• Includes : RhinoPRO 5000, rubber bumper, 19mm white flexible nylon tape
• Works with 6 AA batteries (not included)
• Dimensions (excl. protective bumper) : 212mm H x 114mm W x 70 mm L
• Weight: 519 gr
Options:
DYMO bvba
Industriepark-Noord 30
B-9100 Sint-Niklaas
Belgium
929812
• Hard carrying case
• Soft carrying holster
• Rechargeable batterypack
• Adapter
For more information or to find your nearest RhinoPRO distributor, please visit www.dymo.com or call us at (+44) 020 7341 5529
很抱歉,暂时无法提供与“BULLDOG”相匹配的价格&库存,您可以联系我们找货
