H50 X 25 RED
H50 X 25 RED
    HELLERMAN(海尔曼太通)
    Sleeving, Helsyn H Tubing, 25 mm, 1 ", Binding, 5 mm, Polychloroprene, Red
H50 X 25 RED 数据手册
HellermannTyton DATA SHEET H, TH &HH: Polychloroprene DESCRIPTION The H range of tubing is extruded from a specially formulated polychloroprene rubber compound that offers excellent elastomeric properties, H sleeves are supplied fully severed. APPLICATION The sleeves are ideally suited for the binding of cable harnesses where a high degree of expansion may be required (x 5D whilst fitting and x 2D in service). It can be used in Aerospace, Automotive, Construction, Consumer Electronics, Defence, Mass Transit and Telecommunications applications. PROPERTIES Properties Typical Results Material Continuous Operating Temp Intermittent Temperature Flammability Oxygen Index Proof Voltage Volume Resistivity Resistance to Polychloroprene -65 °C to +95 °C +120 °C HB 28.3 4KV 12 10 Ωcm Acids Alkalis Oils Fuels Moisture UV Ozone Shelf Life (
H50 X 25 RED 价格&库存
很抱歉,暂时无法提供与“H50 X 25 RED”相匹配的价格&库存,您可以联系我们找货
