HIS-PACK-2,4/1,2-CL
HIS-PACK-2,4/1,2-CL
    HELLERMAN(海尔曼太通)
HIS-PACK-2,4/1,2-CL 数据手册
Insulation 2.1 Heat Shrinkable Tubing Storage Rack for HIS-Boxes • HIS-Service Station HIS general purpose heat shrink tubing provides a reliable insulation and protects against corrosion and mechanical influences. The handy dispenser is ideal for small and medium size projects on-site. The sturdy metal HIS Service Station comes with a cutter and can store all sizes and colours. The Service Station can be mounted to the wall in the work shop or service-van. Features and Benefits • Contains up to 5 dispenser boxes • Place on bench or mount to wall • Special cutter included for easily cutting tubing length to size TYPE HIS Service Station HIS-Service Station contains 5 dispensers and a special cutter. Description Article-No. HIS-Service Station incl. cutter, contents: 5 dispensers HIS-3 (shrink ratio: 3:1), black, sizes are as follows: HIS-3/1, HIS-6/2, HIS-12/4 (2 pcs.), HIS-24/8 365-30100 HIS-Service Station incl. cutter, contents: 5 dispensers HIS-Pack (shrink ratio: 2:1), black, sizes are as follows: HIS-1/8, HIS-3/16, HIS-1/4, HIS-3/8, HIS 1/2 and one RiteOn Starter Pack 365-20000 HIS-Service Station incl. cutter, empty 300-30000 All dimensions in mm. Subject to technical changes. Heat Shrinkable Tubing 2:1 on a Reel • HIS-PACK • General purpose electrical insulation • Protection against corrosion and mechanical abrasion Features and Benefits • Cross-linked Polyolefin, thin-wall and flexible • Handy dispenser box including table showing application size range • Available in black, red, blue, transparent and yellow/green • 10 sizes from 1.2 mm to 25.4 mm Heat Shrinkable Tubing 2:1 MATERIAL Polyolefin, cross-linked (PO-X) Shrink Ratio 2:1 Operating Temperature -55 °C to +125 °C Minimum Shrink Temperature +100 °C Longitudinal change after shrinkage +/-5% Dielectric Strength 20kV/mm according to ASTM D2671 Flammability UL224 VW-1 (except clear) Specifications SAE - AMS - DTL-23053/5 Class 1 and 3, SAE - AMS - DTL-23053/5 Class 2 (clear), UL224 125 °C 600V VW-1 Please note! Not all products listed on this page may have this approval. For product specific approvals please refer to the Appendix. 122 Further information and products at www.HellermannTyton.co.uk/a122 Date of issue: January 2014 HIS-Pack. Insulation 2.1 Heat Shrinkable Tubing Heat Shrinkable Tubing 2:1 on a Reel • HIS-PACK TYPE HIS-PACK-1.2/0.6 HIS-PACK-1.6/0.8 HIS-PACK-2.4/1.2 HIS-PACK-3.2/1.6 HIS-PACK-4.8/2.4 HIS-PACK-6.4/3.2 HIS-PACK-9.5/4.7 HIS-PACK-12.7/6.4 Date of issue: January 2014 HIS-PACK-19.1/9.5 HIS-PACK-25.4/12.7 Supplied Ø D min. Recov. Ø d max. Wall (WT) Reel Length Colour Article-No. 1.2 0.6 0.40 10 m Black (BK) 300-30120 1.2 0.6 0.40 10 m Blue (BU) 300-30126 1.2 0.6 0.40 10 m Red (RD) 300-30122 1.2 0.6 0.40 10 m Transparent (CL) 300-30123 1.6 0.8 0.40 10 m Black (BK) 300-30160 1.6 0.8 0.40 10 m Blue (BU) 300-30166 1.6 0.8 0.40 10 m Red (RD) 300-30162 1.6 0.8 0.40 10 m Transparent (CL) 300-30163 2.4 1.2 0.50 10 m Black (BK) 300-30240 2.4 1.2 0.50 10 m Blue (BU) 300-30246 2.4 1.2 0.50 10 m Red (RD) 300-30242 2.4 1.2 0.50 10 m Transparent (CL) 300-30243 3.2 1.6 0.50 10 m Black (BK) 300-30320 3.2 1.6 0.50 10 m Blue (BU) 300-30326 3.2 1.6 0.50 10 m Green-Yellow (GNYE) 300-30327 3.2 1.6 0.50 10 m Red (RD) 300-30322 3.2 1.6 0.50 10 m Transparent (CL) 300-30323 4.8 2.4 0.50 10 m Black (BK) 300-30480 4.8 2.4 0.50 10 m Blue (BU) 300-30486 4.8 2.4 0.50 10 m Green-Yellow (GNYE) 300-30487 4.8 2.4 0.50 10 m Red (RD) 300-30482 4.8 2.4 0.50 10 m Transparent (CL) 300-30483 6.4 3.2 0.60 5m Black (BK) 300-30640 6.4 3.2 0.60 5m Blue (BU) 300-30646 6.4 3.2 0.60 5m Green-Yellow (GNYE) 300-30647 6.4 3.2 0.60 5m Red (RD) 300-30642 6.4 3.2 0.60 5m Transparent (CL) 300-30643 9.5 4.7 0.60 5m Black (BK) 300-30950 9.5 4.7 0.60 5m Blue (BU) 300-30956 9.5 4.7 0.60 5m Green-Yellow (GNYE) 300-30957 9.5 4.7 0.60 5m Red (RD) 300-30952 9.5 4.7 0.60 5m Transparent (CL) 300-30953 12.7 6.4 0.60 5m Black (BK) 300-31270 12.7 6.4 0.60 5m Blue (BU) 300-31276 12.7 6.4 0.60 5m Green-Yellow (GNYE) 300-31277 12.7 6.4 0.60 5m Red (RD) 300-31272 12.7 6.4 0.60 5m Transparent (CL) 300-31273 19.1 9.5 0.80 5m Black (BK) 300-31900 19.1 9.5 0.80 5m Blue (BU) 300-31906 19.1 9.5 0.80 5m Green-Yellow (GNYE) 300-31907 19.1 9.5 0.80 5m Red (RD) 300-31902 19.1 9.5 0.80 5m Transparent (CL) 300-31903 25.4 12.7 0.90 5m Black (BK) 300-32540 25.4 12.7 0.90 5m Blue (BU) 300-32546 25.4 12.7 0.90 5m Green-Yellow (GNYE) 300-32547 25.4 12.7 0.90 5m Red (RD) 300-32542 25.4 12.7 0.90 5m Transparent (CL) 300-32543 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Further information and products at www.HellermannTyton.co.uk/a123 123
HIS-PACK-2,4/1,2-CL 价格&库存
很抱歉,暂时无法提供与“HIS-PACK-2,4/1,2-CL”相匹配的价格&库存,您可以联系我们找货
