Insulation
Heat Shrinkable Tubing
2.1
Heat Shrinkable Tubing 2:1 flexible and coloured
HFT-A - self extinguishing
This high performance thin wall tubing is used extensively for electrical
and mechanical protection. It is also well proven for sleeve marking
to identify wiring circuits. It shrinks uniformly to form a permanent
insulation covering.
The transparent version is used for bundling and cable protection where
visual inspection is required. It is often used as a see through protective
sleeve over cable markers.
Features and Benefits
• Flexible heat shrink tubing
• Fast shrinking, easy handling, good mechanical strength
• Easy to print on
• Wide range of colours
• Internal diameters up to 4 inches (101.6 mm)
• UL-224 ,CSA listed and VG approved
HFT-A conforms to major standards used in all Defence industries.
Standard sizes available in colours black,
red, blue, yellow, white and green-yellow.
MATERIAL
Polyolefin, cross-linked (PO-X)
Shrink Ratio
2:1
Operating Temperature
-55 °C to +135 °C
Minimum Shrink
Temperature
+100 °C
Longitudinal change
after shrinkage
+5 %/-10 %
Dielectric Strength
20 kV/mm according to IEC 60684 P2
Flammability
Self extinguishing
Specifications
ASN-E0126, CSA, DEF STAN 59-97/3,
LEA, MIL-DTL-23053/5C, NF F 00-608,
NSA937211, PAN6493, SAE - AMS DTL-23053 / 5C, UL224 125 °C 600V,
VG 95343
TYPE
HFT-A-1.2/0.6
HFT-A-1.6/0.8
Supplied
Ø D min.
Size
(imperial)
Recov.
Ø d max.
Wall
(WT)
Reel
Length
Colour
Designation as per
VG-Norm
1.2
3/64 "
0.6
0.40
400 m
Black (BK)
VG 95343 T05 A 001A
305-01200
1.2
3/64 "
0.6
0.40
400 m
Blue (BU)
VG 95343 T05 A 001 G
305-01206
1.2
3/64 "
0.6
0.40
400 m
Red (RD)
VG 95343 T05 A 001 C
305-01202
1.2
3/64 "
0.6
0.40
400 m
White (WH)
VG 95343 T05 A 001 L
305-01209
1.2
3/64 "
0.6
0.40
400 m
Yellow (YE)
VG 95343 T05 A 001 E
305-01204
1.6
1/16 "
0.8
0.40
400 m
Black (BK)
VG 95343 T05 A 002 A
305-01600
1.6
1/16 "
0.8
0.40
400 m
Blue (BU)
VG 95343 T05 A 002 G
305-01606
1.6
1/16 "
0.8
0.40
400 m
Red (RD)
VG 95343 T05 A 002 C
305-01602
1.6
1/16 "
0.8
0.40
400 m
White (WH)
VG 95343 T05 A 002 L
305-01609
1.6
1/16 "
0.8
0.40
400 m
Yellow (YE)
VG 95343 T05 A 002 E
305-01604
Article-No.
Date of issue: October 2015
All dimensions in mm. Subject to technical changes.
Minimum Order Quantity (MOQ) may differ from package content.
ASN
LEA
For product specific approvals and specifications
please refer to the Appendix.
Further information at www.HellermannTyton.com/insulation
211
Insulation
2.1
TYPE
HFT-A-2.4/1.2
HFT-A-3.2/1.6
HFT-A-4.8/2.4
HFT-A-6.4/3.2
HFT-A-9.5/4.8
HFT-A-12.7/6.4
Supplied
Ø D min.
Size
(imperial)
Recov.
Ø d max.
Wall
(WT)
Reel
Length
Colour
Designation as per
VG-Norm
Article-No.
2.4
3/32 "
1.2
0.50
100 m
Blue (BU)
VG 95343 T05 A 003 G
305-02406
2.4
3/32 "
1.2
0.50
100 m
Red (RD)
VG 95343 T05 A 003 C
305-02402
2.4
3/32 "
1.2
0.50
100 m
White (WH)
VG 95343 T05 A 003 L
305-02409
2.4
3/32 "
1.2
0.50
100 m
Yellow (YE)
VG 95343 T05 A 003 E
305-02404
2.4
3/32 "
1.2
0.50
400 m
Black (BK)
VG 95343 T05 A 003 A
305-02400
3.2
1/8 "
1.6
0.50
100 m
Blue (BU)
VG 95343 T05 A 004 G
305-03206
3.2
1/8 "
1.6
0.50
100 m
Green-Yellow (GNYE)
VG 95343 T05 A 004 N
305-03245
3.2
1/8 "
1.6
0.50
100 m
Red (RD)
VG 95343 T05 A 004 C
305-03202
3.2
1/8 "
1.6
0.50
100 m
White (WH)
VG 95343 T05 A 004 L
305-03209
3.2
1/8 "
1.6
0.50
100 m
Yellow (YE)
VG 95343 T05 A 004 E
305-03204
3.2
1/8 "
1.6
0.50
400 m
Black (BK)
VG 95343 T05 A 004 A
305-03200
4.8
3/16 "
2.4
0.50
75 m
Blue (BU)
VG 95343 T05 A 005 G
305-04806
4.8
3/16 "
2.4
0.50
75 m
Green-Yellow (GNYE)
VG 95343 T05 A 005 N
305-04845
4.8
3/16 "
2.4
0.50
75 m
Red (RD)
VG 95343 T05 A 005 C
305-04802
4.8
3/16 "
2.4
0.50
75 m
White (WH)
VG 95343 T05 A 005 L
305-04809
4.8
3/16 "
2.4
0.50
75 m
Yellow (YE)
VG 95343 T05 A 005 E
305-04804
4.8
3/16 "
2.4
0.50
300 m
Black (BK)
VG 95343 T05 A 005 A
305-04800
6.4
1/4 "
3.2
0.60
75 m
Blue (BU)
VG 95343 T05 A 006 G
305-06406
6.4
1/4 "
3.2
0.60
75 m
Green-Yellow (GNYE)
VG 95343 T05 A 006 N
305-06445
6.4
1/4 "
3.2
0.60
75 m
Red (RD)
VG 95343 T05 A 006 C
305-06402
6.4
1/4 "
3.2
0.60
75 m
White (WH)
VG 95343 T05 A 006 L
305-06409
6.4
1/4 "
3.2
0.60
75 m
Yellow (YE)
VG 95343 T05 A 006 E
305-06404
6.4
1/4 "
3.2
0.60
300 m
Black (BK)
VG 95343 T05 A 006 A
305-06400
9.5
3/8 "
4.8
0.60
50 m
Blue (BU)
VG 95343 T05 A007 G
305-09506
9.5
3/8 "
4.8
0.60
50 m
Green-Yellow (GNYE)
VG 95343 T05 A007 N
305-09545
9.5
3/8 "
4.8
0.60
50 m
Red (RD)
VG 95343 T05 A007 C
305-09502
9.5
3/8 "
4.8
0.60
50 m
White (WH)
VG 95343 T05 A007 L
305-09509
9.5
3/8 "
4.8
0.60
50 m
Yellow (YE)
VG 95343 T05 A007 E
305-09504
9.5
3/8 "
4.8
0.60
150 m
Black (BK)
VG 95343 T05 A007 A
305-09500
12.7
1/2 "
6.4
0.60
50 m
Blue (BU)
VG 95343 T05 A 008 G
305-12706
12.7
1/2 "
6.4
0.60
50 m
Green-Yellow (GNYE)
VG 95343 T05 A 008 N
305-12745
12.7
1/2 "
6.4
0.60
50 m
Red (RD)
VG 95343 T05 A 008 C
305-12702
12.7
1/2 "
6.4
0.60
50 m
White (WH)
VG 95343 T05 A 008 L
305-12709
12.7
1/2 "
6.4
0.60
50 m
Yellow (YE)
VG 95343 T05 A 008 E
305-12704
12.7
1/2 "
6.4
0.60
100 m
Black (BK)
VG 95343 T05 A 008 A
305-12700
ASN
212
LEA
Insulation
2.1
TYPE
HFT-A-19.0/9.5
HFT-A-25.4/12.7
HFT-A-38.0/19.0
HFT-A-50.8/25.4
HFT-A-76.0/38.0
HFT-A-101.6/50.8
Supplied
Ø D min.
Size
(imperial)
Recov.
Ø d max.
Wall
(WT)
Reel
Length
Colour
Designation as per
VG-Norm
Article-No.
19.0
3/4 "
9.5
0.80
25 m
Blue (BU)
VG 95343 T05 A 009 G
305-19006
19.0
3/4 "
9.5
0.80
25 m
Green-Yellow (GNYE)
VG 95343 T05 A 009 N
305-19045
19.0
3/4 "
9.5
0.80
25 m
Red (RD)
VG 95343 T05 A 009 C
305-19002
19.0
3/4 "
9.5
0.80
25 m
White (WH)
VG 95343 T05 A 009 L
305-19009
305-19004
19.0
3/4 "
9.5
0.80
25 m
Yellow (YE)
VG 95343 T05 A 009 E
19.0
3/4 "
9.5
0.80
50 m
Black (BK)
VG 95343 T05 A 009 A
305-19000
25.4
1"
12.7
0.90
25 m
Blue (BU)
VG 95343 T05 A 010 G
305-25406
25.4
1"
12.7
0.90
25 m
Green-Yellow (GNYE)
VG 95343 T05 A 010 N
305-25445
25.4
1"
12.7
0.90
25 m
Red (RD)
VG 95343 T05 A 010 C
305-25402
25.4
1"
12.7
0.90
25 m
White (WH)
VG 95343 T05 A 010 L
305-25409
25.4
1"
12.7
0.90
25 m
Yellow (YE)
VG 95343 T05 A 010 E
305-25404
25.4
1"
12.7
0.90
50 m
Black (BK)
VG 95343 T05 A 010 A
305-25400
38.0
1-1/2 "
19.0
1.00
50 m
Black (BK)
VG 95343 T05 A 011 A
305-38100
38.0
1-1/2 "
19.0
1.00
50 m
Blue (BU)
VG 95343 T05 A 011 G
305-38106
38.0
1-1/2 "
19.0
1.00
50 m
Green-Yellow (GNYE)
VG 95343 T05 A 011 N
305-38145
38.0
1-1/2 "
19.0
1.00
50 m
Red (RD)
VG 95343 T05 A 011 C
305-38102
38.0
1-1/2 "
19.0
1.00
50 m
White (WH)
VG 95343 T05 A 011 L
305-38109
38.0
1-1/2 "
19.0
1.00
50 m
Yellow (YE)
VG 95343 T05 A 011 E
305-38104
51.0
2"
25.4
1.10
35 m
Black (BK)
VG 95343 T05 A 012 A
305-50800
51.0
2"
25.4
1.10
35 m
Blue (BU)
VG 95343 T05 A 012 G
305-50806
51.0
2"
25.4
1.10
35 m
Red (RD)
VG 95343 T05 A 012 C
305-50802
51.0
2"
25.4
1.10
35 m
White (WH)
VG 95343 T05 A 012 L
305-50809
51.0
2"
25.4
1.10
35 m
Yellow (YE)
VG 95343 T05 A 012 E
305-50804
76.0
3"
38.0
1.30
25 m
Black (BK)
VG 95343 T05 A 013 A
305-76200
76.0
3"
38.0
1.30
25 m
Blue (BU)
VG 95343 T05 A 013 G
305-76206
76.0
3"
38.0
1.30
25 m
Red (RD)
VG 95343 T05 A 013 C
305-76202
76.0
3"
38.0
1.30
25 m
White (WH)
VG 95343 T05 A 013 L
305-76209
76.0
3"
38.0
1.30
25 m
Yellow (YE)
VG 95343 T05 A 013 E
305-76204
101.6
4"
50.8
1.40
25 m
Black (BK)
VG 95343 T05 A 014 A
305-91600
101.6
4"
50.8
1.40
25 m
Blue (BU)
VG 95343 T05 A 014 G
305-91606
101.6
4"
50.8
1.40
25 m
Red (RD)
VG 95343 T05 A 014 C
305-91602
101.6
4"
50.8
1.40
25 m
White (WH)
VG 95343 T05 A014 L
305-91609
101.6
4"
50.8
1.40
25 m
Yellow (YE)
VG 95343 T05 A 014 E
305-91604
ASN
LEA
213
很抱歉,暂时无法提供与“305-01200”相匹配的价格&库存,您可以联系我们找货
