308-30920
308-30920
    HELLERMAN(海尔曼太通)
308-30920 数据手册
308-30920 Article Number: 308-30920 Heat Shrink Tubing, HIS-3-Bag, 3:1, 3/8", 9.5/3.0 dia., Polyolefin, Black, 10/pkg Download spec sheet Base Data Local Order Number 308-30920 Type HIS-3-BAG 9/3 BK Color Black (BK) Features and Benefits • Thin wall, flexible 3 to 1 shrink ratio material accommodates a wide range of component shapes and diameters. • Meets UL224 VW-1 specifications, making it ideal for high heat applications (excludes clear tubing). • Polyolefin material provides excellent insulation and mechanical strength with good resistance to solvents, oils and fuels. • Available in bulk reels, sticks and convenience bags (HIS-3 bags), for small to large volume applications. Product Description TFN31 series heat shrink tubing features a flexible, thin wall and highly flame retardant polyolefin material with a higher operating temperature range than general-use heat shrink tubing. and offers good resistance to solvents, oils and fuels. The 3 to 1 shrink ratio accommodates a variety of component shapes and sizes. TFN31 tubing is available in bulk reels, sticks and convenience bags (HIS-3 bags), for projects of all sizes. Short Description Heat Shrink Tubing, HIS-3-Bag, 3:1, 3/8", 9.5/3.0 dia., Polyolefin, Black, 10/pkg Product Dimensions Length L (Metric) 200 mm Length L3 (imperial) 6.0 " Length L3 (metric) 152.4 mm Shrink Ratio 3:1 Tensile Strength (MPa) 14 MPa Trade Size 3/8 " Variant Thin-Wall Volume Resistance (Ohm cm) 10¹ Ω cm (ASTM D 876) Nominal Diameter (Imperial) 3/8 " Nominal Diameter (Metric) 9.5 mm Wall Thickness WT (Imperial) 0.029 " Wall Thickness WT (Metric) .75 mm Recovered Diameter d (metric) 3.0 mm Recovered Diameter d (imperial) 0.118 " Supplied Diameter D (imperial) 0.38 " Supplied Diameter D (metric) 9.5 mm Logistics and Packaging Quantity Per bag Package Quantity 10 Package Quantity (Metric) 10 Pieces Material and Specifications Material Polyolefin, cross-linked (PO-X) Material Shortcut PO-X Dielectric Strength (Metric) 20 kV/mm according to ASTM D 150 Elongation at break 800% nach ASTM D2671 Flammability UL224 VW-1 (except clear) Shrink Temperature +212 °F (+100 °C) Operating Temperature -67°F to +275°F (-55°C to +135°C) ROHS Compliant Yes Certification/Specification SAE - AMS - DTL-23053/5 Class 1 and 3 UL224 125 °C 600V VW-1 SAE - AMS - DTL-23053/5 Class 2 (clear) UL Listed (US and Canada) Yes © HellermannTyton 2015
308-30920 价格&库存
很抱歉,暂时无法提供与“308-30920”相匹配的价格&库存,您可以联系我们找货
