318-40400
318-40400
    HELLERMAN(海尔曼太通)
    HELLERMANNTYTON - TA42-4/1 PO-X BK - HEAT-SHRINK TUBING, 4:1, 4MM, BLACK
318-40400 数据手册
Insulation 2.1 Heat Shrinkable Tubing Heat Shrinkable Tubing adhesive lined 1.2 m lengths TA32/TA42 is designed for environmental sealing and electrical insulation of wire splices, terminations and components. Features and Benefits • Thin walled adhesive-lined heat shrink tubing • Highly flame retardant • Outer wall conforms to UL224 TA32 and TA42 are UL224 listed adhesive lined tubing. Available in 3:1 and 4:1 shrink ratio. Cut lengths available on request. Please contact us! MATERIAL Polyolefin, cross-linked (PO-X) Operating Temperature -55 °C to +125 °C Minimum Shrink Temperature +110 °C Softening Point Adhesive +110 °C Longitudinal change after shrinkage -15 % max. Dielectric Strength 15 kV/mm according to IEC 60684 P2 Flammability UL224 Specifications CSA, SAE - AMS - DTL-23053/4 Class 3, UL224 125 °C 600V TA32 - thin wall, 3:1 shrink ratio L Supplied Ø D min. Recov. Ø d max. Wall (WT) Length (L) Colour Shrink Ratio Article-No. TA32-3/1 3.2 0.6 0.95 1.2 m Black (BK) 3:1 318-30300 TA32 4.5/1.5 4.5 1.5 1.10 1.2 m Black (BK) 3:1 318-30450 TA32-6/2 6.0 2.0 1.20 1.2 m Black (BK) 3:1 318-30600 TA32-9/3 9.0 3.0 1.30 1.2 m Black (BK) 3:1 318-30900 TA32-12/4 12.0 4.0 1.40 1.2 m Black (BK) 3:1 318-31200 TA32-19/6 19.0 6.0 1.80 1.2 m Black (BK) 3:1 318-31900 TA32-24/8 24.0 8.0 2.50 1.2 m Black (BK) 3:1 318-32400 TA32-40/13 40.0 13.0 2.50 1.2 m Black (BK) 3:1 318-34000 TYPE All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. For product specific approvals and specifications please refer to the Appendix. 222 Further information at www.HellermannTyton.com/insulation Date of issue: October 2015 Heat Shrinkable Tubing 3:1 with adhesive Insulation Heat Shrinkable Tubing 2.1 Heat Shrinkable Tubing adhesive lined 1.2 m lengths TA42 - thin wall, 4:1 shrink ratio L Detailed Information about Heatguns please refer to page 529. Heat Shrinkable Tubing 4:1 with adhesive Supplied Ø D min. Recov. Ø d max. Wall (WT) Length (L) Colour Shrink Ratio Article-No. TA42-4/1 4.0 1.0 1.00 1.2 m Black (BK) 4:1 318-40400 TA42-8/2 8.0 2.0 1.20 1.2 m Black (BK) 4:1 318-40800 TA42-12/3 12.0 3.0 1.40 1.2 m Black (BK) 4:1 318-41200 TA42-16/4 16.0 4.0 1.80 1.2 m Black (BK) 4:1 318-41600 TA42-24/6 24.0 6.0 2.25 1.2 m Black (BK) 4:1 318-42400 TA42-32/8 32.0 8.0 2.55 1.2 m Black (BK) 4:1 318-43200 TA42-52/13 52.0 13.0 2.55 1.2 m Black (BK) 4:1 318-45200 TYPE Date of issue: October 2015 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.com/insulation 223
318-40400 价格&库存
很抱歉,暂时无法提供与“318-40400”相匹配的价格&库存,您可以联系我们找货
  • 1+65.600821+8.49760
  • 10+60.1922410+7.79700
  • 50+52.8644950+6.84780
库存:250
