515-02622
    HELLERMAN(海尔曼太通)
515-02622 数据手册
Identification Systems 5.2 Wire and Cable Markers Pre-printed Cable Markers • Helagrip, chevron cut Helagrip is used to mark cable and wire. Ideally suited to panel building, mass transit, utilities, telecommunications, and electrical contracting. Depending on marker size, the product is supplied either on a reel (HGDC) or in a plastic bag (HGBC). Markers are available as standard in international resistor colour code and yellow material marked in black. White material marked in black is available to special order. Characters are 0-9, A-Z, and standard electrical symbols. Features and Benefits • Easily apply one size marker to wide range of cables • Markers are applied before termination takes place • Chevron cut to lock markers together ensuring text remains in place • Traditional wire marking available in yellow, white and colour code • Flexible material so product returns securely on the wire Clearly a better way to identify in confined spaces. MATERIAL Flexible Polyvinyl Chloride, cadmium free (PVC) Operating Temperature -65 °C to +105 °C, intermittent +135 °C Flammability UL94 V0 (3mm) Specifications BS-2782-540B, BS 6746C, IEC 757, UL224 Helagrip chevron cut. TYPE HGDC1-3 Outside Ø min. Outside Ø max. Length (L) Pack Cont. 1.0 3.0 3.5 1,000 HGDC2-5 2.0 5.0 3.5 1,000 HGDC4-9 4.0 9.0 5.0 250 Date of issue: January 2014 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Further information and products at www.HellermannTyton.co.uk/a247 247 Identification Systems 5.2 Wire and Cable Markers Pre-printed Cable Markers • Helagrip, chevron cut HGDC1-3 HGDC2-5 HGDC2-5 Article-No. Article-No. Article-No. Article-No. 515-01014 515-01604 515-02014 515-02604 515-01024 515-01614 515-02024 515-02614 515-01034 515-01624 515-02034 515-02624 515-01044 515-01634 515-02044 515-02634 515-01054 515-01644 515-02054 515-02644 515-01064 515-01654 515-02064 515-02654 515-01074 515-01664 515-02074 515-02664 515-01084 515-01674 515-02084 515-02674 515-01094 515-01684 515-02094 515-02684 515-01104 515-01694 515-02104 515-02694 515-01114 515-01704 515-02114 515-02704 515-01124 515-01714 515-02124 515-02714 515-01134 515-01724 515-02134 515-02715 515-01144 515-01734 515-02144 515-02724 515-01154 515-01804 515-02154 515-02734 515-01164 515-01600 515-02164 515-02600 515-01174 515-01611 515-02174 515-02611 515-01184 515-01622 515-02184 515-02622 515-01194 515-01633 515-02194 515-02633 515-01204 515-01644 515-02204 515-02644 515-01214 515-01655 515-02214 515-02655 515-01224 515-01666 515-02224 515-02666 515-01234 515-01677 515-02234 515-02677 515-01244 515-01688 515-02244 515-02688 515-01254 515-01699 515-02254 515-02699 515-01264 515-02264 Please note! Not all products listed on this page may have this approval. For product specific approvals please refer to the Appendix. 248 Further information and products at www.HellermannTyton.co.uk/a248 Date of issue: January 2014 HGDC1-3 Identification Systems 5.2 Wire and Cable Markers Pre-printed Cable Markers • Helagrip, chevron cut HGDC4-9 HGDC4-9 Article-No. Article-No. 515-03014 515-03604 515-03024 515-03614 515-03034 515-03624 515-03044 515-03634 515-03054 515-03644 515-03064 515-03654 515-03074 515-03664 515-03084 515-03674 515-03094 515-03684 515-03104 515-03694 515-03114 515-03704 515-03124 515-03714 515-03134 515-03724 515-03144 515-01946 515-03154 515-01947 515-03164 515-03600 515-03174 515-03611 515-03184 515-03622 515-03194 515-03633 515-03204 515-03644 515-03214 515-03655 515-03224 515-03666 515-03234 515-03677 515-03244 515-03688 515-03254 515-03699 Date of issue: January 2014 515-03264 Please note! Not all products listed on this page may have this approval. For product specific approvals please refer to the Appendix. Further information and products at www.HellermannTyton.co.uk/a249 249
515-02622
1. 物料型号:文档列出了不同尺寸的Helagrip chevron cut电缆标记的型号,例如HGDC1-3、HGDC2-5和HGDC4-9,以及它们对应的产品编号。
2. 器件简介:Helagrip chevron cut是一种用于标记电缆和电线的产品,适用于面板构建、公共交通、公用事业、电信和电气承包等领域。
3. 引脚分配:文档中没有提到具体的引脚分配信息,因为Helagrip chevron cut不是电子元件,而是一种电缆标记产品。
4. 参数特性: - 材料:柔性聚氯乙烯,无镉(PVC) - 工作温度:-65°C至+105°C,间歇性+135°C - 阻燃性:UL94V0(3mm) - 规格:BS-2782-540B, BS 6746C, EC 757, UL224
5. 功能详解: - 一种尺寸的标记可以应用于多种电缆尺寸 - 在受限空间内清晰标识 - 标记在终端制作前应用 - 采用切角设计以确保文本固定 - 传统电线标记有黄色、白色和彩色编码可选 - 材料柔软,可牢固地固定在电线上
6. 应用信息:适用于面板构建、公共交通、公用事业、电信和电气承包等领域。
7. 封装信息:根据标记大小,产品以卷装(HGDC)或塑料袋装(HGBC)供应。
515-02622 价格&库存
很抱歉,暂时无法提供与“515-02622”相匹配的价格&库存,您可以联系我们找货
库存:2000
