HellermannTyton
DATA SHEET
H, TH &HH: Polychloroprene
DESCRIPTION
The H range of tubing is extruded from a specially formulated polychloroprene rubber compound that
offers excellent elastomeric properties, H sleeves are supplied fully severed.
APPLICATION
The sleeves are ideally suited for the binding of cable harnesses where a high degree of expansion
may be required (x 5D whilst fitting and x 2D in service).
It can be used in Aerospace, Automotive, Construction, Consumer Electronics, Defence, Mass Transit
and Telecommunications applications.
PROPERTIES
Properties
Typical Results
Material
Continuous Operating Temp
Intermittent Temperature
Flammability
Oxygen Index
Proof Voltage
Volume Resistivity
Resistance to
Polychloroprene
-65 °C to +95 °C
+120 °C
HB
28.3
4KV
12
10 Ωcm
Acids
Alkalis
Oils
Fuels
Moisture
UV
Ozone
Shelf Life (
很抱歉,暂时无法提供与“600-02068”相匹配的价格&库存,您可以联系我们找货
