111-01666
111-01666
    HELLERMAN(海尔曼太通)
    METAL CONTENT CABLE TIE, 8 LONG
111-01666 数据手册
Cable Ties and Fixings 1.1 Cable Ties Inside Serrated Cable Ties for food industry, detectable The Metal Content Tie is a cable tie specifically designed for use in the food and pharmaceutical processing industries. A unique manufacturing process, involving the inclusion of a metallic pigment, enables even small 'cut-off' sections of the tie to be detected by standard metaldetecting equipment. Ideally suited for the installation of cabling in and around the manufacturing process. Features and Benefits • Total metal dispersion throughout the tie • Available in a wide range of sizes • Usable as part of HACCP process* • Blue colour for easy visual detection • Greatly reduces risk of contamination • Magnetic and X-Ray detectable (detection level depending on specific application) The MCT, metal content cable tie, T-series. MCT-Series L One Step to the Web! W MCT-Series Width (W) Length (L) Bundle Ø max. MCT18R 2.5 100.0 22.0 MCT30R 3.5 150.0 35.0 MCT50R 4.6 202.0 50.0 MCT50L 4.7 380.0 110.0 MCT120R 7.6 387.0 100.0 TYPE Material Colour Pack Cont. Tools Article-No. 80 PA66MP Blue (BU) 100 pcs. 2-11 111-01225 135 PA66MP Blue (BU) 100 pcs. 2-11 111-00829 225 PA66MP Blue (BU) 100 pcs. 2-11 111-00830 225 PA66MP Blue (BU) 100 pcs. 2-11 111-00831 535 PA66MP Blue (BU) 100 pcs. 3;9-12 111-01136 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. MCT-Series releasable TYPE MCTRELK2M Width (W) Length (L) Bundle Ø max. 4.6 250.0 65.0 225 Material Colour Pack Cont. Article-No. PA66MP Blue (BU) 100 pcs. 111-00937 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. Recommended Tools 2 3 4 5 6 7 8 9 10 11 12 MK20 MK21 MK3SP MK3PNSP2 EVO7 MK7HT MK7P MK6 MK9 MK9HT MK9P *HACCP stands for Hazard Analysis Critical Control Points. It is a method of identifying and eliminating potential hazards in food production. Those hazards that cannot be eliminated are controlled in such a way that the consumer is protected. These controls are known as Critical Control Points (CCPs). They are CRITICAL because if they fail or are not carried out, the risk of the product harming the customer increases. FDA HACCP 62 For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.com/fixings Date of issue: October 2015 For more information on toolings please refer to the Application Tooling chapter. Cable Ties and Fixings 1.1 Cable Ties Inside Serrated Cable Ties for food industry, detectable MCTS-Series The Metal Content Tie is a cable tie specifically designed for use in the food and pharmaceutical processing industries. A unique manufacturing process, involving the inclusion of a metallic pigment, enables even small 'cut-off' sections of the tie to be detected by standard metaldetecting equipment. Ideally suited for the installation of cabling in and around the manufacturing process. Features and Benefits • Total metal dispersion throughout the tie • Available in a wide range of sizes • Usable as part of HACCP process* • Blue colour for easy visual detection • Greatly reduces risk of contamination • Magnetic and X-Ray detectable (detection level depending on specific application) • MCTS ties have very good corrosion resistance MCTS ties are highly resistant to corrosion. L W MCT-Series Width (W) Length (L) Bundle Ø max. MCTS100 2.5 100.0 22.0 MCTS150 3.5 153.0 MCTS200 4.7 203.0 MCTS300 4.8 301.0 TYPE Material Colour Pack Cont. Tools Article-No. 60 PA66MP+ Blue (BU) 100 pcs. 2-11 111-01341 36.0 110 PA66MP+ Blue (BU) 100 pcs. 2-11 111-01342 50.0 150 PA66MP+ Blue (BU) 100 pcs. 2-11 111-01343 80.0 150 PA66MP+ Blue (BU) 100 pcs. 2-11 111-01399 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. Material specification please see page 24. More colours on request. Please contact us! Recommended Tools 2 3 4 5 6 7 8 9 10 11 MK20 MK21 MK3SP MK3PNSP2 EVO7 MK7HT MK7P MK6 MK9 MK9HT Date of issue: October 2015 For more information on toolings please refer to the Application Tooling chapter. *HACCP stands for Hazard Analysis Critical Control Points. It is a method of identifying and eliminating potential hazards in food production. Those hazards that cannot be eliminated are controlled in such a way that the consumer is protected. These controls are known as Critical Control Points (CCPs). They are CRITICAL because if they fail or are not carried out, the risk of the product harming the customer increases. HACCP For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.com/fixings 63 Cable Ties and Fixings 1.1 Cable Ties Inside Serrated Cable Ties for food industry, detectable MCT-Series / MCTS-Series PPMP The Metal Content Tie is a cable tie specifically designed for use in the food and pharmaceutical processing industries. A unique manufacturing process, involving the inclusion of a metallic pigment, enables even small 'cut-off' sections of the tie to be detected by standard metaldetecting equipment. Ideally suited for the installation of cabling in and around the manufacturing process. Features and Benefits • High chemical resistance • Floats in different liquids • Unique blue color for easy visual detection • Greatly reduces risk of contamination • Magnetic and X-Ray detectable version available • MCTS tie is highly resistant to corrosion • Usable as part of HACCP process* MCTPP ties will float to the surface of liquids so they can easily be seen and removed. The MCT ties made of PA66MP are the ideal complement for MCMB mounts on page 132. L W MCT-Series Width (W) Length (L) Bundle Ø max. MCTPP18R 2.5 100.0 22.0 85 MCTPP30R 3.5 150.0 35.0 130 MCTPP50R 4.6 200.0 50.0 150 MCTPP50L 4.6 390.0 110.0 150 MCTS200 4.7 202.0 50.0 MCTPP120R 7.6 387.0 100.0 TYPE Colour Pack Cont. Tools Article-No. PPMP Blue (BU) 100 pcs. 2-11 111-01664 PPMP Blue (BU) 100 pcs. 2-11 111-01665 PPMP Blue (BU) 100 pcs. 2-11 111-01666 PPMP Blue (BU) 100 pcs. 2-11 111-01667 140 PPMP+ Blue Grey (BUGY) 100 pcs. 2-11 111-01386 380 PPMP Blue (BU) 100 pcs. 3;9-12 111-01668 Material All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. Recommended Tools 2 3 4 5 6 7 8 9 10 11 12 MK20 MK21 MK3SP MK3PNSP2 EVO7 MK7HT MK7P MK6 MK9 MK9HT MK9P *HACCP stands for Hazard Analysis Critical Control Points. It is a method of identifying and eliminating potential hazards in food production. Those hazards that cannot be eliminated are controlled in such a way that the consumer is protected. These controls are known as Critical Control Points (CCPs). They are CRITICAL because if they fail or are not carried out, the risk of the product harming the customer increases. FDA HACCP 64 For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.com/fixings Date of issue: October 2015 For more information on toolings please refer to the Application Tooling chapter. Cable Ties and Fixings 1.0 Material Information Material Specification Overview Material Shortcut Operating Temperature Aluminium-alloy AL -40 °C to +180 °C Natural (NA) • Corrosion resistant • Antimagnetic Chloroprene CR -20 °C to +80 °C Black (BK) • Weather-resistant • High yield strength Ethylene Tetrafluoroethylene E/TFE -80 °C to +170 °C Blue (BU) UL94 V0 Polyacetal POM -40 °C to +90 °C, (+110 °C, 500 h) Natural (NA) UL94 HB Polyamide 11 PA11 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 HB Polyamide 12 PA12 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Good chemical resistance to: acids, bases, oxidizing agents • UV-resistant Polyamide 4.6 PA46 -40 °C to +150 °C (5000 h), +195 °C (500 h) Natural (NA), Grey (GY) UL94 V2 • Resistance to high temperatures • Very moisture sensitive • Low smoke sensitive Polyamide 6 PA6 -40 °C to +80 °C Black (BK) UL94 V2 • High yield strength PA6HIR -40 °C to +80 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature Polyamide 6.6 PA66 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK), Natural (NA) UL94 V2 • High yield strength Polyamide 6.6, PA66GF13, PA66GF15 -40 °C to +105 °C Black (BK) UL94 HB • Good resistance to: lubricants, vehicle fuel, salt water and many solvents PA66HSW -40 °C to +105 °C Black (BK) UL94 V2 • High yield strength • Modified elevated max. temperature • UV-resistant Polyamide 6.6, heat stabilised PA66HS -40 °C to +105 °C Black (BK), Natural (NA) UL94 V2 • High yield strength • Modified elevated max. temperature Polyamide 6.6, high impact modified PA66HIR -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL94 HB Polyamide 6.6, high impact modified, heat and UV stabilised PA66HIRHSW -40 °C to +110 °C Black (BK) UL94 HB Polyamide 6.6, high impact modified, heat stabilised PA66HIRHS -40 °C to +105 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature Polyamide 6.6, high impact modified, scan black PA66HIR(S) -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature PA66W -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 V2 • High yield strength • UV-resistant Polyamide 6, high impact modified glass-fibre reinforced Polyamide 6.6, heat and UV stabilised Polyamide 6.6, UV-resistant Colour** Material Properties* Flammability Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers. • Resistance to radioactivity • UV-resistant, not moisture sensitive • Good chemical resistance to: acids, bases, oxidizing agents • Limited brittleness sensitivity • Flexible at low temperature • Not moisture sensitive • Robust on impacts • Bio-plastic, derived from vegetable oil • Strong impact resistance at low temperature • Very low moisture absorption • Weather-resistant • Good chemical resistance • Limited brittleness sensitivity • Higher flexibility at low temperature • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature • High yield strength, UV-resistant **More colours on request. *These details are only rough guide values. They should be regarded as a material specification and are no substitute for a suitability test. Please see our datasheets for further details. HF = Halogenfree LFH = Limited Fire Hazard RoHS = Restriction of Hazardous Substances 24 Material Specifications Further information at www.HellermannTyton.com/fixings Date of issue: October 2015 MATERIAL Cable Ties and Fixings Material Information Material Shortcut Operating Temperature Polyamide 6.6, with metal particles PA66MP Polyamide 6.6 V0 MATERIAL Material Properties* Colour** Flammability -40 °C to +85 °C, (+105 °C, 500 h) Blue (BU) UL94 HB • High yield strength • Metal and X-Ray detectable PA66V0 -40 °C to +85 °C White (WH) UL94 V0 • High yield strength • Low smoke emission PA66V0-HOI -40 °C to +85 °C, (+105 °C, 500 h) White (WH) UL94 V0 • High yield strength • Low smoke emissions SP -50 °C to +150 °C Black (BK) Halogen free • UV-resistant • Good chemical resistance to: most acids, alkalis and oils PEEK -55 °C to +240 °C Beige (BGE) UL94 V0 • Resistance to radioactivity • Not moisture sensitive • Good chemical resistance to: acids, bases, oxidizing agents Polyethylene PE -40 °C to +50 °C Black (BK), Grey (GY) UL94 HB • Low moisture absorption • Good chemical resistance to: most acids, alcohol and oils Polyolefin PO -40 °C to +90 °C Black (BK) UL94 V0 • Low smoke emissions Polypropylene PP -40 °C to +115 °C Black (BK), Natural (NA) UL94 HB • Floats in water • Moderate yield strength • Good chemical resistance to: organic acids PP, EPDM -20 °C to +95 °C Black (BK) UL94 HB • Good resistance to high temperatures • Good chemical and abrasion resistance Polyamide 6.6 V0, High Oxygen Index Polyester Polyetheretherketone Polypropylene, EthylenePropylene-DienTerpolymere-rubber free of Nitrosamine Polypropylene with metal particles PPMP -40 °C to +115 °C Blue (BU) UL94 HB • Floats in certain liquids • Metal and X-Ray detectable • Heat resistant • Moderate yield strength • Good chemical resistance Polyvinylchloride PVC -10 °C to +70 °C Black (BK), Natural (NA) UL94 V0 • Low moisture absorption • Good chemical resistance to: acids, ethanol and oil Stainless Steel, Stainless Steel SS304, SS316 -80 °C to +538 °C Natural (NA) Non burning • Corrosion resistant • Antimagnetic • Weather resistant • Outstanding chemical resistance Thermoplastic Polyurethane TPU -40 °C to +85 °C Black (BK) UL94 HB • High elasticity • Good chemical resistance to: acids, bases and oxidizing agents Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers. 1.0 Material Specifications **More colours on request. Date of issue: October 2015 *These details are only rough guide values. They should be regarded as a material specification and are no substitute for a suitability test. Please see our datasheets for further details. HF = Halogenfree LFH = Limited Fire Hazard RoHS = Restriction of Hazardous Substances Further information at www.HellermannTyton.com/fixings 25
111-01666 价格&库存
很抱歉,暂时无法提供与“111-01666”相匹配的价格&库存,您可以联系我们找货
  • 100+2.44972100+0.31753
  • 500+2.19690500+0.28476
  • 1000+1.952801000+0.25312
库存:200
