111-12032
111-12032
    HELLERMAN(海尔曼太通)
    HELLERMANNTYTON - 111-12032 - Cable Tie, Nylon 6.6 HIR(S) (Polyamide 6.6 HIR(S)) (ScanBlack), Black,...
111-12032 数据手册
Cable Ties and Fixings 1.1 Cable Ties Inside Serrated Cable Ties for higher impact resistant Polyamide 6.6 ScanBlack T-Series in PA66HIR(S) black Impact resistance T-Series cable ties are manufactured from PA66HIR(S) – an impact modified material formulation. This high performance material offers limited brittleness sensitivity and a higher flexibility even at low temperatures. PA66HIR(S) cable ties meet increasing requirements like in the chemical, medical and/or automotive industry. Features and benefits • Impact resistant cable tie in black colour • For bundling and securing cables, pipes and hoses • Available in different sizes • Higher flexibility especially in cold environments • Limited brittleness sensitivity Impact resistant T-Series cable tie (PA66HIR(S)). Material specification please see page 26. L W T-Series TYPE Width (W) Length (L) Bundle Ø max. T50R 4.6 200.0 50.0 225 Material Colour Pack Cont. Tools Article-No. PA66HIR(S) Black (BK) 100 pcs. 2-10 111-04890 T50I 4.6 300.0 85.0 225 PA66HIR(S) Black (BK) 100 pcs. 2-10 111-00222 T50L 4.6 390.0 110.0 225 PA66HIR(S) Black (BK) 100 pcs. 2-10 111-05441 T120I 7.6 300.0 80.0 535 PA66HIR(S) Black (BK) 100 pcs. 3;9-12 111-12203 T120R(E) 7.6 387.0 100.0 535 PA66HIR(S) Black (BK) 100 pcs. 3;9-12 111-12032 T120L 7.6 760.0 225.0 535 PA66HIR(S) Black (BK) 50 pcs. 3;9-12 111-12402 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. Recommended Tools 2 3 4 5 6 7 8 9 10 11 12 MK20 MK21 MK3SP MK3PNSP2 EVO7 MK7HT MK7P MK6 EVO9 EVO9HT MK9P 545 545 546 546 548 549 550 551 549 549 552 For product specific approvals and specifications please refer to the Appendix. 48 Further information at www.HellermannTyton.co.uk/fixings Date of issue: January 2019 For more information on toolings please refer to the Application Tooling chapter. Cable Ties and Fixings 1.0 Material Information Material Specification Overview Material Shortcut Operating Temperature Colour** Aluminium alloy AL -40 °C to +180 °C Natural (NA) • Corrosion resistant • Antimagnetic Chloroprene rubber CR -20 °C to +80 °C Black (BK) • Weather resistant • High yield strength Ethylene Tetrafluoroethylene (Tefzel®) E/TFE -80 °C to +170 °C Blue (BU) UL 94 V0 Polyacetal POM -40 °C to +90 °C, (+110 °C, 500 h) Natural (NA) UL 94 HB Polyamide 11 PA11 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL 94 HB Polyamide 12 PA12 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL 94 HB • Good chemical resistance to acids, bases, oxidizing agents • UV resistant Polyamide 4.6 PA46 -40 °C to +130 °C, Natural (NA), (+150 °C, 5000 h; Grey (GY) +195 °C, 500 h) UL 94 V2 • Resistance to high temperatures • Very moisture sensitive • Low smoke sensitivity Polyamide 6 PA6 -40 °C to +80 °C Black (BK) UL 94 V2 • High yield strength PA6HIR -40 °C to +80 °C Black (BK) UL 94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature PA66 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK), Natural (NA) UL 94 V2 • High yield strength Polyamide 6.6 glass-fibre reinforced PA66GF13, PA66GF15 -40 °C to +105 °C Black (BK) UL 94 HB • Good resistance to lubricants, fuels, salt water and solvents Polyamide 6.6 heat and UV stabilised PA66HSW -40 °C to +105 °C Black (BK) UL 94 V2 • High yield strength • Modified elevated maximum temperature • UV resistant Polyamide 6.6 heat stabilised PA66HS -40 °C to +105 °C Black (BK), Natural (NA) UL 94 V2 • High yield strength • Modified elevated maximum temperature Polyamide 6.6 high impact modified PA66HIR -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL 94 HB PA66HIRHSW -40 °C to +110 °C Black (BK) UL 94 HB Polyamide 6 high impact modified Polyamide 6.6 Polyamide 6.6 high impact modified, heat and UV stabilised Material Properties* Material Specifications • Resistance to radioactivity • UV resistant, not moisture sensitive • Good chemical resistance to acids, bases, oxidizing agents • Limited brittleness sensitivity • Flexible at low temperature • Not moisture sensitive • Robust on impact • Bio-plastic, derived from vegetable oil • Strong impact resistance at low temperature • Very low moisture absorption • Weather resistant • Good chemical resistance • Limited brittleness sensitivity • Higher flexibility at low temperature • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated maximum temperature • High yield strength, UV resistant • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated maximum temperature Polyamide 6.6 high impact modified, heat stabilised PA66HIRHS -40 °C to +105 °C Black (BK) UL 94 HB Polyamide 6.6 high impact modified, scan black PA66HIR(S) -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL 94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature PA66W -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL 94 V2 • High yield strength • UV resistant Polyamide 6.6 UV resistant 26 Flammability Further information at www.HellermannTyton.co.uk/fixings Date of issue: January 2019 MATERIAL Cable Ties and Fixings Material Information Material Shortcut Operating Temperature Polyamide 6.6 with metal particles PA66MP Polyamide 6.6 with metal particles Polyamide 6.6 V0 MATERIAL Colour** Flammability -40 °C to +85 °C, (+105 °C, 500 h) Blue (BU) UL 94 HB • High yield strength • Metal and X-Ray detectable PA66MP+ -40 °C to +85 °C Blue (BU) not flame retardant • High yield strength • Metal and X-Ray detectable PA66V0 -40 °C to +85 °C White (WH) UL 94 V0 • High yield strength • Low smoke emission SP -50 °C to +150 °C Black (BK) PEEK -55 °C to +240 °C Beige (BGE) UL 94 V0 • Resistance to radioactivity • Not moisture sensitive • Good chemical resistance to acids, bases, oxidising agents Polyethylene PE -40 °C to +50 °C Black (BK), Grey (GY) UL 94 HB • Low moisture absorption • Good chemical resistance to most acids, bases, alcohol, oils Polyolefin PO -40 °C to +90 °C Black (BK) UL 94 V0 • Low smoke emissions Polypropylene PP -40 °C to +115 °C Black (BK), Natural (NA) UL 94 HB • Floats in water • Moderate yield strength • Good chemical resistance to acids, bases and solvents PP, EPDM -20 °C to +95 °C Black (BK) UL 94 HB • Good resistance to high temperature • Good chemical and abrasion resistance Polypropylene with metal particles PPMP -40 °C to +115 °C Blue (BU) UL 94 HB • Metal and X-Ray detectable • Heat resistant • Moderate yield strength • Good chemical resistance Polypropylene with metal particles PPMP+ -40 °C to +85 °C Blue (BU) not flame retardant • High yield strength • Metal and X-Ray detectable Polyvinylchloride PVC -10 °C to +70 °C Black (BK), Natural (NA) Stainless Steel, Stainless Steel SS304, SS316 -80 °C to +538 °C Natural (NA) Thermoplastic Polyurethane TPU -40 °C to +85 °C Black (BK) Polyester Polyetheretherketone Polypropylene, Ethylene Propylene Diene Terpolymer rubber free of Nitrosamine Material Properties* 1.0 Material Specifications • UV resistant • Good chemical resistance to most acids, bases and oils • Low moisture absorption • Good chemical resistance to acids, bases, salts, alcohol, oils • Corrosion resistant • Antimagnetic • Weather resistant Non burning • Chemical resistance • SS316 also resistant against seawater, salt spray and anorganic acids UL 94 V0 UL 94 HB Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton also uses equivalent E/TFE raw material from other suppliers. • High elasticity • Good chemical resistance to acids, bases and oxidising agents **Further colours available on request. Date of issue: January 2019 *These details are only guide values. They should not be regarded as a exhaustive material specification and are no substitute for suitability tests. Please see our datasheets for further details. HF = Halogenfree LFH = Limited Fire Hazard RoHS = Restriction of Hazardous Substances Further information at www.HellermannTyton.co.uk/fixings 27
111-12032 价格&库存
很抱歉,暂时无法提供与“111-12032”相匹配的价格&库存,您可以联系我们找货
