111-85479
111-85479
    HELLERMAN(海尔曼太通)
    HELLERMANNTYTON - T50SL7-NAT(100 PACK) - CABLE TIE, NATURAL, 165MM, PK100
111-85479 数据手册
T50SL7 - Arrowhead Fixing Ties 1 - HellermannTyton 1 of 2 http://www.hellermanntyton.co.uk/BaseCMP/pages/contentdelivery?... United Kingdom T50SL7 111-85479 The arrowhead design, in conjunction with the supporting legs or disc, ensure a firm and secure fixing. The disc or legs take up any variation in panel thickness enabling one part to suit many applications. Both the RT and FBS versions are releasable and reusable and the FBS type have the added feature of a ladder type strap as opposed to the conventional serrated strap - this ladder type strap has the benefit of being very flexible. With a diverse range of fixing possibilities (from 4.4mm to 8.0mm hole diameters and 0.5mm to 8.0mm panel thickness) this range of fixing ties is ideal for use in many different industries, including automotive, aerospace and panel building. Base Data Colour Natural (NA) Package Content 500 Quantity (Sold Unit / EDP) 500 Recommended Application Tool MK20, MK3PNSP2, MK3SP, MK7P, MK7 Logisitic and Packaging Carton Quantity 4000 EAN code 4031026107325 Quantity of Europallet 72000 UPC 08930620756 Weight (kg) (Metric) 3.2 kg Material and Specifications Flammability UL94 V2 Material Polyamide 6.6 (PA66) Material Shortcut PA66 Operating Temperature (Metric) -40 °C to +85 °C Continuous, (+105 °C for 500 h) ROHS Conformity TRUE Product Dimensions Bundle Diameter max (Imperial) 1.34 " Bundle Diameter max (Metric) 34 mm Bundle Diameter min (Imperial) .06 " Bundle Diameter min (Metric) 1.5 mm 08/08/2006 14:04 T50SL7 - Arrowhead Fixing Ties 1 - HellermannTyton 2 of 2 http://www.hellermanntyton.co.uk/BaseCMP/pages/contentdelivery?... Disc Diameter (Imperial) .73 " Disc Diameter (Metric) 18.5 mm Fixing Hole Diameter D max (Imperial) .28 " Fixing Hole Diameter D min (Imperial) .27 " Height H (Imperial) .40 " Height H (Metric) 10.0 mm Hole 6.9-7.1 Length L (Imperial) 6.50 " Length L (Metric) 165 mm Minimum Tensile Strength (imperial) 50 Minimum Tensile Strength (N) 225 Panel Thickness max. 2.5 Panel Thickness max. (imperial) .10 " Panel Thickness min. 0.8 Panel Thickness min. (imperial) .03 " Width W (Imperial) .18 " Width W (Metric) 4.6 © HellermannTyton 2006 08/08/2006 14:04
111-85479 价格&库存
很抱歉,暂时无法提供与“111-85479”相匹配的价格&库存,您可以联系我们找货
