MBT8S
Article Number: 111-93089
Stainless Steel Tie, 7.9" Long, 202lb Tensile Strength, SS316, Metal, 100/pkg
Download spec sheet
Base Data
Local Order Number MBT8S
Type MBT8S
Color Metal (ML)
Features and Benefits • 316 grade stainless steel offers excellent resistance to salt spray, corrosion, weather and chemical resistance.
• Ball bearing locking mechanism assures high tensile strength and easy insertion.
Product Description HellermannTyton’s stainless steel ties are designed with a ball bearing locking mechanism to assure high tensile
strength and easy insertion when securing hoses, cables, pipes and more. Available in 304 or 316 grades of
stainless steel, providing protection when used in corrosive environments, fire resistance and temperature extremes.
Short Description Stainless Steel Tie, 7.9" Long, 202lb Tensile Strength, SS316, Metal, 100/pkg
Product Dimensions
Minimum Tensile Strength (Imperial) 202.0 lbs
Minimum Tensile Strength (Metric) 900.0 N
Length L (Imperial) 7.9 "
Length L (Metric) 201.0 mm
Fixation Method None
Identification Plate Position none
Releasable Closure No
Tie Closure ball bearing lock
Variant No Serration
Width W (Imperial) 0.18 "
Width W (Metric) 4.6 mm
Bundle Diameter Min. (Imperial) 0.47 "
Bundle Diameter Min. (Metric) 12.0 mm
Bundle Diameter Max. (Imperial) 2.0 "
Bundle Diameter Max. (Metric) 50.0 mm
Thickness T (Imperial) 0.01 "
Thickness T (Metric) 0.3 mm
Logistics and Packaging
Quantity Per bag
Package Quantity (Metric) 100 Pieces
Carton Quantity 1 Pieces
Weight (Metric) 6 kg
Material and Specifications
Material Stainless Steel (SS316)
Material Shortcut SS316
Flammability non-burning
Halogenfree Yes
Operating Temperature -112°F to +1000°F (-80°C to +538°C)
ROHS Compliant Yes
Certification/Specification Det Norske Veritas
ABS
GL
BV
© HellermannTyton 2015
很抱歉,暂时无法提供与“111-93089”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+8.3691410+1.08480
- 100+7.23582100+0.93790
- 500+6.97429500+0.90400
