126-02202
126-02202
    HELLERMAN(海尔曼太通)
    HELLERMANNTYTON - 126-02202 - Cable Tie, Nylon 6.6 (Polyamide 6.6), Natural, 135 mm, 4.6 mm, 27 mm, ...
126-02202 数据手册
T50SSL5 - Arrowhead Fixing Ties 1 - HellermannTyton 1 of 2 http://www.hellermanntyton.co.uk/BaseCMP/pages/contentdelivery?... United Kingdom T50SSL5 126-02203 The arrowhead design, in conjunction with the supporting legs or disc, ensure a firm and secure fixing. The disc or legs take up any variation in panel thickness enabling one part to suit many applications. Both the RT and FBS versions are releasable and reusable and the FBS type have the added feature of a ladder type strap as opposed to the conventional serrated strap - this ladder type strap has the benefit of being very flexible. With a diverse range of fixing possibilities (from 4.4mm to 8.0mm hole diameters and 0.5mm to 8.0mm panel thickness) this range of fixing ties is ideal for use in many different industries, including automotive, aerospace and panel building. Base Data Colour Natural (NA) Package Content 500 Quantity per Bag Recommended Application Tool MK20, MK3PNSP2, MK3SP, MK7P, MK7 Material and Specifications Flammability UL94 V2 Material Polyamide 6.6 (PA66) Material Shortcut PA66 Operating Temperature (Metric) -40 °C to +85 °C Continuous, (+105 °C for 500 h) ROHS Conformity TRUE Product Dimensions Bundle Diameter max (Metric) 27 Bundle Diameter min (Metric) 1.5 Height H (Metric) 10 Hole 6.1-6.5 Length L (Metric) 135 Minimum Tensile Strength (N) 225 Panel Thickness max. 2.7 Panel Thickness min. 0.8 Width W (Metric) 4.6 08/08/2006 14:04 T50SSL5 - Arrowhead Fixing Ties 1 - HellermannTyton 2 of 2 http://www.hellermanntyton.co.uk/BaseCMP/pages/contentdelivery?... © HellermannTyton 2006 08/08/2006 14:04
126-02202
物料型号:T50SSL5 器件简介:Arrowhead Fixing Ties,箭头设计结合支撑腿或圆盘,确保牢固和安全的固定。圆盘或腿可以适应面板厚度的变化,使一个部件适用于多种应用。 引脚分配:未提供 参数特性: - 颜色:自然色(NA) - 包装内容:500个/袋 - 推荐应用工具:MK20, MK3PNSP2, MK3SP, MK7P, MK7 - 材料:聚酰胺6.6(PA66) - 材料缩写:PA66 - 耐燃性:UL94 V2 - 工作温度:-40°C至+85°C连续,+105°C下500小时 - 符合RoHS标准:是 - 产品尺寸:最大束径27mm,最小束径1.5mm,高度H 10mm,孔径6.1-6.5mm,长度L 135mm - 最小拉伸强度:225N - 最大面板厚度:2.7mm - 最小面板厚度:0.8mm - 宽度W:4.6mm 功能详解:适用于多种固定可能性(孔径从4.4mm到8.0mm,面板厚度从0.5mm到8.0mm),适用于汽车、航空和面板建筑等多种行业。 应用信息:适用于多种行业,包括汽车、航空和面板建筑。 封装信息:未提供
126-02202 价格&库存
很抱歉,暂时无法提供与“126-02202”相匹配的价格&库存,您可以联系我们找货
