148-00135
148-00135
    HELLERMAN(海尔曼太通)
    Cable Tie, TPU (Thermoplastic Polyurethane), Natural, 250 mm, 16.2 mm
148-00135 数据手册
The Diamond Lock Tie (DLK-Series) Overview A soft, flexible and versatile fastening solution suitable for a wide range of applications. DLK-Series ties offer an excellent general purpose fastening that is both releasable and reusable, whilst protecting cables from chafing and damage with its soft-grip strap. Features & Benefits  Quick & easy to apply – automatic self-locking feature making installation simple  Provides a strong, durable fastening – the flexible nonslip design provides a secure grip for a wide range of applications  Innovative design allows full adjustment once applied – can also be released quickly and easily  Good UV resistance – suitable for both indoor and outdoor use  Flexible fastening options – can be applied in a single or double loop orientation, or for multiple bundles The Diamond Lock Tie (DLK-Series) Markets & Applications  Securing cables and wiring harnesses during transportation or movement  Protective fastening solution for data cables or for securely holding soft bundles  Ideal for general purpose or temporary applications that require a releasable fastening, or where the addition or removal of cables is required. Product Data Tensile strength figures are for guidance only. This will be dependant on the application of the product, its age and number of times used / stretched. Material Properties  Excellent strength and tear resistance  Excellent resistance to abrasion, hydrolysis failure and oxidation  Good stability against solvents  Good UV resistance
148-00135 价格&库存
很抱歉,暂时无法提供与“148-00135”相匹配的价格&库存,您可以联系我们找货
