150-77941
150-77941
    HELLERMAN(海尔曼太通)
    HELLERMANNTYTON - 150-77941 - Cable Tie, Nylon 6.6 HS (Polyamide 6.6 HS) (Heat Stabilised), Black, 2...
150-77941 数据手册
Cable Ties and Fixings 1.6 Cable Ties With Fixing Elements 2-Piece Fixing Ties with Fir Tree, with Disc, for Round Holes Fir Tree Parts FT6 L L W T30RFT6 T30RFT6 TYPE Drawing Hole Ø (FH) Bundle Panel Width Length Ø Thickness (W) (L) max. Disc Ø Material Cable Material Tie Foot Part PEEK Colour Tools Article-No. Beige (BGE), 2;4-6 156-01336 Grey (GY) PT2AFT6LG 6.4 - 7.1 0.8 - 6.0 3.4 145.0 35.0 230 16.0 PA46 T30RFT6LG 6.4 - 7.1 0.8 - 6.0 3.5 150.0 30.0 135 16.0 PA66HS PA66HIRHS Black (BK) 2;4-6 150-31090 T50ROSFT6LG 6.4 - 7.1 0.8 - 6.0 4.6 200.0 45.0 225 16.0 PA66HS PA66HIRHS Black (BK) 2;4-8 150-31099 T50RFT6LG 6.4 - 7.1 0.8 - 6.0 4.6 202.0 45.0 225 16.0 PA66HS PA66HIRHS Black (BK) 2-10 150-31091 T80IFT6LG 6.4 - 7.1 0.8 - 6.0 4.6 300.0 81.0 356 16.0 PA66HS PA66HIRHS Black (BK) 2-12 150-31096 T30RFT6SD 6.4 - 7.1 0.8 - 3.0 3.6 148.0 35.0 135 16.0 PA66HS PA66HIRHS Black (BK) 2;4-6 150-52690 T50ROS FT6SD 6.4 - 7.1 0.8 - 3.0 4.6 200.0 45.0 225 16.0 6.4 - 7.1 0.8 - 3.0 4.6 200.0 46.0 225 16.0 PA66HS 6.25 - 6.75, 6.1 - 6.6 0.7 - 5.0 (hexagonal) 4.6 202.0 45.0 225 16.0 PA66HS PA66HIRHS Black (BK) 2-10 156-01705 4.6 160.0 30.0 225 16.0 PA66HS PA66HIRHS Black (BK) 2-10 156-00154 T50RFT6 LGSD-HEX T50SFT6 LG1SD 6.5 - 7.0 0.6 - 6.0 PA46 PA46 Grey (GY) 2-10 156-00085 PA66HIR Black (BK) 2-10 156-05902 T30RFT6 6.4 - 7.1 0.8 - 3.0 3.5 150.0 30.0 135 16.0 PA66HS PA66HIRHS Black (BK) 2;4-6 150-77950 T50ROSFT6 6.4 - 7.1 0.8 - 3.0 4.6 200.0 45.0 225 16.0 PA66HS PA66HIRHS Black (BK) 2-10 156-00076 T50RFT6 6.4 - 7.1 0.8 - 3.0 4.6 202.0 45.0 225 16.0 PA66HS T50RDHFT6 6.4 - 7.1 0.8 - 3.0 4.7 210.0 19.0 180 16.0 PA66HS PA66HIRHS Black (BK) 2-10 150-77936 PT2AFT6 6.4 - 7.1 0.8 - 3.0 3.4 145.0 35.0 230 16.0 PEEK PA46 Beige (BGE), 2;4-6 156-00890 Grey (GY) T50RFT6 6.4 - 7.1 0.8 - 3.0 4.6 202.0 45.0 225 16.0 PA46 PA46 Grey (GY) 2-10 156-01693 PA66 Black (BK) 2-10 150-77941 All dimensions in mm. Subject to technical changes. Recommended Tools 2 3 4 5 6 7 8 9 10 11 12 MK20 MK21 MK3SP MK3PNSP2 EVO7 MK7HT MK7P MK6 EVO9 EVO9HT MK9P 545 545 546 546 548 549 550 551 549 549 552 Date of issue: January 2019 For more information on toolings please refer to the Application Tooling chapter. Further information at www.HellermannTyton.co.uk/fixings 109 Cable Ties and Fixings 1.0 Material Information Material Specification Overview Material Shortcut Operating Temperature Colour** Aluminium alloy AL -40 °C to +180 °C Natural (NA) • Corrosion resistant • Antimagnetic Chloroprene rubber CR -20 °C to +80 °C Black (BK) • Weather resistant • High yield strength Ethylene Tetrafluoroethylene (Tefzel®) E/TFE -80 °C to +170 °C Blue (BU) UL 94 V0 Polyacetal POM -40 °C to +90 °C, (+110 °C, 500 h) Natural (NA) UL 94 HB Polyamide 11 PA11 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL 94 HB Polyamide 12 PA12 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL 94 HB • Good chemical resistance to acids, bases, oxidizing agents • UV resistant Polyamide 4.6 PA46 -40 °C to +130 °C, Natural (NA), (+150 °C, 5000 h; Grey (GY) +195 °C, 500 h) UL 94 V2 • Resistance to high temperatures • Very moisture sensitive • Low smoke sensitivity Polyamide 6 PA6 -40 °C to +80 °C Black (BK) UL 94 V2 • High yield strength PA6HIR -40 °C to +80 °C Black (BK) UL 94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature PA66 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK), Natural (NA) UL 94 V2 • High yield strength Polyamide 6.6 glass-fibre reinforced PA66GF13, PA66GF15 -40 °C to +105 °C Black (BK) UL 94 HB • Good resistance to lubricants, fuels, salt water and solvents Polyamide 6.6 heat and UV stabilised PA66HSW -40 °C to +105 °C Black (BK) UL 94 V2 • High yield strength • Modified elevated maximum temperature • UV resistant Polyamide 6.6 heat stabilised PA66HS -40 °C to +105 °C Black (BK), Natural (NA) UL 94 V2 • High yield strength • Modified elevated maximum temperature Polyamide 6.6 high impact modified PA66HIR -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL 94 HB PA66HIRHSW -40 °C to +110 °C Black (BK) UL 94 HB Polyamide 6 high impact modified Polyamide 6.6 Polyamide 6.6 high impact modified, heat and UV stabilised Material Properties* Material Specifications • Resistance to radioactivity • UV resistant, not moisture sensitive • Good chemical resistance to acids, bases, oxidizing agents • Limited brittleness sensitivity • Flexible at low temperature • Not moisture sensitive • Robust on impact • Bio-plastic, derived from vegetable oil • Strong impact resistance at low temperature • Very low moisture absorption • Weather resistant • Good chemical resistance • Limited brittleness sensitivity • Higher flexibility at low temperature • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated maximum temperature • High yield strength, UV resistant • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated maximum temperature Polyamide 6.6 high impact modified, heat stabilised PA66HIRHS -40 °C to +105 °C Black (BK) UL 94 HB Polyamide 6.6 high impact modified, scan black PA66HIR(S) -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL 94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature PA66W -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL 94 V2 • High yield strength • UV resistant Polyamide 6.6 UV resistant 26 Flammability Further information at www.HellermannTyton.co.uk/fixings Date of issue: January 2019 MATERIAL Cable Ties and Fixings Material Information Material Shortcut Operating Temperature Polyamide 6.6 with metal particles PA66MP Polyamide 6.6 with metal particles Polyamide 6.6 V0 MATERIAL Colour** Flammability -40 °C to +85 °C, (+105 °C, 500 h) Blue (BU) UL 94 HB • High yield strength • Metal and X-Ray detectable PA66MP+ -40 °C to +85 °C Blue (BU) not flame retardant • High yield strength • Metal and X-Ray detectable PA66V0 -40 °C to +85 °C White (WH) UL 94 V0 • High yield strength • Low smoke emission SP -50 °C to +150 °C Black (BK) PEEK -55 °C to +240 °C Beige (BGE) UL 94 V0 • Resistance to radioactivity • Not moisture sensitive • Good chemical resistance to acids, bases, oxidising agents Polyethylene PE -40 °C to +50 °C Black (BK), Grey (GY) UL 94 HB • Low moisture absorption • Good chemical resistance to most acids, bases, alcohol, oils Polyolefin PO -40 °C to +90 °C Black (BK) UL 94 V0 • Low smoke emissions Polypropylene PP -40 °C to +115 °C Black (BK), Natural (NA) UL 94 HB • Floats in water • Moderate yield strength • Good chemical resistance to acids, bases and solvents PP, EPDM -20 °C to +95 °C Black (BK) UL 94 HB • Good resistance to high temperature • Good chemical and abrasion resistance Polypropylene with metal particles PPMP -40 °C to +115 °C Blue (BU) UL 94 HB • Metal and X-Ray detectable • Heat resistant • Moderate yield strength • Good chemical resistance Polypropylene with metal particles PPMP+ -40 °C to +85 °C Blue (BU) not flame retardant • High yield strength • Metal and X-Ray detectable Polyvinylchloride PVC -10 °C to +70 °C Black (BK), Natural (NA) Stainless Steel, Stainless Steel SS304, SS316 -80 °C to +538 °C Natural (NA) Thermoplastic Polyurethane TPU -40 °C to +85 °C Black (BK) Polyester Polyetheretherketone Polypropylene, Ethylene Propylene Diene Terpolymer rubber free of Nitrosamine Material Properties* 1.0 Material Specifications • UV resistant • Good chemical resistance to most acids, bases and oils • Low moisture absorption • Good chemical resistance to acids, bases, salts, alcohol, oils • Corrosion resistant • Antimagnetic • Weather resistant Non burning • Chemical resistance • SS316 also resistant against seawater, salt spray and anorganic acids UL 94 V0 UL 94 HB Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton also uses equivalent E/TFE raw material from other suppliers. • High elasticity • Good chemical resistance to acids, bases and oxidising agents **Further colours available on request. Date of issue: January 2019 *These details are only guide values. They should not be regarded as a exhaustive material specification and are no substitute for suitability tests. Please see our datasheets for further details. HF = Halogenfree LFH = Limited Fire Hazard RoHS = Restriction of Hazardous Substances Further information at www.HellermannTyton.co.uk/fixings 27
150-77941 价格&库存
很抱歉,暂时无法提供与“150-77941”相匹配的价格&库存,您可以联系我们找货
    • 500+5.70999500+0.74228
    • 2500+5.247982500+0.68222
    • 7500+4.608277500+0.59906
    库存:6500
