Insulation
Heat Shrinkable Tubing
2.1
Heat Shrinkable Cable Repair Sleeves
RMS
RMS wrap-around sleeves are easy to install.
Features and Benefits
• Fast, moisture proof and permanent repair of cable jackets
• Only 6 sizes for a wide range of cable diameters: from 10 mm
up to 160 mm
• Available in 4 standard lengths, custom lengths available on request
• Each RMS kit is ready for use and comes with instruction sheet,
abrasive strip and cleaning sachet
• Weather resistant and halogen free
• TCP (thermo-chromatic paint) spots indicate the sleeve has been
sufficiently heated
RMS wrap-around sleeves for rapid and secure cable repair on site.
Application video: RMS
MATERIAL
Polyolefin, Chemically cross-linked (PO-X)
Shrink Ratio
up to 4.5:1
Operating Temperature
-40 °C to +120 °C
Minimum Shrink
Temperature
+110 °C
Softening Point
Adhesive
+105 °C
Longitudinal change
after shrinkage
-10 % max.
Dielectric Strength
30 kV/mm
Flammability
not flame retarded
RMS: Repair sleeve, steel closure, abrasive strip, cleaning sachet, instruction sheet.
INFO
Cable Repair Sleeve RMS with adhesive
TYPE
RMS 43-10
Date of issue: October 2015
RMS 52-15
RMS 76-22
RMS 100-30
Supplied
Ø D min.
Recov.
Ø d max.
Wall
(WT)
Suitable for
Cable Ø
from/to
Length
(L)
Colour
Article-No.
43
10.0
2.30
15 - 35
250.0
Black (BK)
450-20000
43
10.0
2.30
15 - 35
500.0
Black (BK)
450-20001
43
10.0
2.30
15 - 35
750.0
Black (BK)
450-20004
43
10.0
2.30
15 - 35
1,000.0
Black (BK)
450-20002
52
15.0
2.30
20 - 45
250.0
Black (BK)
450-20010
52
15.0
2.30
20 - 45
500.0
Black (BK)
450-20011
52
15.0
2.30
20 - 45
750.0
Black (BK)
450-20014
52
15.0
2.30
20 - 45
1,000.0
Black (BK)
450-20012
76
22.0
2.50
28 - 65
500.0
Black (BK)
450-20021
76
22.0
2.50
28 - 65
750.0
Black (BK)
450-20024
76
22.0
2.50
28 - 65
1,000.0
Black (BK)
450-20022
100
30.0
2.54
35 - 85
500.0
Black (BK)
450-20030
100
30.0
2.54
35 - 85
1,000.0
Black (BK)
450-20031
RMS 139-38
139
38.0
2.77
45 - 120
1,000.0
Black (BK)
450-20041
RMS 185-55
185
55.0
2.74
65 - 160
1,000.0
Black (BK)
450-20050
All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content.
Further information at www.HellermannTyton.com/insulation
229
很抱歉,暂时无法提供与“450-20041”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+876.015161+113.47460
- 5+803.086595+104.02780
- 15+705.6449515+91.40570
