Cable Ties and Fixings
1.6
Cable Ties With Fixing Elements
1-Piece Fixing Ties with rivet, releasable
Simply drill an 8 mm hole and knock in the peg. Used to fasten
cables, pipes or hoses in place.
Features and Benefits
• One-piece for fixing to brick, cement or wood
• Practical for the construction industry
• Time saving and versatile
• Depth of drill hole: 13.0 mm
Wall plug tie in application.
WPT230
TYPE
WPT230
Width
(W)
Length
(L)
Bundle
Ø max.
Hole Ø
(FH)
Material
Colour
Article-No.
8.0
230.0
59.0
8.0
PA66HIR
Black (BK)
126-00020
Material
Colour
Article-No.
PA66
Natural (NA)
148-00001
All dimensions in mm. Subject to technical changes.
1-Piece Fixing Tie with Self Adhesive Socket
• Bundling and fixing solution
• Ideal combination of materials and design
• Different positions of the fixing anchor are available to fit
installation space
T18RSA
TYPE
T18RSA
Material specification
please see page 22.
T18RSA
Width
(W)
Length
(L)
Bundle
Ø max.
2.5
100.0
16.0
80
72
Further information and products at www.HellermannTyton.co.uk/a72
Date of issue: January 2014
1.1
Material Information
Materi
a
Propert l
ies*
ability
Flamm
Colour*
Opera
tin
Tempe g
rature
ut
Shortc
Materi
al
Material Specification Overview
Aluminium-alloy
AL
-40 °C to +180 °C
Natural
(NA)
• Corrosion resistant
• Antimagnetic
Chloroprene
CR
-20 °C to +80 °C
Black
(BK)
• Weather-resistant
• High yield strength
Ethylenterafluorineethylen
E/TFE
-80 °C to +170 °C
Blue (BU)
UL94 V0
• Resistance to radioactivity
• UV- resistant, not moisture sentitive
• Good chemical resistance to:
• acids, bases, oxidizing agents
Polyacetal
POM
-40 °C to +90 °C,
(+110 °C, 500 h)
Natural
(NA)
UL94 HB
• Limited brittleness sensitivity
• Flexible at low temperature
• Not moisture sensitive
• Robust on impacts
Polyamide 11
PA11
-40 °C to +85 °C,
(+105 °C, 500 h)
Black
(BK)
UL94 HB
• Bio-plastic, derived from vegetable oil
• Strong impact resistance at low temperature
• Very low moisture absorption
• Weather-resistant
Polyamide 12
PA12
-40 °C to +85 °C,
(+105 °C, 500 h)
Black
(BK)
UL94 HB
• UV- resistant
Polyamide 4.6
PA46
-40 °C to +150 °C
(5000 h), +195 °C
(500 h)
Natural
(NA),
Grey
(GY)
UL94 V2
• Resistance to high temperatures
• Very moisture sensitive
• Low smoke sensitive
Polyamide 6
PA6
-40 °C to +80 °C
Black
(BK)
UL94 V2
Polyamide 6.6
PA66
-40 °C to +85 °C,
(+105 °C, 500 h)
Black
(BK),
Natural
(NA)
UL94 V2
Polyamide 6.6,
Glassfibre reinforced
PA66GF13,
PA66GF15
-40 °C to +105 °C
Black
(BK)
UL94 HB
• Good resistance to: lubricants, vehicle fuel, salt
water and many solvents
Polyamide 6.6
heat and UV stabilised
PA66HSW
-40 °C to +105 °C
Black
(BK)
UL94 V2
• Modified elevated max. temperature
• UV-resistant
Polyamide 6.6
Heat Stabilised
PA66HS
-40 °C to +105 °C
Black
(BK),
Natural
(NA)
UL94 V2
Polyamide 6.6
High Imp. Mod.,
Heat Stab.
PA66HIRHS
-40 °C to +105 °C
Black
(BK)
UL94 HB
• Higher flexibility at low temperature
Polyamide 6.6
High Imp. Mod.
scan black
PA66HIR(S)
-40 °C to +80 °C,
(+105 °C, 500 h)
Black
(BK)
UL94 HB
Polyamide 6.6
High Impact Modified
PA66HIR
-40 °C to +80 °C,
(+105 °C, 500 h)
Black
(BK)
UL94 HB
Tefzel® is a registered trademark of DuPont.
General linguistic usage for cable ties made from raw material E/TFE is Tefzel®-Tie. In additon to Tefzel® from
DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers.
**More colours on request.
*These details are only rough guide values. They should be regarded as a material specification and are no
substitute for a suitability test. Please see our datasheets for further details.
22
Further information and products at www.HellermannTyton.co.uk/a22
= Minimum Tensile Strength
1.1
Materi
a
Propert l
ies*
ability
Flamm
Colour*
Opera
tin
Tempe g
rature
ut
Shortc
Materi
al
Polyamide 6.6
high impact
modified, heat and
UV stabilised
PA66HIRHSW
-40 °C to +110 °C
Black
(BK)
UL94 HB
• High yield strength, UV-resistant
Polyamide 6.6
UV Resistant
PA66W
-40 °C to +85 °C,
(+105 °C, 500 h)
Black
(BK)
UL94 V2
• UV-resistant
Polyamide 6.6 V0
PA66V0
-40 °C to +85 °C
White
(WH)
UL94 V0
• Low smoke emission
Polyamide 6.6 V0
High Oxygen Index
PA66V0-HOI
-40 °C to +85 °C,
(+105 °C, 500 h)
White
(WH)
UL94 V0
• Low smoke emissions
Polyamide 6.6
with metal particles
PA66MP
-40 °C to +85 °C,
(+105 °C, 500 h)
Blue (BU)
UL94 HB
Polyamide 6
high impact modified
PA6HIR
-40 °C to +80 °C
Black
(BK)
UL94 HB
SP
-50 °C to +150 °C
Black
(BK)
PEEK
-55 °C to +240 °C
Beige
(BGE)
UL94 V0
• Good chemical resistance to: acids, bases,
oxidizing agents
Polyethylene
PE
-40 °C to +50 °C
Black
(BK),
Grey
(GY)
UL94 HB
• Low moisture absorption
• Good chemical resistance to: most acids, alcohol
and oils
Polyolefin
PO
-40 °C to +90 °C
Black
(BK)
UL94 V0
Polypropylene
PP
-40 °C to +115 °C
Black
(BK),
Natural
(NA)
UL94 HB
• Floats in water
• Moderate yield strength
• Good chemical resistance to: organic acids
Polypropylene,
Ethylene-Propylene-Dien-Terpolymere-rubber free
of Nitrosamine
PP, EPDM
-20 °C to +95 °C
Black
(BK)
UL94 HB
• Good resistance to high temperatures
• Good chemical and abrasion resistance
Polyvinylchloride
PVC
-10 °C to +70 °C
Black
(BK),
Natural
(NA)
UL94 V0
• Good chemical resistance to: acids, ethanol, oil
Stainless Steel
SS304,
SS316
-80 °C to +538 °C
Natural
(NA)
Thermoplastic
Polyurethane
TPU
-40 °C to +85 °C
Black
(BK)
Polyester
Polyetheretherketone
• UV-resistant
• Good chemical resistance to: most acids, alkalis
and oils
• Antimagnetic
UL94 HB
• High elastic
Further information and products at www.HellermannTyton.co.uk/a23
23
