151-14003
    HELLERMAN(海尔曼太通)
151-14003 数据手册
Cable Ties and Fixings 1.9 Clips, Clamps and Plugs Self Adhesive Clips These clips are ideal for use in applications which are difficult to access, or for areas where self adhesive is the only possible fixing method (for example where fixing ‚holes‘ would be unacceptable). Features and Benefits • One-piece self-adhesive fixing clips for quick and easy installation • Designed to hold wires, cables or hoses without cable tie • Different sizes for various bundle diameters One piece fixing clips Type RA quick and easy installation. • RA-Series with round design For more information on the types of adhesive please see page 73. RA3-18 Self Adhesve Clip TYPE Width (W) Width (W2) Length (L) Height (H) Bundle Ø max. Adhesive Material Colour Article-No. RA3 13.0 5.0 13.0 5.0 3.0 Synthetic rubber PA66 Natural (NA) 151-13018 RA6 19.0 5.0 19.0 9.0 6.0 Synthetic rubber PA66 Natural (NA) 151-13019 RA9 19.0 7.5 19.0 12.5 9.0 Synthetic rubber PA66 Natural (NA) 151-13020 RA13 25.0 10.0 25.0 16.5 13.0 Synthetic rubber PA66 Natural (NA) 151-13021 RA18 28.5 10.0 28.5 23.0 18.0 Synthetic rubber PA66 Natural (NA) 151-13119 All dimensions in mm. Subject to technical changes. • RB-Series with flat design Material specification please see page 22. RB5-14 Self Adhesive Clip TYPE RB5 RB8 Width (W) Width (W2) Length (L) Height (H) Bundle Ø max. Material 19.0 9.7 19.0 6.0 5.0 19.0 9.7 19.0 6.0 5.0 25.0 12.7 25.0 11.5 8.0 25.0 12.7 25.0 11.5 8.0 Colour Adhesive Article-No. PA66 Black (BK) Synthetic rubber 151-14000 PA66 Natural (NA) Synthetic rubber 151-14059 PA66 Black (BK) Synthetic rubber 151-13601 PA66 Natural (NA) Synthetic rubber 151-13606 Date of issue: January 2014 All dimensions in mm. Subject to technical changes. Further information and products at www.HellermannTyton.co.uk/a93 93 Cable Ties and Fixings 1.1 Material Information Materi a Propert l ies* ability Flamm Colour* * Opera tin Tempe g rature ut Shortc Materi al Material Specification Overview Aluminium-alloy AL -40 °C to +180 °C Natural (NA) • Corrosion resistant • Antimagnetic Chloroprene CR -20 °C to +80 °C Black (BK) • Weather-resistant • High yield strength Ethylenterafluorineethylen E/TFE -80 °C to +170 °C Blue (BU) UL94 V0 • Resistance to radioactivity • UV- resistant, not moisture sentitive • Good chemical resistance to: • acids, bases, oxidizing agents Polyacetal POM -40 °C to +90 °C, (+110 °C, 500 h) Natural (NA) UL94 HB • Limited brittleness sensitivity • Flexible at low temperature • Not moisture sensitive • Robust on impacts Polyamide 11 PA11 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Bio-plastic, derived from vegetable oil • Strong impact resistance at low temperature • Very low moisture absorption • Weather-resistant • Good chemical resistance Polyamide 12 PA12 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Good chemical resistance to: • acids, bases, oxidizing agents • UV- resistant Polyamide 4.6 PA46 -40 °C to +150 °C (5000 h), +195 °C (500 h) Natural (NA), Grey (GY) UL94 V2 • Resistance to high temperatures • Very moisture sensitive • Low smoke sensitive Polyamide 6 PA6 -40 °C to +80 °C Black (BK) UL94 V2 • High yield strength Polyamide 6.6 PA66 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK), Natural (NA) UL94 V2 • High yield strength Polyamide 6.6, Glassfibre reinforced PA66GF13, PA66GF15 -40 °C to +105 °C Black (BK) UL94 HB • Good resistance to: lubricants, vehicle fuel, salt water and many solvents Polyamide 6.6 heat and UV stabilised PA66HSW -40 °C to +105 °C Black (BK) UL94 V2 • High yield strength • Modified elevated max. temperature • UV-resistant Polyamide 6.6 Heat Stabilised PA66HS -40 °C to +105 °C Black (BK), Natural (NA) UL94 V2 • High yield strength • Modified elevated max. temperature Polyamide 6.6 High Imp. Mod., Heat Stab. PA66HIRHS -40 °C to +105 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature Polyamide 6.6 High Imp. Mod. scan black PA66HIR(S) -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature Polyamide 6.6 High Impact Modified PA66HIR -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®-Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers. **More colours on request. *These details are only rough guide values. They should be regarded as a material specification and are no substitute for a suitability test. Please see our datasheets for further details. 22 Further information and products at www.HellermannTyton.co.uk/a22 Date of issue: January 2014 = Minimum Tensile Strength Cable Ties and Fixings 1.1 Material Information Materi a Propert l ies* ability Flamm Colour* * Opera tin Tempe g rature ut Shortc Materi al Material Specification Overview Polyamide 6.6 high impact modified, heat and UV stabilised PA66HIRHSW -40 °C to +110 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature • High yield strength, UV-resistant Polyamide 6.6 UV Resistant PA66W -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 V2 • High yield strength • UV-resistant Polyamide 6.6 V0 PA66V0 -40 °C to +85 °C White (WH) UL94 V0 • High yield strength • Low smoke emission Polyamide 6.6 V0 High Oxygen Index PA66V0-HOI -40 °C to +85 °C, (+105 °C, 500 h) White (WH) UL94 V0 • High yield strength • Low smoke emissions Polyamide 6.6 with metal particles PA66MP -40 °C to +85 °C, (+105 °C, 500 h) Blue (BU) UL94 HB • High yield strength Polyamide 6 high impact modified PA6HIR -40 °C to +80 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature SP -50 °C to +150 °C Black (BK) PEEK -55 °C to +240 °C Beige (BGE) UL94 V0 • Resistance to radioactivity • Not moisture sensitive • Good chemical resistance to: acids, bases, oxidizing agents Polyethylene PE -40 °C to +50 °C Black (BK), Grey (GY) UL94 HB • Low moisture absorption • Good chemical resistance to: most acids, alcohol and oils Polyolefin PO -40 °C to +90 °C Black (BK) UL94 V0 • Low smoke emissions Polypropylene PP -40 °C to +115 °C Black (BK), Natural (NA) UL94 HB • Floats in water • Moderate yield strength • Good chemical resistance to: organic acids Polypropylene, Ethylene-Propylene-Dien-Terpolymere-rubber free of Nitrosamine PP, EPDM -20 °C to +95 °C Black (BK) UL94 HB • Good resistance to high temperatures • Good chemical and abrasion resistance Polyvinylchloride PVC -10 °C to +70 °C Black (BK), Natural (NA) UL94 V0 • Low moisture absorption • Good chemical resistance to: acids, ethanol, oil Stainless Steel SS304, SS316 -80 °C to +538 °C Natural (NA) Thermoplastic Polyurethane TPU -40 °C to +85 °C Black (BK) Polyester Polyetheretherketone • UV-resistant • Good chemical resistance to: most acids, alkalis and oils • Corrosion resistant • Antimagnetic UL94 HB Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®-Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers. • High elastic • Good chemical resistance to: • acids, bases, oxidizing agents **More colours on request. Date of issue: January 2014 *These details are only rough guide values. They should be regarded as a material specification and are no substitute for a suitability test. Please see our datasheets for further details. Further information and products at www.HellermannTyton.co.uk/a23 = Minimum Tensile Strength 23
151-14003 价格&库存
很抱歉,暂时无法提供与“151-14003”相匹配的价格&库存,您可以联系我们找货
