184-10068
184-10068
    HELLERMAN(海尔曼太通)
184-10068 数据手册
Cable Protection Systems 3.7 Wiring Ducts Rigid PVC wiring ducts HelaDuct HTWD-PN for small-diameter wires T1E wiring ducts are used in control panels, switching systems, and especially electronic control systems. Features and benefits • Narrow slots suitable for small-diameter wires • Smooth, burr-free edges protect installers from injury and wires from damage • Fingers can be removed with no sharp edges at pre-notched snap-off points • Further pre-notched snap-off point at base of sidewall allow cutting out and removing sections of sidewall with no sharp edges • Raised mounting points for easily and securely fastening wire retainers and other accessores prior to cabling • Wire retainers and accessories leave no protruding parts below surface of duct • Duct covers are easy to mount and remove, yet hold securely even in a vertical position and under vibration • Cover is flush with side of duct, allowing for tight, contiguous placement of ducts • Additional retainer nub on fingers on ducts height 80 and above to prevent cables from slipping • Base perforation according to DIN EN 50085 HTWD-PN wiring ducts with narrow fingers and slots for small-diameter wires. MATERIAL Polyvinylchloride (PVC) Colour Grey (GY) Length (L) 2m Operating Temperature -5 °C to +65 °C Flammability UL 94 V0 HTWD-PN wiring ducts base perforation according to DIN EN 50085 50 100 48.5 48.5 48.5 25 25 25 25 25 25 100 100 8 4.5 14 6.5 Width 40-60 Width 80-120 Hole dimensions For product specific approvals and specifications please refer to the Appendix. 348 Further information at www.HellermannTyton.co.uk/protection Date of issue: January 2019 Width 25 Cable Protection Systems Wiring Ducts 3.7 Rigid PVC wiring ducts HelaDuct HTWD-PN for small-diameter wires W W3 W2 H Wiring duct HTWD-PN Width (W) TYPE Height (H) Width (W2) Width (W3) Pack Cont. Article-No. HTWD-PN-25X40 25 40 4 6 72 m 184-10068 HTWD-PN-25X60 25 60 4 6 48 m 184-10138 HTWD-PN-25X80 25 80 4 6 48 m 184-10198 HTWD-PN-40X40 40 40 4 6 40 m 184-10078 HTWD-PN-40X60 40 60 4 6 36 m 184-10148 HTWD-PN-40X80 40 80 4 6 32 m 184-10208 HTWD-PN-40X100 40 100 4 6 16 m 184-10258 HTWD-PN-60X40 60 40 4 6 24 m 184-10088 HTWD-PN-60X60 60 60 4 6 24 m 184-10158 HTWD-PN-60X80 60 80 4 6 24 m 184-10218 HTWD-PN-60X100 60 100 4 6 8m 184-10268 HTWD-PN-80X40 80 40 4 6 24 m 184-10098 HTWD-PN-80X60 80 60 4 6 24 m 184-10168 HTWD-PN-80X80 80 80 4 6 24 m 184-10228 HTWD-PN-80X100 80 100 4 6 8m 184-10329 HTWD-PN-100X40 100 40 4 6 16 m 184-10108 HTWD-PN-100X60 100 60 4 6 16 m 184-10178 HTWD-PN-100X80 100 80 4 6 16 m 184-10238 HTWD-PN-100X100 100 100 4 6 8m 184-10278 HTWD-PN-120X60 120 60 4 6 16 m 184-10188 HTWD-PN-120X80 120 80 4 6 16 m 184-10248 Date of issue: January 2019 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.co.uk/protection 349
184-10068 价格&库存
很抱歉,暂时无法提供与“184-10068”相匹配的价格&库存,您可以联系我们找货
