321-30500
    HELLERMAN(海尔曼太通)
321-30500 数据手册
Insulation Heat Shrinkable Tubing 2.1 Heat Shrinkable Tubing 6:1, adhesive lined in 1 m cuts HA67 Insulates, seals and protects large size differences between connectors and cables. Features and Benefits • High shrink ratio, heavy-duty heat shrinkable tubing • Thermoplastic adhesive-lined tubing • Conforms well to highly variable substrate dimensions • Simplifies cable repair • Passes over large connectors and shrinks onto much smaller cable jackets • Environmental sealing and excellent insulation • Resistant to impact and abrasion One Step to the Web! Due to the high shrink ratio HA67 is suitable for complex shapes and dimensions. MATERIAL Polyolefin, cross-linked (PO-X) Shrink Ratio 6:1 Operating Temperature -55 °C to +110 °C Minimum Shrink Temperature +120 °C Softening Point Adhesive +85 °C Longitudinal change after shrinkage -10 % max. Dielectric Strength 20kV/mm according to ASTM D2671 Flammability not flame retarded L Heat Shrinkable Tubing 6:1 with adhesive Supplied Ø D min. Recov. Ø d max. Wall (WT) Length (L) Colour Article-No. 19.0 3.2 3.20 1,220.0 Black (BK) 321-30000 HA67-33.0/5.5 33.0 5.5 3.40 1,220.0 Black (BK) 321-30100 HA67-44.4/7.4 44.4 7.4 3.60 1,220.0 Black (BK) 321-30200 TYPE HA67-19.0/3.2 HA67-50.8/8.3 50.8 8.3 4.80 1,220.0 Black (BK) 321-30300 HA67-69.8/11.7 69.8 11.7 4.80 1,220.0 Black (BK) 321-30400 HA67-88.9/17.1 88.9 17.1 4.80 1,220.0 Black (BK) 321-30500 HA67-119.4/22.9 119.4 22.9 4.80 1,220.0 Black (BK) 321-30600 HA67-235.0/40.0 235.0 40.0 4.80 1,220.0 Black (BK) 321-30700 Date of issue: October 2015 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Further information at www.HellermannTyton.com/insulation 233
321-30500 价格&库存
很抱歉,暂时无法提供与“321-30500”相匹配的价格&库存,您可以联系我们找货
