Insulation Products
Heat Shrinkable Moulded Shapes
2.2
Pinched End Caps 3:1
with inner adhesive
• PEC
Features and Benefits
The PEC-Series can be applied fast and easy
like a standard heat shrink tube. The inner
adhesive layer and the adhesive plug provide
a good and secure water protection. The
optimal shrink ratio of 3:1 and different
diameters allow a wide range of application.
Other diameters and lenghts are available
on request.
Application
Pinched End Caps can be used for mechanical
and environmental protection of stub splices
in electrical harnesses. Due to the fast and
easy installation, these caps can be used for
non-electrical applications as well.
The appropriate end cap for every cable diameter, and cable types.
Material Data
Material
Colour
Shrink Ratio
Minimum Shrink
Temperature
Operating
Temperature
Dielectric Strength
Flammability
Polyolefin, cross-linked (POX)
Black (BK)
3:1
+120 °C
-45 °C to +125 °C
15 kV/mm according to IEC 60684 P2
self extinguishing in 30 seconds
according to SAE-AMS-DTL-23053/4
Inner Wall Adhesive
PEC-Series recovered
PEC-Series expanded
Technical Table
Article-No.
Type
Supplied
ØD
Recov.
Ød
Wall
(WT)
Length
(L)
Length
(L2)
416-00000
PEC-3/1
3.0
1.0
1.0
25.0
20.0
416-00003
PEC-4.8/1.5
4.8
1.5
1.0
30.0
25.0
416-00001
PEC-6/2
6.0
2.0
1.0
30.0
25.0
416-00002
PEC-9/3
9.0
3.0
1.4
35.0
27.0
All dimensions in mm. Subject to technical changes.
Date of issue: April 2011
299
很抱歉,暂时无法提供与“416-00002”相匹配的价格&库存,您可以联系我们找货
