Identification Systems
5.1
Wire and Cable Markers
Self-laminating labels, manual marking
RiteOn, Starter Pack, Material 1401 dispenser
A specially developed material for use in labels required to wrap around
cables and wires. The conformable structure of the label ensures that
once the label is applied to the wire it remains in place without lifting.
The SPRO200-1401-WH Starter Pack contains all you need to start work
identifying your wires,
• 1 x RiteOn dispenser
•1
x R202 reel of 150 self-laminating labels for cable diameters ranging
from 6mm to 12mm
• 1 x T82S-BK black indelible ink marker pen
Features and Benefits
• Palm sized hand held self-laminating label dispenser
• Easy to write on and dispense labels
• Wide range of wire diameters covered as standard
• Ideal for low volume maintenance and repair work
• Write text with specially formulated fast-drying ink T82 pens
The RiteOn starter pack gets you started right away.
Application video: RiteOn
TYPE
RO201-1401-WH
RO202-1401-WH
RO203-1401-WH
Description
Filled
dispenser
RO201REF-1401-WH
RO202REF-1401-WH
Refill packs
RO203REF-1401-WH
SPRO200-1401-WH
Starter pack
Bundle
Ø min.
MATERIAL
Type 1401, Vinyl (PVC)
Operating Temperature
-40 °C to +80 °C
Curing Temperature
from +10 °C
Adhesive
Acrylic
Thickness of Foil (µm)
80 µm
Chem. Material Properties
Resistant to water, alcohol, most
oils, greases, fuel, aliphatic solvents,
weak acids, salts and alkalis.
Bundle Width Height Height
Ø max. (W)
(H)
(H2)
Pack
Cont.
ArticleNo.
Colour
4.0
8.1
12.7
12.7
38.1
200 pcs.
White (WH), Transparent (CL)
550-14011
6.1
12.1
19.1
12.7
50.8
150 pcs.
550-14012
9.1
18.2
19.1
25.4
76.2
100 pcs.
550-14013
4.0
8.1
12.7
12.7
38.1
200 pcs.
550-14014
6.1
12.1
19.1
12.7
50.8
150 pcs.
550-11401
9.1
18.2
19.1
25.4
76.2
100 pcs.
550-71401
6.1
12.1
19.1
12.7
50.8
150 pcs.
550-14010
Description
Colour
Pack
Cont.
Article-No.
T82S-BK
Indelible Marker Pen
Black (BK)
2 pcs.
500-50820
T82R-RD
Red (RD)
2 pcs.
500-50822
TYPE
Subject to technical changes.
Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available.
442
Further information at www.HellermannTyton.com/identification
Date of issue: October 2015
All dimensions in mm. Subject to technical changes.
很抱歉,暂时无法提供与“550-14010”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+236.928091+26.58890
- 3+214.171723+24.03510
- 5+199.370015+22.37400
- 国内价格
- 1+203.91347
- 2+192.77393
- 5+187.04845
