111-01638
111-01638
    HELLERMAN(海尔曼太通)
    HELLERMANNTYTON - T50RFIDCLA - CABLE TIE, 200MM, NYLON 6.6, YELLOW
111-01638 数据手册
Identification Systems 5.4 RFID Cable Ties and Accessories Cable ties complete with integrated RFID transponder T50RFID – Low Frequency (LF) and High Frequency (HF) RFID cable ties provide an innovative solution for clear and rapid product identification. The nylon cable ties are equipped with an RFID transponder and therefore combine the numerous advantages of a regular cable tie with RFID technology. The ties are especially suited for securing, serialisation, tracking and identification of products in the areas of resource management, electrical inspection, inventory, distribution and rental services as well as for easy management of maintenance and repair routines. Features and benefits • Flexible, contactless data communication • Clear identification of objects through unique numbering • Faster data management compared to paper solution • More accurate documentation processes – prevention of human errors • Robust and resistant to harsh environments and cleaning processes • Low frequency (LF – 125 kHz) - Read only • High frequency (HF – 13.56 MHz) - Rewritable T50RFID – Cable ties with RFID transponder. MATERIAL Polyamide 6.6 (PA66) Frequency 125 kHz (LF) Idle Temperature -40 °C to +85 °C Operating Temperature -40 °C to +85 °C Flammability UL94 V2 13.56 MHz (HF) -25 °C to +85 °C L W T50RFID, MCTRFID TYPE Bundle Ø min. Frequency T50RFIDCLA T50RFIDCHA Bundle Ø max. Width (W) Length (L) Colour Pack Cont. Tools Article-No. 125 kHz (LF) 1.5 50.0 4.6 200.0 225 Yellow (YE) 100 pcs. 6;54 111-01638 13.56 MHz (HF) 1.5 50.0 4.6 200.0 225 Yellow (YE) 100 pcs. 6;52-53 111-01639 13.56 MHz (HF) 1.5 50.0 4.6 200.0 225 Black (BK) 100 pcs. 6;52-53 111-01591 13.56 MHz (HF) 1.5 50.0 4.6 200.0 225 Light Blue (LTBU) 100 pcs. 6;52-53 111-01673 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. More colours on request. Recommended Tools 6 52 53 54 EVO7 RFID-DT22-HF RFID-HS9BT-HF RFID-HS9BT-LF 554 521 520 520 Date of issue: 10/2017 For more information on toolings please refer to the Application Tooling chapter. For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.com/identification 515
111-01638 价格&库存
很抱歉,暂时无法提供与“111-01638”相匹配的价格&库存,您可以联系我们找货
