111-01667
111-01667
    HELLERMAN(海尔曼太通)
    HELLERMANNTYTON - 111-01667 - Cable Tie, Metal Content, Detectable, PP (Polypropylene) / Metal Parti...
111-01667 数据手册
Cable Ties and Fixings 1.1 Cable Ties Inside Serrated Cable ties for food industry, detectable The Metal Content Tie is a cable tie specifically designed for use in the food and pharmaceutical processing industries. A unique manufacturing process, involving the inclusion of a metallic pigment, enables even small 'cut-off' sections of the tie to be detected by standard metaldetecting equipment. Ideally suited for the installation of cabling in and around the manufacturing process. Features and benefits • Manufactured from metal content Polypropylene • High chemical and temperature resistance • Blue colour for easy visual detection • Greatly reduces risk of contamination • Magnetic and X-Ray detectable (detection level depending on specific application and equipment) • MCTS ties have very good corrosion resistance • Can support quality assurance in the production of food stuffs, for example HACCP MCTPP ties have a high chemical and temperature resistance. The MCT ties made of PA66MP are the ideal complement for MCMB mounts on page 142. MCT-Series / MCTS-Series PPMP Can support quality assurance in the production of food stuffs, for example HACCP. L W MCT-Series TYPE Width (W) Length (L) Bundle Ø max. 2.5 100.0 22.0 MCTPP18R 85 Material Colour Pack Cont. Tools Article-No. PPMP Blue (BU) 100 pcs. 2;4-6 111-01664 111-01665 MCTPP30R 3.5 150.0 35.0 130 PPMP Blue (BU) 100 pcs. 2;4-6 MCTPP50R 4.6 200.0 50.0 150 PPMP Blue (BU) 100 pcs. 2-10 111-01666 MCTPP50L 4.6 390.0 110.0 150 PPMP Blue (BU) 100 pcs. 2-10;12 111-01667 MCTPP120R 7.6 387.0 100.0 380 PPMP Blue (BU) 100 pcs. 3;9-12 111-01668 Material Colour Pack Cont. Tools Article-No. PPMP+ Blue (BU) 100 pcs. 2-10 111-01386 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. MCTS-Series, PPMP+ TYPE MCTS200 Width (W) Length (L) Bundle Ø max. 4.7 201.0 50.0 140 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. 2 3 4 5 6 7 8 9 10 11 12 MK20 MK21 MK3SP MK3PNSP2 EVO7 MK7HT MK7P MK6 EVO9 EVO9HT MK9P 545 545 546 546 548 549 550 551 549 549 552 For more information on toolings please refer to the Application Tooling chapter. 62 Further information at www.HellermannTyton.co.uk/fixings Date of issue: January 2019 Recommended Tools Cable Ties and Fixings 1.0 Material Information Material Specification Overview Material Shortcut Operating Temperature Colour** Aluminium alloy AL -40 °C to +180 °C Natural (NA) • Corrosion resistant • Antimagnetic Chloroprene rubber CR -20 °C to +80 °C Black (BK) • Weather resistant • High yield strength Ethylene Tetrafluoroethylene (Tefzel®) E/TFE -80 °C to +170 °C Blue (BU) UL 94 V0 Polyacetal POM -40 °C to +90 °C, (+110 °C, 500 h) Natural (NA) UL 94 HB Polyamide 11 PA11 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL 94 HB Polyamide 12 PA12 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL 94 HB • Good chemical resistance to acids, bases, oxidizing agents • UV resistant Polyamide 4.6 PA46 -40 °C to +130 °C, Natural (NA), (+150 °C, 5000 h; Grey (GY) +195 °C, 500 h) UL 94 V2 • Resistance to high temperatures • Very moisture sensitive • Low smoke sensitivity Polyamide 6 PA6 -40 °C to +80 °C Black (BK) UL 94 V2 • High yield strength PA6HIR -40 °C to +80 °C Black (BK) UL 94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature PA66 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK), Natural (NA) UL 94 V2 • High yield strength Polyamide 6.6 glass-fibre reinforced PA66GF13, PA66GF15 -40 °C to +105 °C Black (BK) UL 94 HB • Good resistance to lubricants, fuels, salt water and solvents Polyamide 6.6 heat and UV stabilised PA66HSW -40 °C to +105 °C Black (BK) UL 94 V2 • High yield strength • Modified elevated maximum temperature • UV resistant Polyamide 6.6 heat stabilised PA66HS -40 °C to +105 °C Black (BK), Natural (NA) UL 94 V2 • High yield strength • Modified elevated maximum temperature Polyamide 6.6 high impact modified PA66HIR -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL 94 HB PA66HIRHSW -40 °C to +110 °C Black (BK) UL 94 HB Polyamide 6 high impact modified Polyamide 6.6 Polyamide 6.6 high impact modified, heat and UV stabilised Material Properties* Material Specifications • Resistance to radioactivity • UV resistant, not moisture sensitive • Good chemical resistance to acids, bases, oxidizing agents • Limited brittleness sensitivity • Flexible at low temperature • Not moisture sensitive • Robust on impact • Bio-plastic, derived from vegetable oil • Strong impact resistance at low temperature • Very low moisture absorption • Weather resistant • Good chemical resistance • Limited brittleness sensitivity • Higher flexibility at low temperature • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated maximum temperature • High yield strength, UV resistant • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated maximum temperature Polyamide 6.6 high impact modified, heat stabilised PA66HIRHS -40 °C to +105 °C Black (BK) UL 94 HB Polyamide 6.6 high impact modified, scan black PA66HIR(S) -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL 94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature PA66W -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL 94 V2 • High yield strength • UV resistant Polyamide 6.6 UV resistant 26 Flammability Further information at www.HellermannTyton.co.uk/fixings Date of issue: January 2019 MATERIAL Cable Ties and Fixings Material Information Material Shortcut Operating Temperature Polyamide 6.6 with metal particles PA66MP Polyamide 6.6 with metal particles Polyamide 6.6 V0 MATERIAL Colour** Flammability -40 °C to +85 °C, (+105 °C, 500 h) Blue (BU) UL 94 HB • High yield strength • Metal and X-Ray detectable PA66MP+ -40 °C to +85 °C Blue (BU) not flame retardant • High yield strength • Metal and X-Ray detectable PA66V0 -40 °C to +85 °C White (WH) UL 94 V0 • High yield strength • Low smoke emission SP -50 °C to +150 °C Black (BK) PEEK -55 °C to +240 °C Beige (BGE) UL 94 V0 • Resistance to radioactivity • Not moisture sensitive • Good chemical resistance to acids, bases, oxidising agents Polyethylene PE -40 °C to +50 °C Black (BK), Grey (GY) UL 94 HB • Low moisture absorption • Good chemical resistance to most acids, bases, alcohol, oils Polyolefin PO -40 °C to +90 °C Black (BK) UL 94 V0 • Low smoke emissions Polypropylene PP -40 °C to +115 °C Black (BK), Natural (NA) UL 94 HB • Floats in water • Moderate yield strength • Good chemical resistance to acids, bases and solvents PP, EPDM -20 °C to +95 °C Black (BK) UL 94 HB • Good resistance to high temperature • Good chemical and abrasion resistance Polypropylene with metal particles PPMP -40 °C to +115 °C Blue (BU) UL 94 HB • Metal and X-Ray detectable • Heat resistant • Moderate yield strength • Good chemical resistance Polypropylene with metal particles PPMP+ -40 °C to +85 °C Blue (BU) not flame retardant • High yield strength • Metal and X-Ray detectable Polyvinylchloride PVC -10 °C to +70 °C Black (BK), Natural (NA) Stainless Steel, Stainless Steel SS304, SS316 -80 °C to +538 °C Natural (NA) Thermoplastic Polyurethane TPU -40 °C to +85 °C Black (BK) Polyester Polyetheretherketone Polypropylene, Ethylene Propylene Diene Terpolymer rubber free of Nitrosamine Material Properties* 1.0 Material Specifications • UV resistant • Good chemical resistance to most acids, bases and oils • Low moisture absorption • Good chemical resistance to acids, bases, salts, alcohol, oils • Corrosion resistant • Antimagnetic • Weather resistant Non burning • Chemical resistance • SS316 also resistant against seawater, salt spray and anorganic acids UL 94 V0 UL 94 HB Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton also uses equivalent E/TFE raw material from other suppliers. • High elasticity • Good chemical resistance to acids, bases and oxidising agents **Further colours available on request. Date of issue: January 2019 *These details are only guide values. They should not be regarded as a exhaustive material specification and are no substitute for suitability tests. Please see our datasheets for further details. HF = Halogenfree LFH = Limited Fire Hazard RoHS = Restriction of Hazardous Substances Further information at www.HellermannTyton.co.uk/fixings 27
111-01667 价格&库存
很抱歉,暂时无法提供与“111-01667”相匹配的价格&库存,您可以联系我们找货
  • 100+5.93898100+0.76727
  • 500+5.28299500+0.68252
  • 1000+4.784431000+0.61811
